lcd psu problem
    lcd psu problem
    how do i post pictures here o this psu board??
    School fees paid as everyday is a learning curve.
    Re: lcd psu problem
    https://www.badcaps.net/forum/showthread.php?t=1868
      Re: lcd psu problem
      ive got a lamp driver problem on presario monitor one of ic's have poped and cant find it any where only marking it have is .....CD7K27...wich sound like this 8 pin ic was made for this monitor .....went to the Huipu electronics(shenzen) co ltd website but no help there
      If can figure out how to post pics of this board ill attach them
        Re: lcd psu problem
        The first picture was acceptable, the one of the bottom of the board wasn't good enough to show anything.
        A few hints: Take the pictures in a well lit area, and use a tripod or steady your hand when you take the picture.
        In this case, I see one obvious problem in the top view. The cap by itself at 10 O'clock has a bulging top. On the bottom of the board the SMPS controller (8 pin IC) and inverter controller (16 pin IC) and inverter drivers (8 pin ICs) are obvious by location, but I can't see enough detail to see which has 'poped'.
        PlainBill
          Re: lcd psu problem
          Hi thanks for replying back i have uploaded a much better picture .
          Im aware of the cap hence the reason i think the ic popped..... so that i can sort out. The main problem is i can't find the part for the inverter bit for the cfl's
          you will see the one that popped and one is still ok the top bit off the number is the same 4605 and the other number is cd7k27 . but no data sheet provider turn anything up on these part numbers.
          And if i can find out exactly how this ic operates i could build a generic of some sort.
            Re: lcd psu problem
            Are you sure its a 5 and not a 6
            check this out
            http://www.alldatasheet.com/datashee...MD/AO4600.html
              Re: lcd psu problem
              And you just don' stop rocking .....now to see if i can get hold of that ic in South Africa
              Thanks a stack mate .
