Find 2sc5707 equivalent
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4289
    • Italy - Milan
    Hi, was repairing a Benq Power supply-inverter, i wanted a cheaper and faster solution than buying c5707 kits on ebay, so i wanted something similar, even with a different and more common package like To220 that fits quite well i have already seen (same step), the c5707 datasheet says : NPN Vce 80v Ic 8A Pd 15W Hfe min 200 max 560, for all apart the hfe i can find equal>bigger value ones like an NTE 377 - NPN 80V 10A 50W but for the hfe i must be equal-over also?
  • Toasty
    • Jul 2007
    • 4171
    Re: Find 2sc5707 equivalent
    Yes, and the speed(s) are critical: on = Td(on), off = Td(off), rise = Tr, fall = Tf.
    Many have tried subs, I don't know of any that succeeded.
    I've seen sources other than eBay selling them dirt cheap in lots of 10, 20, etc. Some online electronic supply shops, IIRC. Google is your friend. lol
    [EDIT: in Google: 2sc5707 -ebay -badcaps ]
    Got 3 hits right off the top at 99 cents each. Less in quantity.
    veritas odium parit
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      thecapking.com sells them for $0.80 a pop.
      http://thecapking.com/sanyoc5707.html
      Don't know about shipping though.
      • PlainBill
        • Feb 2009
        • 7034
        Coreweave sells tehm (on eBay) for $.48 each (quantity 4). Shipping to Italy is $3.99 per order. Get a dozen delivered for under $10.00 US (less than 7 Euros).
        PlainBill
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4289
          • Italy - Milan
          Ok. It's seems difficult to find substitutes also with hfe and speed ok, so probably the only cheap way will be ebay. Bye!
          • dondrusco
            • Apr 2009
            • 89
            We have one e-shop in Slovakia - but I'm not sure, if they are able to send items to Italy.
            http://www.avelmak.sk/index.php?lm=4...&article=30766
            They have lcd parts (inverters, transformers), too. But they have no specification on it
            Even worser - page is in Slovak only.
            I don't know, how fast do you need it, but I will order some parts there next week. I can order it for you, and send it to Italy. Postal fees is 2 EUR.
            You can pay by PayPal, or bank transfer.
            • stng
              • Jul 2006
              • 34
              The replacement for C5707 are D1804 or C5706
              INTEL CORE2DUO E6600 LGA775 + Cooler Master Hyper L3
              Asus P5W DH Deluxe (Wireless edition)
              2Gb Kingston DDR2 800
              Asus Xtreme N7600gs 256Mb Silencer PCI-E
              80Gb WD 7200 SATA + 40Gb Maxtor 7200 x 2 +
              80 Gb Seagate 3.5'' external HDD
              HL-DT-ST DVD rom GDR8163B
              HL-DT-ST DVD Ram GSA-4167B
              20'' Dell FPM LCD
              Cooler Master Centurion 5 + Acbel 450w with Active PFC
              Philips A2.610 5.1 speaker +
              Altec Lensing AHS30
              • Krankshaft
                • Jan 2007
                • 2328
                PlainBill
                I just got 16 from them. Best price I've found so far even beats Newark's 1000+ quantity pricing.
                These transistors aren't easy to sub their characteristics are very important.
                Not to mention their failure can take out the ON/OFF FETs, the fuse, and in worse cases the traces on the PCB around the FETs so if a failure does recur. You may have more damage than you bargained for.
                Lets also not forget getting the cover back on with TO220s would require slicing up the rear cover. Isolating the transistor tab from the grounded back cover is also important. Too much trouble IMO. If the monitor is worth repairing repair it once with the right parts.
                • seanc
                  • Nov 2008
                  • 1319
                  I agree with the eBay route, you can get lots in bulk for a good price.
                  • adigrf
                    How can I find this chip equivalent?
                    by adigrf
                    Hello! I saw on my motherboard DAG77MB18C0 rec C that I have a burn chip and I also found a similar one in good shape but I am having troubles recognizing and finding it online in order to replace it.
                    What I can read is: DN46AP 22cf 1000 and Gemini is telling me it is a MOSFET by On Semiconductor model NVMFD5c466n
                    Do you think this is real ?
                    The laptop is still starting but I dont want to use it until I replace that. Based on the images, do you think I will succed with a profesional electronic technician?
                    06-22-2025, 12:37 AM
                  • trepachka
                    Trying to find an equivalent component Inspiron 7706
                    by trepachka
                    Hello, I have this Inspiron 7706 that is not starting. It flashes 5 white/3 amber combination indicating "Power rail failure".
                    I found this shorted component U6601 on the motherboard with markings "53BC". Accoring to the schematics it's SY6288DAAC-GP.
                    They are available in China which means a 3 week wait.
                    My question is this: is there an equivalent I can get quicker which will do the job? Thanks....
                    11-30-2023, 04:27 AM
                  • Vesko356
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • dragon3x
                    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                    by dragon3x
                    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                    power on.
                    Here are some examples :
                    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                    switching supply area).
                    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                    than 6.3 V.)
                    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                    I replaced capacitors with aluminum-polymer.
                    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                    03-21-2025, 02:46 PM
                  • corrize
                    Where to find a very small fpc connector 0.3mm between 2 pins ?
                    by corrize
                    Hello, I search this connector (oxydated).
                    It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                    I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                    I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                    Do you know how to find this connector please ? What is the exact name for find it ?
                    08-06-2024, 05:25 PM
