Gateway fpd1730 Problem
+ More Options
Posts
  • pdog_phatpat
    • Aug 2009
    • 37
    Hello! I have this lcd monitor generously donated by a friend who was tired of dealing with its problem. I hooked it up to my PC to test it and let it run a screensaver for about an hour an a half and had no problems. The problem comes in when its simply switched off or goes into standby. When the monitor is switched off, after a period of time it cannot be turned back on...OR...After a period of time in standby, the amber light will go off and the monitor cannot be turned back on. If I unplug the power cord for maybe 5 seconds then everything works fine again, until one of the above things happens. What I do not understand is the noise coming from the power section. It starts as soon as I plug in the monitor and remains even though it is completely off. When switched on the noise goes away until it goes into standby. I have attached a sound file. Maybe the noise is normal, I don't know. Any advice is appreciated!
  • PlainBill
    • Feb 2009
    • 7034
    Re: Gateway fpd1730 Problem
    1. Open the monitor up by removing the rear cover and the shield over the electronics.
    2. Look for caps with their tops bulging. If you find them
    3. Order name brand low ESR replacements for ALL caps, even those not bulging
    4. Install the replacements
    5. Close the monitor back up
    6 Enjoy.
    PlainBill
    • pdog_phatpat
      • Aug 2009
      • 37
      Thanks for the reply! It's already open. No visible bad caps. I'll get pics if you want them. Did you listen to that sound clip? Is that normal?
      • EGuevarae
        • Nov 2008
        • 1336
        Do what PlainBill suggested. Post the info. If pics are needed he/we will let you know.
        • ASUS ROG Maximus IX Code
        • Intel Core i5-7600K 3.8GHz
        • Windows 10 Pro x64
        • GeForce GT1050
        • PlainBill
          • Feb 2009
          • 7034
          They symptoms you describe are consistent with bad capacitors. What are the brand and series? Some manufacturers are quite adept at manufacturing caps that fail without any physical sign.
          PlainBill
          • pdog_phatpat
            • Aug 2009
            • 37
            Okay. Bear with me I have a horrible camera and horrible lighting. I'm calling PB the Power Board and it has 4 Rubycon YXG's. LB will be the Logic Board and it's all Teapos and 1 Rubycon YXG. IB is the Inverter Board and it has 2 Sanyo's.
            • PlainBill
              • Feb 2009
              • 7034
              Pictures are good enough. I've seen a lot worse.
              First step: Measure the voltage at CN2. Judging by the connector on the logic board, this is a single output supply. I don't see any indication of the rated output voltage, but would expect 12 -18 volts. Of course, you can keep fiddling with it until the monitor does start up. If there is no output voltage initially, replace the two small electrolytic caps at the end of the very large cap.
              Next step: If there is output voltage, on the logic board there are two voltage regulators between CN2 and CN5. One of them is U5. What are the voltage on all three pins of those regulators?
              PlainBill
              • pdog_phatpat
                • Aug 2009
                • 37
                I have 12 volts coming out of the power board. The regulators are U5 and U6. So, looking at the picture with the vga connector at the bottom, from top to bottom pin: U5: 5.05, 3.33, 2.08. U6: 5.05, 2.49, 1.24-1.25.
                • PlainBill
                  • Feb 2009
                  • 7034
                  So I would assume that U12 and the FET driectly above it step the 12 volts down to 5.0. I'm not sure if there is a 1.25 volt supply on this board.
                  Were these readings taken with the monitor hooked together? If so, was it working?
                  I'm about of ideas. The only thing else I can suggest is recapping the logic board and the power supply. It may be a long shot.
                  PlainBill
                  • pdog_phatpat
                    • Aug 2009
                    • 37
                    Yeah...the thing is all over the place as far as reliable operation goes. I put everything back together and hooked it to a PC and had picture while I tested it. I had it face down while I was testing it and 2 times it shut off and I had to unplug the power, wait around 30 seconds, plug the power back in and then it was fine. Right now I have it plugged into the PC and am running Serious Sam demos and so far no problems after 2 hours. Confusing.
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Ahaa!!! An intermittent! Your mission, should you decide to accept it, is to measure the above voltages when it decides to shut off. Start with the 12 Volt output of the supply.
                      PlainBill
                      • pdog_phatpat
                        • Aug 2009
                        • 37
                        Thanks for the Help PlainBill. The monitor has worked perfectly since yesterday, so it's making it kinda hard to test. It figures...it's fighting me. I'll continue to use it and see if the problem comes back. I'll post the results when it starts acting up again...and I'm sure it will at some point.
                        • alex the great
                          • Oct 2011
                          • 5
                          I own a Gateway FPD 1730 with the power board being a Powernet PWI1504FG. I replaced all the capacitors with the exception of the 0243. I got my hands on another similar board. I replaced the 2 capacitors on the video board (this monitor has only 2 boards), to no effect.
                          Any suggestions are welcomed.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            1) Post pictures in the same format and composition of YOUR boards like post #6.
                            2) Describe the problem with your monitor in detail.
                            3) Do you own a multimeter?
                            --- begin sig file ---
                            --- end sig file ---
                            • alex the great
                              • Oct 2011
                              • 5
                              Here is the copy of the board in question.
                              • alexanna
                                • Mar 2010
                                • 1346
                                What's the problem??With the monitor.
                                • Rick_1234
                                  LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                  by Rick_1234
                                  Good evening, gentlemen.
                                  I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                  To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                  https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                  Things I tried
                                  - Bought a new AC adapter thinking that was the problem but the problem...
                                  06-22-2024, 04:44 PM
                                • Askic
                                  Problem with monitor DS-D5022QE-B
                                  by Askic
                                  Hello to all,
                                  I have a problem with monitor that is delivered together with CCTV system.
                                  The monitor appears to be completely dead, there is no LED power diode and it doesn't react to pressed power button.
                                  I have disconnect display and check many components on the power supply part of the board. There is no anything obvious and monitor is about 3 years old. There are no bulged caps. When measuring voltages on the output connector to VGA board I can measure stable 14.5 V on 12V pins and stable 5.07V on 5V pins. So I assumed that this part of the board is OK....
                                  05-31-2023, 03:14 AM
                                • CptChronic
                                  Samsung LU32J590UQUXEN Monitor display problem
                                  by CptChronic
                                  I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
                                  Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
                                  But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
                                  04-24-2023, 04:33 PM
                                • tmhobadcap
                                  LG 24MP56HQ-P Monitor Backlight problem?
                                  by tmhobadcap
                                  I have a few successful experience in fixing tv backlight problem. But for monitor, I have no experience. However, I think they are more or less the same. Am I correct?
                                  Recently, I got the captioned monitor and the owner said it could not be turned on. I open it up and found that one of the SMT capacitors seemed to be bad. I replaced it as well as the other one. The monitor still could not be turned on.
                                  I found the power indicator is on. When I shine a flashlight on the screen, I can see the image. Therefore, I think it is with backlight problem. I took out the led strip....
                                  10-13-2021, 01:52 PM
                                • tmhobadcap
                                  by tmhobadcap
                                  10-12-2021, 01:43 PM
