inverter transformers
+ More Options
Posts
  • johnboy183
    • May 2008
    • 119
    Just a general question re the above. I have now accumulated quite a lot of powerboards and inverters and although its easy to scavenge most items from a board I cant find any logic to transformer numberings or markings ands none of them bring up any kind of datasheet or comaprison chart on Google. Has anyone looked into this to see if there is a comparison chart or a way of identifying output from the markings. I am sure most of the transformers I have are functional and to a large extent look physically similar especially in terms of their number and placing of pins but certainly wouldn't risk a substitution based on that. Any guru advice out there on this would be much appreciated.
    Johnboy183
  • pedro
    • 199
    • AUSTRALIA
    Re: inverter transformers
    Johnboy183
    There are enough differences in the configuration alone (winding arrangement, taps etc) that pulling them off boards for use as spares isn't practical. Also the turns ratio depends on the supply rail voltage to the primary switching transistors.
    I must admit that although some repairers may have found failed inverter transformers, to date I haven't. Usually they are protected from failure by those fast acting semiconductor fuses we call transistors, or by the protection built into the PWM controller.
    Friends don't let friends buy Samsung ....
    • PlainBill
      • Feb 2009
      • 7034
      Johnboy183
      The numbers on inverter transformers are generally some form of house numbers, possibly including a date code of production lot. For example, one Darfon inverter used transformers stamped with the number 4006A508019. Attempting to Google that was fruitless. After some research I found that this model of Darfon inverter had transformers that started with 4006A, followed by 6 additional numbers. And searching on 4006A led me to a source of the transformers.
      To further confuse the issue, transformers with the same form factor were used on a number of Darfon inverters. In most cases, the difference between 4006A and 4009A are the number of turns in the primary or secondary. However, there are eBay sellers that claim all are interchangeable.
      PlainBill
      • x_orange90_x
        Vizio E55-E1 bad backlights or bad inverter?
        by x_orange90_x
        I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
        I don't know how exactly to test the inverter itself. Is it...
        01-29-2025, 09:24 PM
      • Gentian
        APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
        by Gentian
        I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
        It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
        03-06-2023, 07:07 AM
      • Tips
        Inverter 316827000001-R0A transformers
        by Tips
        I have a failed inverter board, 316827000001-R0A from an Acer Aspire Z5700 AIO PC. (I know I am asking this question under TV's and video sources as I believe it is more relevant here than under PC's and I hope that is not an issue)
        The transformers have failed and I am struggling to identify them or find a suitable replacement for them. The only code printed on them is 273001050372 10252. (Please see attached pictures)
        Any advise or suitable compatible replacements would be most welcome, and thank you in advance....
        12-13-2020, 06:15 AM
      • valvashon
        Insignia NS-LCD19-09 (PS OK, Inverter problem?)
        by valvashon
        For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
        History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
        01-04-2024, 01:44 PM
      • eccerr0r
        A modified sine wave inverter + a grid tie inverter?
        by eccerr0r
        If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
        Next thing is trying to charge the batteries using solar power, but that's another issue ...
        08-31-2023, 09:14 PM
