Sceptre X20WG-1080P not turning on
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sceptre X20WG-1080P not turning on
    Originally posted by cecil61443
    hi again
    its cecil61443 here.
    boy do i have problems. first i did something stupid, i just look at the pictures posted above and saw what i wanted to see. it is the same pc board but, i didn't really check the caps out that closely, or just plain miss read them. i guess i was just to lazy to do it right. so i ordered the parts from the list from above and very little matched. here is my list of caps that my monitor needs:
    1; capxon 1000uf 16v, KF105`c, c719, vent, dia. 7/16 x 7/8 length
    2; capxon 1000uf 16v, KF105`c, c719, vent, " 7/16 x 7/8 "
    3; capxon 1000uf 25v, KF105`c, c724, vent, " 3/8 x 13/16 "
    4; capxon 1000uf 25v, KF105`c, c724, vent, " 3/8 x 13/16 "
    5; CHC 1000uf 25v, +105`c, cd286, " 3/8 x 13/16 "
    6; capxon 470uf 25v, KF105`c, c717, vent, " 3/8 x 5/8 "
    7; capxon 1000uf 25v, KF 105`c, c734, vent, " 3/8 x 13/16 "
    8; CHC 100uf 16v, +105`c, cd268, " 3/16 x 7/16 "
    9; capxon 470uf 25v, KM 105`c, c717, vent, " 5/16 x 9/16 "
    10; capxon 470uf 25v, KM 105`c, c717, vent, " 5/16 x 9/16 "
    11; capxon 470uf 25v, KM 105`c, c717, vent, " 5/16 x 9/16 "
    12; capxon 10uf 25v, KM 105`c, c717, " 1/4 x 1/2 "
    13; capxon 22uf 50v, KM 105`c, c717, " 3/16 x 7/16 "
    Like i said before i am new to all of this !!!!!!!!!! could some one PLEASE help me out!!!!!!
    later
    cecil61443
    First we rationalize the list by combining identical caps and eliminating extraneous information:
    2 ea 1000uf 16v, 7/16 x 7/8 P12366-ND EEU-FM1C102 @ $.59
    4 ea 1000uf 25v, 3/8 x 13/16 P12379-ND EEU-FM1E102 @ $.76
    1 ea 470uf 25v, 3/8 x 5/8 P12389-ND EEU-FM1E471L @ $.43
    3 ea 470uf 25v, 5/16 x 9/16 P12388-ND EEU-FM1E471 @ $.50
    1 ea 100uf 16v 3/16 x 7/16 P11198-ND EEU-FC1C101 @ $.34
    1 ea 22uf 50v 3/16 x 7/16 P12927-ND EEU-FM1H220 @ $.16
    1 ea 10uf 25v 1/4 x 1/2 P11212-ND EEA-FC1E100 @ $.30
    The numbers that begin with P are the Digikey stock numbers; the numbers that begin with EE are the Panasonic part numbers. I suspect the 470 uF caps can all be the same size. All parts are in stock.
    PlainBill
    • Sparklingx
      HP 450 g1 keeps turning on even tho shutdown/sleep
      by Sparklingx
      HP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
      09-23-2024, 12:34 AM
    • khelane
      Satellite PRO A50-A Not turning on after turning off Windows
      by khelane
      Hello
      A device with specifications
      Toshiba Satellite PRO A50-A is here to replace the hard drive.
      The hard drive has been replaced and there is no problem, but there is another problem, but the customer does not care to fix the problem.
      The device enters Windows without any problem and works, even I put pressure on the CPU and graphics, but when I turn off the system through Windows, if I want to turn it on again, the system switches, but it turns off quickly within a second, and this routine continues. It is turning on and off within a second and soon it turns off....
      04-20-2023, 06:28 AM
    • Rabit
      VX3276-2K-mhd-2 Random Turning off
      by Rabit
      Recently staring turning off more often, brightens set at 50% - monitor back side in PSU area is very warm to touch, also at front left corner getting hot.
      When changed brightens set at 30% no longer turning off , and no longer I can feel any heat in this areas.
      This can be signs of bad capacitors causing overheating PSU ?
      06-17-2024, 09:30 AM
    • shakib200
      Dell latitude E7240 not turning on if adapter plugged in
      by shakib200
      Laptop turns on only on battery but if I plugged the adapter with battery, it is not turning on. After turning on the laptop using only battery (no adapter plug in), then plugging the adapter everything works fine also charging ok. Anyone have any clue what’s wrong?...
      03-31-2024, 12:55 PM
    • netgearnetgear
      AIWA 32" TV not turning ON
      by netgearnetgear
      Good day everyone,
      I have a AIWA 32" TV model #
      AW32B4SM that is turning ON with a blank screen. The backlight is working but there is no image on the screen. I did the standard troubleshooting checks: logic board inspection under microscope, reseating ribbons cables, power rail checks, diodes, mosfet checks, power on and measure voltages on coils, caps, vcc, regulator checks all check good. Then I measured the panel voltage (12v present) and noticed that the VONE (approximately 30v) was missing, the AVDD (15v) was only 5v, vcc 3.3v present, vcc 1.8v present. I know when...
      10-03-2025, 06:06 PM
