Hi, was repairing a Benq Power supply-inverter, i wanted a cheaper and faster solution than buying c5707 kits on ebay, so i wanted something similar, even with a different and more common package like To220 that fits quite well i have already seen (same step), the c5707 datasheet says : NPN Vce 80v Ic 8A Pd 15W Hfe min 200 max 560, for all apart the hfe i can find equal>bigger value ones like an NTE 377 - NPN 80V 10A 50W but for the hfe i must be equal-over also?
Find 2sc5707 equivalent
Re: Find 2sc5707 equivalent
Yes, and the speed(s) are critical: on = Td(on), off = Td(off), rise = Tr, fall = Tf.
Many have tried subs, I don't know of any that succeeded.
I've seen sources other than eBay selling them dirt cheap in lots of 10, 20, etc. Some online electronic supply shops, IIRC. Google is your friend. lol
[EDIT: in Google: 2sc5707 -ebay -badcaps ]
Got 3 hits right off the top at 99 cents each. Less in quantity.Last edited by Toasty; 11-11-2009, 04:50 PM.veritas odium parit -
thecapking.com sells them for $0.80 a pop.
http://thecapking.com/sanyoc5707.html
Don't know about shipping though.Comment
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
We have one e-shop in Slovakia - but I'm not sure, if they are able to send items to Italy.
http://www.avelmak.sk/index.php?lm=4...&article=30766
They have lcd parts (inverters, transformers), too. But they have no specification on it
Even worser - page is in Slovak only.
I don't know, how fast do you need it, but I will order some parts there next week. I can order it for you, and send it to Italy. Postal fees is 2 EUR.
You can pay by PayPal, or bank transfer.Comment
The replacement for C5707 are D1804 or C5706INTEL CORE2DUO E6600 LGA775 + Cooler Master Hyper L3
Asus P5W DH Deluxe (Wireless edition)
2Gb Kingston DDR2 800
Asus Xtreme N7600gs 256Mb Silencer PCI-E
80Gb WD 7200 SATA + 40Gb Maxtor 7200 x 2 +
80 Gb Seagate 3.5'' external HDD
HL-DT-ST DVD rom GDR8163B
HL-DT-ST DVD Ram GSA-4167B
20'' Dell FPM LCD
Cooler Master Centurion 5 + Acbel 450w with Active PFC
Philips A2.610 5.1 speaker +
Altec Lensing AHS30Comment
Originally posted by PlainBillCoreweave sells tehm (on eBay) for $.48 each (quantity 4). Shipping to Italy is $3.99 per order. Get a dozen delivered for under $10.00 US (less than 7 Euros).
PlainBill
These transistors aren't easy to sub their characteristics are very important.
Not to mention their failure can take out the ON/OFF FETs, the fuse, and in worse cases the traces on the PCB around the FETs so if a failure does recur. You may have more damage than you bargained for.
Lets also not forget getting the cover back on with TO220s would require slicing up the rear cover. Isolating the transistor tab from the grounded back cover is also important. Too much trouble IMO. If the monitor is worth repairing repair it once with the right parts.Last edited by Krankshaft; 02-05-2010, 10:01 AM.Elements of the past and the future combining to make something not quite as good as either.Comment
by adigrfHello! I saw on my motherboard DAG77MB18C0 rec C that I have a burn chip and I also found a similar one in good shape but I am having troubles recognizing and finding it online in order to replace it.
What I can read is: DN46AP 22cf 1000 and Gemini is telling me it is a MOSFET by On Semiconductor model NVMFD5c466n
Do you think this is real ?
The laptop is still starting but I dont want to use it until I replace that. Based on the images, do you think I will succed with a profesional electronic technician?
by trepachkaHello, I have this Inspiron 7706 that is not starting. It flashes 5 white/3 amber combination indicating "Power rail failure".
I found this shorted component U6601 on the motherboard with markings "53BC". Accoring to the schematics it's SY6288DAAC-GP.
They are available in China which means a 3 week wait.
My question is this: is there an equivalent I can get quicker which will do the job? Thanks.... -
Channel: BIOS Requests ONLY!
Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
switching supply area).
than 6.3 V.)
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... - Loading...
