Gateway FPD2485W - capacitor related?
Re: Gateway FPD2485W - capacitor related?
Hi, I'm new as well. I have the same Gateway Monitor it stopped working.
All else seems to work, I just have no picture. No Gateway splash screen, other inputs don't work (PS2 console) either.
I was watching it about 2 weeks ago (I use it as my TV for my Media Center PC) and it just went black all of a sudden.
I went searching on Google and found this forum. I haven't cracked it open yet but I will be this weekend. I guess I could try replacing caps, is that usually the problem with these things?
ThanksComment
Need more info.. when you power up, you get no Gateway logo but is the power LED still lit? Does it stay lit as long as an input signal is present or does it go into sleep mode? If you use a flashlight in a dark room, can you see the picture?
Doesn't sound like a cap problem to me, it's probably inverter related. Still, it's a good idea to double check the state of the caps. Pics of the top/bottom of each of the boards (power/inverter and main logic) would be helpful to troubleshoot. When you take the monitor apart, remember to start on the side opposite the touch controls. There is a FFC (flat flex cable) on that side that you need to be careful with!Comment
The Touch Controls still work. My room is dark, there is no Splash Screen. I switched inputs from the Media Center (VGA) to my PS2 console (Component 1) and still no picture. I connected my laptop to both VGA and DV-I, still nothing. The laptop "saw" the panel but there was no picture.
When you turn it on, I get the tones and the lights remain blue. But it will then time out and go orange.
When the game is over I'll pull it apart and take some pictures.Comment
Hello everyone, another new member here. I just inherited a Gateway LP2407 (also refered to as FPD2485W). I don't know the history of the monitor, but it has the same symptoms as posted here. When I plug it in, it makes the musical sound, and the blue power light comes on and the lights above it flash on, but then after a while the light turns orange. There is absolutely no picture being displayed. I already took the monitor apart and found quite a few caps that were bulged on the top - on all 3 boards, so I replaced all the caps but the biggie on the power supply board -the 150uF 450V one (it wasn't bulged and appears to be hard to find). So after putting it back together, I still get no display. I'm sure a lot of the capacitors were bad, so they should have been replaced, but now I'm wondering if there is a bad fuse. I checked the fuse on the power supply board (F850) and it checks out ok. I looked at the inverter board, and I'm guessing that F1 may be a fuse. If it is, It doesn't appear to be ok. If I touch DVM to ground and the other lead to one side, it buzzes, but if I put it to the other side of F1, nothing. I replaced both caps on this board because they were swollen. Assuming F1 is a fuse, and it is bad, could the swollen caps have caused the fuse to blow? If not, any advise what else to check? If it is a fuse, does anyone know where to get it and/or part#? Thanks in advance for any help. RussellComment
A clear focused picture of your fuse would help. Manufacturers can change board revisions and may not use the same components even though the model number on the front of the LCD are the same.
If you are in the USA, I'm sure Digikey has a replacement fuse.--- begin sig file ---
--- end sig file ---Comment
Hello, and thanks for the quick reply. I did test the fuse in the manner that you described, but it didn't seem like I was getting a good connection, so I also tried it the way I mentioned. I attached 2 pictures for you to view. I wanted to confirm that this is indeed a fuse (I assume the F in F1 means fuse 1). I am tempted to try to jump across the fuse with a real thin wire strand or something just to confirm that it does something. If it works, I would be more willing to order a fuse from digikey if they have it. That is where I ordered my caps from. I'm sure shipping would exceed the cost of the fuse. There is nothing protruding from the backside of the circuit board, so I guess this would have to be desoldered and resoldered from the front.
Thanks,
RussellComment
If it says 2 on the fuse F1, then I believe it is a 2A fuse. I'm not sure what voltage rating is though. It could be 2A 125V or 2A 250V. Maybe someone else with more experience can verify?--- begin sig file ---
All it shows is IE 5A, so I assume it's a 5 amp fuse. When I say I'm tempted to jump a wire strand across, I mean literally a single, very thin wire that you would get from a strand. I would never put a complete wire strand across, that would defeat the purpose of a fuse. I think this part # from Mouser is the same...576-0453005.MR.Comment
On my Radio Shack DVM, it shows a 1 which is open. When I first tested, it seemed like it was showing something, but then went to 1. I'm pretty certain the fuse is bad. I just hope that's all it is.Comment
"1" is definitely open. I would probably order 2 fuses just in case.
I believe digikey.com has lower shipping costs than mouser. For first class shipping, I believe Digikey is in the $2.75 USA range.--- begin sig file ---
I found a 4 amp fuse (the round glass type that are often used for car radios, etc) that had a wire on each side. I soldered each end to each end of the fuse on the inverter circuit. After doing this, I plugged it in and first thing I noticed is that it didn't make the muscial sound that it did before. The display is still blank however. One problem I have is I don't know how this monitor behaves when it does work. Is there someone who is familiar with this monitor? Does it normally turn itself on, or at least play the music when it is first plugged in, or do you have to push the power button? I hooked up the thin 5 strand wire and it doesn't power on when I push it. I'm not sure what to do or check next. Hopefully someone here can give me a few pointers to try. I can check for some voltages, etc. if someone can tell me where to. If you need pics, I can upload some, but there already are pictures at the beginning of this thread from others.
Thanks,
RussellComment
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
by Rick_1234Good evening, gentlemen.
I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
https://drive.google.com/file/d/1L6S...ew?usp=sharing
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
by momakaLooking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
When I saw the Craigslist post, I wasn't...-
- Loading...
