Gnr TG700H power problem
  • ash
    • Nov 2009
    Having major problems with this Gnr TG700H monitor. Its the famous 1 second display problem, comes on for 1 second and then quickly shuts down. I have openned it up and ALL the rubycon caps are in pristine condition!
    The whole power board looks in very good condition with no darkened areas. The soldering joints look OK.
    I just replaced all the capacitors anyway with absolutely no joy.
    A friend also has a similar monitor with a slightly different problem - dim display. The monitor comes on but display is very dim.
    Any help on this would be much appreciated.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Gnr TG700H power problem
    I'd suggest searching for my posts on the 'Two Seconds to Black' issue and start checking out the possibilities. Post good pictures of the front and back of the inverter after reading these instructions.
    PlainBill
    • ash
      • Nov 2009
      OK, thanks Bill. Like alot of people on this site, my talents are only limited to replacing caps! I wish I could trouble shoot and do other things .
      • Wrog
        • Oct 2009
        • 472
        Don't sell yourself short -- if you can replace caps, then you are certainly capable of performing more troubleshooting provided you have basic test equipment (for example, a DMM or VOM). You have access to a lot of resources here (particularly the history of troubleshooting others' problems here in the forums), so take the time to read, read, read! When you get to a point where you are stuck or want clarification, ask a specific question and there are many here to help.
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • Duranitron
          Asus x512dk rev 2.1 power on problem
          by Duranitron
          When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
          Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
          11-26-2024, 10:22 PM
        • usbdevice
          Acer X223HQ (Version Bbd) on/off-power-cycling
          by usbdevice
          Hi all
          There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
          https://www.badcaps.net/forum/showthread.php?t=50657
          https://www.badcaps.net/forum/showthread.php?t=40512
          The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
          It's my dad's old monitor. He...
          08-05-2022, 02:21 AM
        • EazyBone
          LG OLED55C9PUA power problem
          by EazyBone
          Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
          Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
          I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
          The power supply to t con is different story.
          This...
          06-23-2023, 07:43 AM
