NC 6000 black screen after changing motherboard
  • grop
    • Sep 2009
    • 10
    I have a Compaq NC 6000 laptop. The motherboard went bad. Found a used motherboard and put it in. I had to put the old processer and menory into the (new) used board from the old (not working) board. Turned on the computer and the screen is black. Did work before replacing the motherboard! Tried unplugging the 2 connection from the monitor and reconnected. Still nothing!!!
  • Player2
    • Aug 2009
    • 98
    Re: NC 6000 black screen after changing motherboard
    Check the connection to your backlight inverter. Are there multiple plugs / could they be reversed? Do you have access to an external monitor to try it with? Try unplugging the power cord and battery, then pull the CMOS battery. Wait about 10 minutes to make sure the CMOS is cleared, put everything back and try again.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      maybe you got ripped and was sent a toasted board.
      sigpic
      (Insert witty quote here)
      • grop
        • Sep 2009
        • 10
        Got the screen to work. Problem was the cpu was not in tight. I am new at this and learning as I go.
        Next problem is now it started a set up process and it shut down. It now beeps and 2 green lights are Hard Drive and MultiBay drive flashing. I have pulled the battery and disconnect the power. Let it set for a few minutes and pluged and put the battery back in. Still the same thing. Anyone thoughts?
        • grop
          • Sep 2009
          • 10
          NOw the lights have stopped blinking and no beeping sound. All it does now is the power and charge light stays on and they are both green. Nothing on the monitor. ?????????
          • HTR-Informatique
            Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
            by HTR-Informatique
            YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
            I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
            On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
            I also changed the screen because the PC fell and the screen was broken.
            I changed the battery with a new and original battery.
            I also had corrosion/oxidation on the...
            02-09-2025, 06:51 AM
          • Stanley1843
            Motherboard W26361-W84-X-02 - Black Screen
            by Stanley1843
            Hello to everyone.
            My W26361-W84-X-02 motherboard starts but don't show image (no logo screen neither bios). Because, I have two of them I desoldered the bios chip from the no working motherboard and I soldered it to the working motherboard and the motherboard works OK, so the bios firmware isn't the problem. Below I took some measurements from the no working motherboard when is power on. Also, I replaced the RAM and didn't work again (maybe some pins from the RAM slot don't have the right voltage?). I replaced and the bios battery, and I made reset on the bios and again the problem didn't...
            05-23-2024, 03:51 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • DaniK
            Acer Aspire E5-574-52RH - black screen
            by DaniK
            I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
            Laptop came in for a SSD upgrade, took everything apart to install the SSD.
            Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
            Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
            The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
            Symptoms are:
            - random black screen after displaying Acer logo...
            02-21-2024, 06:27 AM
          • Archimedes
            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
            by Archimedes
            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
            Fans are spinning. Blindly could install windows11 and got the device manager...
            07-30-2024, 05:14 PM
