Dell E196FPf
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Re: Dell E196FPf
Hi all, this will be my first attempt at repairing an LCD monitor. I haven't done much repair work in a long time, so I'm dusting off my gear and hoping for the best... Monitor is a Dell E196FPf no backlight. Image is visible on the monitor with a flashlight so I suspect just the inverter, or maybe a bad lamp, though none of the 4 come on at all, even at power up... 2 caps in the inverter section are bulged and have relatively high ESR (2 ohms) other than that no obvious visible signs.
We've done a bit of minor cap repair to some older model car dashboards, but nothing really like a computer board. Before I dive in, any pointers - things to do, not do, watch out for, buy, etc.?
Thanks in advance for any help.Comment
Re: Dell E196FPf
I'm caught up on other projects and have replacement caps for these monitor boards in hand. Any advice on how to proceed? As I mentioned above, we have some soldering/cap replacement experience, but it was only on car dashboards about 10-15 years old. We've never tackled anything complicated like a computer motherboard. We do have a couple of different soldering irons but, for the most part, we're starting from scratch in both supplies and experience.
Thanks in advance for any advice - or pointers to instructions we could use.Comment
Re: Dell E196FPf
Ok there is awhole forum devoted to this amongst other things
Read this https://www.badcaps.net/forum/showthread.php?t=31448
There is some useful ideas and a youtube video which leads to a whole series of videos on
soldering.
My tip - 40 watt iron Leaded solder with flux. more flux. if you are working in a cold place pre heat the board gently with a hair dryer or very very gently with a hot air gunPlease upload pictures using attachment function when ask for help on the repair
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
by Jesus CoderHello everyone,
I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...-
I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
Does someone have seen this before?...-
by paparazzo79Hi guys.
I got myself used Dell 27" touch monitor but I got scammed again, seller sent HP adapter.
Though voltages are the same, I suppose power supply design is not the same.
So may I use it without any harm to the monitor?...-
- Loading...
