Hyundai L90D+ inverter mosfet problem
  • camra88
    • Dec 2010
    • 8
    #41
    Re: Hyundai L90D+ inverter mosfet problem
    Results:
    all caps and Q's are not short circuited. Including C22 & C52.
    All resistors are within tolerances
    All diodes? (D's) also pass this test, except for 2:
    D14 and D16 (to the left of the 0Z960SN) -- i get a reading of 98 ohms across the two legs next to each other. They are the legs connected in parallel to a 390 ohm resistor (according to marking 3900).
    I find this low, considering measurements taken off similar D's: D10 and D11 (they all have similar markings A7>) measured at 1k ohms. (390 || 1000) = 280 ohms. Is this a normal in-circuit resistance at those two nodes?
    • retiredcaps
      • Apr 2010
      • 9271
      #42
      Personally, I would change the caps first and retest. However, if you have really good soldering skills and can remove D14 and D16 without destroying them, you can test them out of circuit. In circuit testing can be affected by surrounding components.
      My soldering skills for something that small dictates that I try new caps first.
      --- begin sig file ---
      --- end sig file ---
      • camra88
        • Dec 2010
        • 8
        #43
        I replaced those caps with 25v, 330uF's. Problem remains.
        I also noticed that when I first turn the monitor on, the backlight flickers for only a quick moment. I didn't notice it until I turned the lights off in the room.
        After turning it on and off many times to observe this just now (about a dozen+ times), the monitor turns off once it attempts to power up the backlight. If I give it a minute, it will stay on again. I don't know if this means anything?
        Knowing this, can I pinpoint the culprit?
        • jetadm123
          • 2169
          #44
          Since you're getting a flicker of the backlight before shutdown, this could be caused by:
          1) Bad wiring to the CCFL tube(s)
          2) Bad CCFL tube
          3) Bad inverter transformer
          To check the CCFL tube, you'll have to find a known good one and susbstitute for the existing tube.
          Check the resistance of the secondary for each inverter transformer. There should be no more than 3% difference between the two.
          • retiredcaps
            • Apr 2010
            • 9271
            #45
            I circled the inverter transformer secondaries. With power off and lcd unplugged, set your multimeter to 2000 ohms (if manual).
            Measure the resistance between the 2 red dots. Report measurement. Do the same for the blue dots.
            • rurban
              • Nov 2010
              I have a mildly off-topic contribution to this thread...
              my L90D+ exhibited similar problems (power light flashed orange briefly then went back to blue, accompanied by a quiet clicking sound). I found a used power-supply in china and had it sent to me, which took 3 months. The PS was functional, but it already had a brown burn mark on the component side opposite one of the inverter MOSFETs.
              I fashioned a heat-spreader and siliconed it to the PC-board to get the most out of the used PS. Picture below.
              I also removed the plastic enclosure around the PS, and instead glued a piece of plastic to the back of the panel opposite the PS, in order to improve air circulation.
              R. Urban
              • Sharky-T
                • Nov 2014
                [QUOTE=retiredcaps;119680]In post #1, it is picture 3. U5 to the right of the circled component. U4 is to the left of it. Both are 6 pins.
                Hi... even though some years back, I wonder about the statement:
                "Both are 6 pins."
                On my board, U5 and U4 are 8 pins.
                I am a bit confused.
                • Sharky-T
                  • Nov 2014
                  "Both are 6 pins."
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #49
                    [QUOTE=Sharky-T;499901]
                    "Both are 6 pins."
                    There are 8 pins on the original picture - probably just a typing error.
                    retiredcaps also posted the datasheets which show 8 pins.
                    Retiredcaps used to help out on here for hours on end and it does go for the eyes. I personally work on a small laptop and can barely tell the difference
                    between the 6 and 8 on my keyboard .
                    Even if it was noticed later, one cannot amend posts after around 1 hour.
                    • Jane
                      How do you test MOSFET in laptops ?
                      by Jane
                      I tried to use this method:
                      Testing an N-channel MOSFET:
                      Step 1: Discharge the Gate (turn off the MOSFET)
                      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                      Step 2: Charge the Gate (turn on the MOSFET)
                      Now, place the red probe on the Gate (G) and the black probe on the
                      09-27-2024, 03:31 AM
                    • Nooy
                      VGA MOSfet permanently shorted and loss of MOSfet pad
                      by Nooy
                      Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                      I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                      02-14-2024, 02:26 AM
                    • redbaron1007
                      Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                      by redbaron1007
                      I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                      Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                      09-09-2025, 11:10 AM
                    • AppleLover123
                      Asus X712EA 3 volts after the first mosfet
                      by AppleLover123
                      Hey guys,
                      i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                      I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                      Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                      I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                      Now i thought something...
                      12-15-2024, 07:49 AM
                    • MicroSMD Lab
                      by MicroSMD Lab
                      I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                      01-10-2024, 06:36 AM
