I have a 26" benq monitor/tv Model: dv2680. It has 8 ccfl's backlights and one is bad. In lieu of replacing it, can someone tell me how to fake it out or bypass it. Its viewable with 7 of them working...Thanks
Sam
Re: Sam
Originally posted by squiddiddlerI have a 26" benq monitor/tv Model: dv2680. It has 8 ccfl's backlights and one is bad. In lieu of replacing it, can someone tell me how to fake it out or bypass it. Its viewable with 7 of them working...Thanks
Second, use a more descriptive thread/topic name.
Third, look around for Dummy Load. I think PlainBill would be able to help you in that topic, as I do not have enough knowledge to serve you ...There are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- Intel Core i5-7600K 3.8GHz
- 16gb GSKILL TridentZ RGB DDR4-3200
- 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
- Windows 10 Pro x64
- GeForce GT1050
2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job)
Re: Sam
I mentioned those because I'm not going to infer a relationship between those names and what you are trying to do.
In general, here is the theory. Measure the voltage across and the current through a working CCFL. Calculate the equivalent resistance and power dissipation of the CCFL. I.E. If there is 780 V at 8.3 ma through a good CCFL the equivalent resistance is 94K ohm. 100K ohm is close enough. It was dissipating 6.5 watts, better use a 10 Watt resistor.
Now the problem is your typical DMM won't accurately measure the voltage or the current. The best solution is to pick up a range of 10 Watt resistors and try them until you find the highers value that works, then go down 10%.
Of course, by the time you have done that you will have spent more than you would pay for a new CCFL, and you won't have to be annoyed by people asking why there is a dark band across the screen.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Re: Sam
Originally posted by PlainBillGreetings. I just returned from a day escorting my Grandson around Disneyland. He got to see Buzz Lightyear, have his picture taken with Goofy, ride on Dumbo, and play in Mickey Mouse's Toonland.
PlainBillThere are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- GeForce GT1050
Re: Sam
Originally posted by WizardYes this is what is done to load test the lamp inverters. Even in few service manuals spells this out.
and 96K is too low, I recall around 120K and yes use 10W sand bar because of high KV.
Cheers, Wizard
