HP 1740 lcd monitor white screen.
  • andy smethurst
    • 49
    Hi, everyone
    I have a HP 17" lcd monitor that powers up to a white screen. This is a new fault for me even though I have heard of it, i never wanted to see it. I have tried different data cables and computers, and checked the capacitors and pico fuse. Is there a typical fault condition that causes the white screen?.
    Thank you for any experienced feedback. Andy
  • sofTest
    • Aug 2008
    • 361
    Re: HP 1740 lcd monitor white screen.
    The most common cause for a white screen, is a defective fuse on the video/logic board in the monitor, not on the power/inverter board, if that's the one you have checked. If it's only the fuse, or there is faults that caused the fuse to open, has to be investigated by you.
    Be a mensch
    • andy smethurst
      • 49
      Thanks SofTest for the tip, I then moved to the data board and found two s.m fuses.
      Unfortunately these tested OK.
      • PlainBill
        • Feb 2009
        • 7034
        I think you are still not looking at the correct board. Just to humor me, post a picture of the back of the lcd panel.
        PlainBill
        • andy smethurst
          • 49
          I see, I thought you meant the dat board. I then checked the fuse on the LCD board, and yes it was open. I could not find why, so i replaced it with a similar one of the same amperage, and when turned on burned a three pin device on the data board near the data to LCD socket. The components on the lcd board are getting to small to see or re-work these days.
          Regards: Andy.
          • harp
            White screen repairs
            by harp
            To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
            Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
            On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
            05-13-2024, 03:43 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
            by momaka
            03-15-2023, 10:17 PM
          • abajor
            A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
            by abajor
            Having this very weird issue.
            The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
            I swapped with a working screen from an A2141 waiting for parts.
            The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
            The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
            04-27-2024, 01:37 PM
          • EazyBone
            Sharp LC-65Q620U White Screen
            by EazyBone
            Another TV topic!!
            I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
            The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
            Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
            08-21-2024, 12:56 PM
