Old but unused Dell Monitor
  • slap_happy
    • Nov 2011
    • 46
    I just broke the factory seal on a Dell (Philips) monitor that was manufactured in July of 2010.
    I decided to check the power supply board (see image) before I even powered up the monitor for the first time.
    The following is a list of the electrolytic capacitors. Are any of these more urgent than the others to replace?
    C605
    Lelon A207(M)
    120uF 450v
    C501, C503, C505
    FDAI
    220uF 10v
    C521, C522, C855
    Elite
    220uF 25v
    C606
    Lelon
    A032(M)
    33uF 50v
    C851
    Elite
    220uF 35v
    C703
    FDAI
    470uF 25v
    C707, C708
    nichicon HE(M)
    680uF 16v
    C704, C801
    Lelon
    330uF 35v
    I did later power up the monitor, and it does work fine. The best parts are the two nichicon parts (C707, C708) on the secondary. Even though they are all unused, they are all 11 years old.
    This power supply board is not very commonly available on the used market, so I'd like to protect it from the old capacitors causing the failure of other components. Should all of caps be replaced?
  • Griffmadár
    • Nov 2021
    • 5
    • Hungary
    Re: Old but unused Dell Monitor
    Hello
    I think yes to be in safe side. In a 11 years old capacitor the electrolyt could harm the body it self. The cost of set of new capacitors including big one ( i guess 120uF 450V) are nothing compare to the value of "new" monitor. Did you visually checked the capacitors on video board too?
      • Jul 2011
      • 6069
      I would probably do a complete recap myself only because if the quality of the capacitor are in question and because it sat in storage for so long and you probably do not know what conditions the place where the storage took place
        • 31214
        dont spend a penny on ANY monitor until you get it to display an image.
        panels fail a lot and you wont know till you try it if the bonded cables have failed and put lines on the screen!!!
        specially on 2010 ish DELL crap - i have about 8 of them that work and have binned atleast 4 with bad panels.
        incase your wondering, i dont buy monitors - i recover ones that companies throw out during upgrades.
        i would never risk spending even the cost of a beer on a dell monitor!
        • CapLeaker
          Leaking Member
          • 8329
          yeah... i wouldn't spend a cent on a dell either, unless i have something kicking around in my parts bin. just run it like that until it dies.
          • Borse2008
            Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
            by Borse2008
            Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
            I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
            • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
            • There’s
            07-15-2025, 04:55 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • DanPoka
            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
            by DanPoka
            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
            02-15-2025, 05:05 AM
            by momaka
            03-15-2023, 10:17 PM
          • Jesus Coder
            Issues Reviving Old Dell 2408WFPb Monitor
            by Jesus Coder
            I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
            06-25-2023, 02:33 PM
