Envision EN7410
  • PincushionMan
    • 22
    Envision EN7410
    I've got a new broken one - 17" Envision EN7410. No camera today, so I'll describe everything. Pictures tomorrow.
    Problem with this one is that it randomly powers down after 5-10 minutes of use. The panel wasn't too difficult to take apart, two screws in the bottom corners and 3 hidden latches per side. Easiest to start at the bottom. Opened with a letter opener and a small cross point screwdriver, but I think I'd recommend a pair of smallish flat screwdrivers. The panel itself says 'Quanta'. To get the power/inverter board out, 6 plugs, 4 under some shiny tape, and 4 screws must be removed from a metal box unit. Flip it over and 4 more screws and removing a sheet of plastic will get the power/inverter board out. The power/inverter board has the text:
    E187621
    JIA HE
    D 94V0 (or 94VO)
    0513
    p/n: AS02B012DC2
    The power/inverter board is populated with CapXon capacitors, 2 of which are swollen and ugly, near a MOSFET, I believe.
    Here's the list of Capacitors (date code C506 so June 2005?)
    C24 470uF 25V KF/105C 10x13mm (near inverter)
    C114 100uF 400V KF/105C
    C320 10uF 50V KF/105C 4x8mm
    C661 470uF 25V KF/105C 10x13mm (swollen)
    C662 ??? has rubber shield over it ??? W-1 CS 8x12mm
    Very close to L660
    C664 470uF 25V KF/105C 10x13mm (swollen)
    I was planning on using either Nichicon HEs or Panasonic FCs, depending on what I have on hand - and what fits. After that, if it still powers off, I'll reflow the transformer points (and there's two on this one, a big one (near the MOSFET) and a little one (near the AC Input).
    Thanks!
  • x_orange90_x
    Vizio E55-E1 bad backlights or bad inverter?
    by x_orange90_x
    I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
    I don't know how exactly to test the inverter itself. Is it...
    01-29-2025, 09:24 PM
  • Gentian
    APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
    by Gentian
    I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
    It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
    03-06-2023, 07:07 AM
  • valvashon
    Insignia NS-LCD19-09 (PS OK, Inverter problem?)
    by valvashon
    For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
    History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
    01-04-2024, 01:44 PM
  • eccerr0r
    A modified sine wave inverter + a grid tie inverter?
    by eccerr0r
    If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
    Next thing is trying to charge the batteries using solar power, but that's another issue ...
    08-31-2023, 09:14 PM
  • caseyjay_48
    Sony KDL-46BX450 Inverter Troubleshoot Logic
    by caseyjay_48
    I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
    I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
    09-23-2022, 08:08 PM
