Re: HP 1955 Monitor Repair Guide
Multimeter was set to diode test mode, so as i understand these was Ohms. All testings performed in the circuit.
Also, I pulled an original Microsoft XBox out of a neighbors bin and it worked the first time then stopped. When I inspected the insides I bumped a capacitor and it moved too easily to make me take a closer look at it. I wiggled it gently and one leg on the capacitor broke. Close inspection revealed so much corrosion around the capacitor pins and that it had been falling off the board. The board itself looks fine so have bought a replacement cap for NZ$9 and hoping the high price will pay off.
So perhaps check the pins on all the capacitors on the board.Leave a comment:
"C5707 all are showing 980 and 620 AND 165 and 1065
FET's are showing around 170 and 990" Are those reading in Ohms, K Ohms, M Ohms?Leave a comment:
Switching the monitor on and then have it not turn on again is like a dieing capacitor symptom, well it is a possible symptom in my short monitor and power supply repairs experience and all my repairs to now have been capacitor replacement and a cracked transformer on a 24 inch all in one PC power board. Perhaps one or more capacitors you replaced with are not good. I bought a tester for testing Capacitance of new replacement capacitors before installing.
So perhaps check the pins on all the capacitors on the board.Last edited by nickBcap; 09-02-2013, 03:31 PM.Leave a comment:
Should be OK as long as they are not fully opened.Leave a comment:
hmm..
FET's are showing around 170 and 990Leave a comment:
Just check all three pairs between, between two legs at a time.
Just digged mine from a hill of stuff and found it's display is scratched. Damn it, I just found a buyer for itLeave a comment:
Hi there,
Received same HP 1955 monitor. Turned it on and it worked. Opened it and replaced Elite caps with new 105C ones. Switched it on and tested. It worked for 1 day till I switched it off. Now - I just doesn't turn on. As it has also bad sleeve connector from menu keys to logic board - i can't identify if it's showing some led activity (first time it switched on w/o menu control pad), and i am not able to see any activity on screen using flashlight (which makes me think that smth is shortened)
As I received information from the previous user of this monitor - that it turned on after some kind of shaking it. (This one is leading to bad soldering joints)
Could you please point me what, and more importantly - how should i check components?
What I have already done:
1. Replaced caps in primary circuit (monitor worked with new caps) - OK
2. Checked 5A Pico fuse PF701 - OK
3. Checked Q805, Q812, 4431 mosfets in the circuit. They are not shortened in Source to Drain. So seems to be OK.
4. Was not able to see any bad joints (searching for magnifying glass)
Have no idea how to check FETs and C5707
Any advices what else should i check :?
I am very new to electric theory, so please be understanding.
Thanks in advance.Leave a comment:
Well actualy problem was that almost all caps were bulged and it stopped powering on, this was just a bonus…Leave a comment:
Oh god. That's very very bad there. I guess you are loosing a lot of power there. Might be the problem then.Leave a comment:
It's very dangerous on the primary side, due to high voltage there may be huge losses on a bad joint. This is one under freewheeling diode in Acer AL2423W:
Cracked solder joints at AC inlet: Example of Dell and HP
http://s807.photobucket.com/user/bud...tml?sort=3&o=7
http://s807.photobucket.com/user/bud...tml?sort=3&o=2
At transistor C5707:
http://s807.photobucket.com/user/bud...tml?sort=3&o=0
At inverter transformer:
http://s807.photobucket.com/user/bud...tml?sort=3&o=8
BenQ made some monitors for ACER, HP, Dell.Leave a comment:
Ah, soldering. Yeah, we are used to check it, at least most people are around I think. BenQ has usually poor board and soldering quality, so do all other BenQ-made displays (like HP).Leave a comment:
No, the soldering at the condensator etc. At the AC it's typical it gets loose but it can happen to any part on the motherboard so check them out carefully. If you havent seen any at the electricity part then check out the computer motherboard.Leave a comment:
You mean grounding screwes or what?Leave a comment:
Guys. Sometimes not the transistors, fet or such is the problem only the "bolting". Happend to me once that the power input bolting (all three) were "lazily" connected and it made my screen go black after 1 sec. I have rebolted it and wunderbar, All working. TRy that first to see if there is any loose bolting.Leave a comment:
The inverter circuits for this chassis uses Royer Oscillator setup, the gray cap is part of the tuning circuits with inverter transformer, if the cap changes it value, the Oscillator frequency will shift which can cause the C5707 to run hot. The B+ feeding the Royer is done by the power transistor that is driven with PWM signal to produce variable DC feeding the Royer Osc, less B+ less brightness, if that power transistor shorted out, the Royer will be running full blast or the time since the PWM Power transistor is not turn off when the monitor is turn off because it is shorted out. New monitor no longer use Royer Oscillator type setup any more. Bad solder joints on the inverter transformer legs are another common failure.Leave a comment:
These 2SC5707, every time two pieces around the gray foil caps in push-pull configuration.
Also there are two 2SJ598, one for every invertor, these turn it on and off. Just posted problem with one of these on page 6. It was also shorted making the invertor stay on all the time (even when display was turned off).Leave a comment:
Thanks for the feedback.
So I'm thinking the inverter transistors are the C5707s and what else?Leave a comment:
Probably typical problem with blown 2SC5707 transistors, blown fuse.
If you'll go to somebody, have him check all the inverter transistors, also the grey capacitors between them.Leave a comment:
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
by Rick_1234Good evening, gentlemen.
I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
https://drive.google.com/file/d/1L6S...ew?usp=sharing
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
by corrizeHello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping... - Loading...
