LG W2442PA LCD monitor flickers when cold
  • Creep-hwbg
    I have a strange problem with LG W2442PA LCD monitor - it is working fine, but if you leave the PC to switch off the monitor into power saving mode and you leave it like that for some 3-4 minutes (enough for the monitor to cool down), and then you wake it up - the monitor will flicker (just like 60Hz on CRT) for 15-20 sec. and then will return back to normal operation. The same can be reproduced if you simply turn off the display by using the on/off switch on the monitor for some 3-4 minutes after it heated up.
    It would never flicker when being used intensively (i.e. if you not let it enter in power saving mode to cool down or turn it off manually for some time and).
    Please advise!
    Thanks in advance for your time spent!
  • Creep-hwbg
    Re: LG W2442PA LCD monitor flickers when cold
    Anybody?
    • etnietering
      • Apr 2009
      • 379
      Well this is just a guess, but it seems to me that the large primary cap is bad. When the monitor is cold, it has a very low capacitance, which is causing the 60Hz mains frequency to interfere with the DC output of the power supply. As it warms up it's capacitance goes back up and then the mains frequency is blocked properly.
      It could easily be something else though....
      Crack it open and take some pictures for us, and then people will be able to help you better.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        is the screen pink or orange till it warms up?
        • Creep-hwbg
          No, there are no other issues except for the flicker...
          • Bobdee
            • Jun 2008
            • 461
            Open it up to get a visible check on caps
            A couple of pictures if possible will help if its not the caps
            • Rick_1234
              by Rick_1234
              Good evening, gentlemen.
              Things I tried
              06-22-2024, 04:44 PM
              by momaka
              03-15-2023, 10:17 PM
            • wattage
              by wattage
              Hello Badcaps Community,
              07-13-2025, 04:41 PM
            • ant3202
              HP 27es - LED monitor - Monitor Flashing On - Off
              by ant3202
              Hi Everyone
              Lately I am experiencing the deja-vu incident on one of the led monitor like this.
              https://www.badcaps.net/forum/troubl...lashing-on-off
              The monitor is HP 27es LED Monitor
              https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
              The monitor will randomly blackout and display no signal and will recover again.
              Sometimes need to power and off again to restore the display but...
              03-20-2025, 07:30 PM
              Wise Wing F199 19'' LCD monitor - recapped
              by momaka
              Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
              I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
              When I saw the Craigslist post, I wasn't...
              08-24-2020, 10:58 AM
