Motherboard W26361-W84-X-02 - Black Screen
  • Stanley1843
    • May 2024
    • 48
    • Swiss
    Hello to everyone.
    My W26361-W84-X-02 motherboard starts but don't show image (no logo screen neither bios). Because, I have two of them I desoldered the bios chip from the no working motherboard and I soldered it to the working motherboard and the motherboard works OK, so the bios firmware isn't the problem. Below I took some measurements from the no working motherboard when is power on. Also, I replaced the RAM and didn't work again (maybe some pins from the RAM slot don't have the right voltage?). I replaced and the bios battery, and I made reset on the bios and again the problem didn't solved.
    Finally I replaced the two leak capacitors where are in the red circle on the below image.
    Do you know what could be the source of the problem or do you know where can I find a schematic?
    Motherboard when is power on:
    RAM decoupling capacitors - 1,84V
    CPU inductors - 1,48V
    Bios flash memory - 3,23V
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    Start by checking cpu socket pins. Also, check in the board´s manual in which slot it needs to have RAM ( or try with one stick in all combinations ) .
    • Stanley1843
      • May 2024
      • 48
      • Swiss
      Hello and thanks for your reply.
      I check the CPU pins and are OK. Also I check all the combinations in the RAM slots and didn't work again. Any idea?
      • rogfanther
        • Jul 2006
        • 458
        • Brazil
        What were the caps that were in it before ( brand, series, capacitance, voltage ) and with what did you replace them ?
        • Stanley1843
          • May 2024
          • 48
          • Swiss
          The original Caps was OST (Brand) 2200uF / 6.3V / 105Celcius and I replace them with Panasonic (Brand) 2200uF / 6.3V / 105Celcius Low ESR (Part Number: EEUFM0J222L).
          • rogfanther
            • Jul 2006
            • 458
            • Brazil
            If some OST´s are bulged, chances are that a lot of the other OST on the board are bad too. Do you have a post car ? Could try replacing all the 820uF or greater OST.
            Is this from a Fujitsu computer ? Also, seems the board doesn´t have a speaker soldered. If you connect on the the front panel pins, and power the board without RAM, does it beep ?
            • Stanley1843
              • May 2024
              • 48
              • Swiss
              First of all many thanks for your time to reply me. What do you mean by "Do you have a post car"?
              This mainboard is from an old PC that controls a CNC laser router.
              It doesn't have a speaker solder on the PCB neither have in the panel. I started without a RAM but doesn't beep and makes the same thing again. Do you know if can I connect a buzzer (how can I find the pins - if it has pins for speaker/buzzer)?
              Do you suggest me to change all the capacitors?
              One thing that I remebered. I had the same motherboard before some years where was working fine and I replaced preventively these two capacitors that I changed at this time and the motherboard made the same exact problem like this one that I am trying to repair now. Back then I have checked all the voltages and I re-program the BIOS and all these movements that I made this time but I couldn't make it to work again. How do you explain this; just from the preventively changing of these two capacitors a working motherboard stop working?
              • rogfanther
                • Jul 2006
                • 458
                • Brazil
                Oops, sorry. I meant a "Post Card", to insert in the pci slot and see bios debug codes.
                Without a buzzer connected, you won´t hear the beeps. Yes, you can connect one, it should be in those pins near the atx connector. The photo doesn´t show if there is something written around them, so maybe you need the manual to see that.
                Can you take a better picture of it? Cannot read the markings on you picture.
                • Stanley1843
                  • May 2024
                  • 48
                  • Swiss
                  Could you suggest me to buy a "Post Card" (part number or brand or link)? I always want to buy one and now I think it is the time.
                  For this motherboard I couldn't find a manual and I found a manual from another model of motherboard where it seems that is the same from what I check in my motherboeard (I don't know if you know a site that I could find it).
                  • rogfanther
                    • Jul 2006
                    • 458
                    • Brazil
                    If the other pins/connections correspond to the way the motherboars was connected to the front buttons, then I believe the buzzer is connected to those yellow points, yes.
                    • Stanley1843
                      • May 2024
                      • 48
                      • Swiss
                      Do you know any trusted "Post Card" (part number or brand or link) to suggest me to buy?
                      • rogfanther
                        • Jul 2006
                        • 458
                        • Brazil
                        Just a couple from Aliexpress, no specific recommendation. They are useful to know if the board is at least a little alive, or if nothing is working.
                        Alsi, please post pictures of your board, both sides.
                        https://www.aliexpress.com/item/1005006053395173.html
                        https://www.aliexpress.com/item/32832307293.html
                        https://www.aliexpress.com/item/1005006338028041.html
                        https://www.aliexpress.com/item/1005006757438677.html
                        • piernov
                          • Jan 2016
                          • 4439
                          • France
                          I would recommend getting one that can be hooked up to LPC bus through TPM header or manual soldering, more modern desktop boards don't have PCI slots and neither do laptops, so all you have left is LPC bus. (if you are lucky enough there's a debug connector but not always)
                          • Stanley1843
                            • May 2024
                            • 48
                            • Swiss
                            Thanks for your reply. You mean something like this?
                            https://vi.aliexpress.com/item/10050...yAdapt=glo2vnm
                            • Stanley1843
                              • May 2024
                              • 48
                              • Swiss
                              Thanks again for your help.
                              • Stanley1843
                                • May 2024
                                • 48
                                • Swiss
                                I received the PCI tester cards from the alliexpress and I attached on the motherboard.
                                The one of them show nothing "--".
                                The second show "0000".
                                The third show "FF".
                                As I saw in a "PC Analyzer Users Guide" pdf that I found on the internet:
                                The "00" means "Code copyng to specific areas is done. Passing control to INT 19h boot loader next.
                                The "FF" means "Flash ROM programming was succesful. Next restarting the system BIOS."
                                Do you know what these codes means?
                                Tests where I have do until now:
                                I have replace the RAM with a same and functional one (from a same second PC that I have).
                                I have replace the CPU with a same and functional one (from a same second PC that I have).
                                I check the CPU socket for bend pins and all are ok.
                                I have replace the BIOS chip with a same and functional one (from a same second PC that I have).
                                I have replace all the caps in the yellow circles with brand new capacitors.
                                I place a buzzer on the motherboard and no beep even when I remove the RAM.
                                I can't understand what is the problem at all.
                                • Stanley1843
                                  • May 2024
                                  • 48
                                  • Swiss
                                  New update:
                                  I check the voltage with oscilloscope on the CPU coils and the CPU don't have the proper voltage. If touch the CPU when the fan spins is slightly hot.
                                  I measure the pulses from the 15,18,19 pins of ISL6565BCRZ (Multi-Phase PWM Controller) and looks OK. Also, these pulses arrive at the pin 3 of each ISL6612ECB-T (Advanced Synchronous Rectified Buck MOSFET Driver) respectively.
                                  The problem in my opinion is at the output pin 1 that drives the high side mosfet. And in three chips ISL6612ECB-T the pulses are weak and seems like a noise.
                                  I checked for shorts but I didn't find anything and I replace the electrolytic caps.
                                  Any idea of what is going on?
                                  https://www.renesas.com/us/en/docume...6613-datasheet
                                  https://rocelec.widen.net/view/pdf/t...=true&u=5oefqw
                                  • Aliencomputres
                                    • Aug 2019
                                    • 218
                                    • România
                                    put a single memory stick in each slot.
                                    • mitchw
                                      HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
                                      by mitchw
                                      Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
                                      After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
                                      After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
                                      I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
                                      04-29-2025, 03:45 PM
                                    • Technodoc
                                      ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                                      by Technodoc
                                      Asus laptop G614JZ-N3012W Rog Strix with i7
                                      Mainboard G634J-PMV-VGT
                                      6050A3441302-MB-A01
                                      2023-02-10
                                      Power button works okay....power light goes on
                                      Red "bottom" leds go on
                                      Charging led works
                                      Fans do not spin, capslock key does nothing, screen stays black
                                      I would like to program the bios again, to rule out a corrupted bios.
                                      However I run into a size error
                                      The bios chip is a Winbond 25R256JVEN
                                      Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                                      02-24-2025, 04:46 AM
                                    • iZakre
                                      HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                      by iZakre
                                      Hello everybody!
                                      To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                      The thing is that I had installed TeamViewer and could log into the computer...
                                      02-19-2023, 02:27 PM
                                    • to5it0
                                      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                      by to5it0
                                      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                      I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                      This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                      I have opened the laptop and identified the main BIOS chip...
                                      10-24-2025, 01:35 AM
                                    • amennone
                                      Acer A315-24p-r2km , black screen. Bios
                                      by amennone
                                      Acer A315-24p-r2km Acer N23C3 snid: 32400005934 s/n NXKDEET00B3240003B3400 Main: IH5JM LA-M611P Rev: 1A
                                      As per the title, the screen remains black. When the power button is pressed, the blue LED lights up, but the screen is black.
                                      With an external monitor and HDMI output, there is no image. I loaded the following bins, same situation: ACER_A315_24P_IH5JM_LA_M611P_REV_1A_2022_08_22_WORKING_BIOS_100% IH5JM120.bin from this address https://www.badcaps.net/forum/troubl...a-m611p-rev-1a With the RT 809F programmer, I can't read the contents of the original XMC 25QU128CH1Q SPI, I get the...
                                      07-31-2025, 04:19 PM
