Hp 1740
  • Dew_32
    • Nov 2009
    • 11
    Hp 1740
    I got a scrap HP 1740 monitor and am trying to repair it. I have been reading this post and see allot of the same problems. My monitor lights up for about one sec. then goes dark I can see the display is there but there is no back light. So I order this repair kit and replaced 4 c5707, 2 fu9024n, Pico Fuse, 2 220uf 35v cap, 2 470uf 35v cap. I also re soldered the transformers as suggested in the form. But my monitor is still doing the same thing. Only displays for about one sec then goes black. Is there a way to find out which component is failing?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Hp 1740
    Yes, but it will require a little testing. This is a very interesting circuit; I don't believe I've ever seen it before. The transistors drive both primaries, the secondaries are connected in series.... OK, I've got a handle on it.
    On the top side of the board there is a long jumper that runs between the pairs of transformers. J5 runs between T801 and T802. Another runs between T803 and T804, I can't see the number. Mount the power supply / inverter board in place with all the screws. Use either screw at the bottom of the board (as seen in the picture of the top side) as ground, and measure the voltage at each jumper in the second or so before the screen goes dark. This should be only a couple of volts DC.
    PlainBill
    • Dew_32
      • Nov 2009
      • 11
      Re: Hp 1740
      Here are the readings I got
      starting at the bottom
      J10 .84
      J20 .84
      J5 .72
      J17 1.68
      • sofTest
        • Aug 2008
        • 361
        Re: Hp 1740
        You might want to test the D801 and D803 diodes on the back of the board. I repaired a 1940 a while ago, where one of them was shorted. I also replaced all capacitors. You might have a look in this thread for ideas.
        Be a mensch
        • Dew_32
          • Nov 2009
          • 11
          Re: Hp 1740
          Where can I get those diodes if I find that they are shorted ?
          • Dew_32
            • Nov 2009
            • 11
            Re: Hp 1740
            Ok I pulled both diodes from D801 and D803 and tested them they were both good so I put them back on. I do see dark color on the board above the 4 resistors on the other side would that be my problem? R27-R30, R33-R36
            • sofTest
              • Aug 2008
              • 361
              Re: Hp 1740
              All Benq-boards I've seen had those dark spots.
              You might have other bad capacitors beside the four you have replaced. Personally I've repaired five HP monitors with Benq-boards, and not one of them had so few as four bad electrolytic capacitors. As a minimum, I always replace all capacitors with value 220uF and up. I even saw someone who found one of the capacitors that sits between the c5707s to be bad. Also, what make and series of capacitors did this kit you bought come with?
              Be a mensch
              • Dew_32
                • Nov 2009
                • 11
                Re: Hp 1740
                So are you saying I should replace the four blue cap located at c830,c832,c834,c836.
                But my main question would still be is there a way to test which component is failing and replace that one instead of blindly replacing parts untill I get lucky and make the monitor work again. or then again maybe not?
                • sofTest
                  • Aug 2008
                  • 361
                  Re: Hp 1740
                  To test if a capacitor is defective reliably, you need an ESR-tester. Unless you plan to repair electronics regularly, it doesn't pay to buy one. Just replace all. Also, if some of the capacitors of dubious quality (Elite, Lelon, Jamicon) is starting to fail, the rest probably are in line for failing also. So, unless you like opening up monitor to search for failed components regularly, replace them all.
                  I don't find my notes on the board with the same layout you got, so I can't verify the locations, but my monitor worked after replacing all capacitors with value 220uF and up.
                  Again, what make and series capacitors did you get with the kit?
                  Be a mensch
                  • sofTest
                    • Aug 2008
                    • 361
                    Re: Hp 1740
                    Edit time out, I'm making dinner:
                    No not the four blue ones, the ones I mentioned are the grey film capacitors. Anyway, the other electrolytics are more likely to be bad than the film capacitors.
                    Be a mensch
                    • Dew_32
                      • Nov 2009
                      • 11
                      Re: Hp 1740
                      here is the link from where I got the kit
                      http://www.lcdrepair.us/Kit-HP1940-inverter-power.html
                      The one I took out were all Elite
                      The ones I replaced them with veried the 2 220uf are Chengx, the 2 1000uf are nichican, I can't tell what the 440uf are
                      • sofTest
                        • Aug 2008
                        • 361
                        Re: Hp 1740
                        Hmm, I wouldn't put any Chengx capacitors in a monitor of mine. They are likely to fail within short time. Nichican? Not Nichicon? If, Nichican, not them either. Nichicon maybe, depending on series. If you are in the US, I would have ordered a set of new known good capacitors from the owner of this site, or from DigiKey.
                        Be a mensch
                        • Dew_32
                          • Nov 2009
                          • 11
                          Re: Hp 1740
                          Ok all that being said this may still be a stupid question. If I just replaced all the capacitors that I told you plus the 4 c5707 and the 2 fu9024N shouldn't my monitor be working. which it is not. so I am thinking there is still something else going on there? Granted they might be poor components, but they would last for a while uless something else on the board is knocking them out right away. By the way none of the old cap looked bad had buldging on the top nor do any of the new ones. of course i have no way of testing them.
                          • sofTest
                            • Aug 2008
                            • 361
                            Re: Hp 1740
                            OK, a little capacitor failure tutorial. In addition to when you can see the bulging top/leaking bottom, the capacitor can be shorted or open internally. The most common failure though, is an elevated ESR-value. ESR is a form of resistance in the capacitors. Elevated ESR is so common, that most of us here own an ESR-meter. Even a hobbyist like me. When we replace capacitors, we use low-ESR capacitors with same or better specifications than the original, from a known good manufacturer.
                            Those Chengx you got with the kit, are of unknown specifications, but they are very likely not low-ESR like the originals, witch I'm guessing were Elite ES-series. You might have replaced Elites with elevated ESR-values with capacitors equally high original ESR-values. The Chengx might work as they are manufactured for, but their specification might be to low to work in this specific application.
                            As for something else going on, since you got image, but no backlight, I'm guessing first capacitors (the ones you haven't replaced and the ones you have replaced), second a bad CCFL-lamp. To test the lamps you need another inverter. We usually use an inverter from a PC-case lamp to test the CCFLs.
                            Be a mensch
                            • Dew_32
                              • Nov 2009
                              • 11
                              Re: Hp 1740
                              Yes I already tested with another good inverter from a HP 1703 monitor I use on this computer and the screen works good, backlights stay on. so I guess I should get a good set of capacitor and try repalacing them again.
                              • EGuevarae
                                • Nov 2008
                                • 1336
                                Re: Hp 1740
                                Did you resolder all the transformer solder points, and other suspecting solder points?
                                • ASUS ROG Maximus IX Code
                                • Intel Core i5-7600K 3.8GHz
                                • Windows 10 Pro x64
                                • GeForce GT1050
                                • Dew_32
                                  • Nov 2009
                                  • 11
                                  Re: Hp 1740
                                  Yes I did all the transformer points I read that in other post and tried that already
                                  • Madre
                                    • Jul 2011
                                    Re: Hp 1740
                                    And finally how you resolve the problem???
                                      by momaka
                                      03-15-2023, 10:17 PM
                                    • ant3202
                                      HP 27es - LED monitor - Monitor Flashing On - Off
                                      by ant3202
                                      Hi Everyone
                                      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                      https://www.badcaps.net/forum/troubl...lashing-on-off
                                      The monitor is HP 27es LED Monitor
                                      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                      The monitor will randomly blackout and display no signal and will recover again.
                                      Sometimes need to power and off again to restore the display but...
                                      03-20-2025, 07:30 PM
                                    • Rick_1234
                                      LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                      by Rick_1234
                                      Good evening, gentlemen.
                                      I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                      To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                      https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                      Things I tried
                                      - Bought a new AC adapter thinking that was the problem but the problem...
                                      06-22-2024, 04:44 PM
                                      Wise Wing F199 19'' LCD monitor - recapped
                                      by momaka
                                      Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                      I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                      When I saw the Craigslist post, I wasn't...
                                      08-24-2020, 10:58 AM
                                    • sew333
                                      Pc shutdown, monitor flickered with no signal after 10 seconds
                                      by sew333
                                      My pc:
                                      10850K stock 4800mhz stock Kraken X73 good temps
                                      2x16 GB DDR4 GSKILL 3000mhz XMP
                                      Seasonic Tx-850 Ultra Titanium
                                      Gigabyte Rtx 3090 Gaming OC
                                      Aorus Z490 Pro Gaming
                                      1 TB SSD
                                      4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                      Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                      Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                      Power...
                                      02-22-2022, 10:27 AM
