viewsonic VA912b will not turn on.
+ More Options
Posts
  • Spacedye69
    • Nov 2005
    • 698
    • US
    Re: viewsonic VA912b will not turn on.
    https://www.badcaps.net/forum/showthread.php?t=5992
    Big cap bad. I didn't replace the 22uf, though. Probably should have.
    • EGuevarae
      • Nov 2008
      • 1336
      Originally posted by Toasty
      I want him to come work for me!! He can look and tell what parts are good and bad! I can throw out all this test equipment! He's magic!
      >>I have read alot of posts on here about this particular monitor... <<
      ...and evidently you're not going to pay attention to what they said.
      Replace ALL the caps.
      Toast
      As nice as ever.... I like the part of the magic, Toasty. That was funny. And by the way, if you discard all of your test equipment, I can send you my mailing address so you can dispose of it in my P.O. Box.....
      Doc, better replace all of them in one shot. Listen to the seniors around here......
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • Windows 10 Pro x64
      • GeForce GT1050
      • Toasty
        • Jul 2007
        • 4171
        >>what I did not order was the really big one, I believe the 400v one? cause it was my understanding this one almost never fails and is ok to be left alone?<<
        *sigh*
        >>As nice as ever....<<
        Sometimes even a good cattle prod won't do.
        Pardon me while I go back to smacking my head with this wall...
        veritas odium parit
        • EGuevarae
          • Nov 2008
          • 1336
          *sigh*
          That was not a complaint. You really get to the point, in a funny way.
          • GeForce GT1050
          • bigdoc675
            • May 2009
            • 12
            people ( whom have posted here on this very thread) have said its ok to ignore the big one and just do all of the smaller ones, is this information just from a few months ago faulty info?
            this here is the post i refer to https://www.badcaps.net/forum/showthread.php?t=6740
            I really am confused, if that info in that post is no longer valid and I need to replace the big one as well then Ill buy one and throw it in, but as far as I knew it wasn't necessary.
            • Toasty
              • Jul 2007
              • 4171
              #26
              It's not NECESSARY, but you're already there.
              If it should fail 6 months from now, will you have the time to fix it?
              My point is (again & again), your(my) time has value. For $5 more now, you've replaced all the caps and you won't need to go back and fix that one in the future.
              [ and pay s/h again ]
              Toast
              veritas odium parit
              • PlainBill
                • Feb 2009
                • 7034
                As far as I am concerned, it isn't necessary. We know why the filter caps for the 5V and 12V supplies fail. They are filtering the output of a switching supply operating at 100Khz or above. Their ability to absorb those rapid pulses depends on a low (effective) series resistance. If that increases they start dissipating more heat, leading to increased heat, excess pressure, and a bulging top. At that point it becomes obvious there is a failure.
                Contrast the situation with the main filter cap. It's handling a rectified sine wave at 120 Hz. They've been building caps to handle that for over 50 years.
                Now, it also depends on the application. If you are rebuilding the $150 power supply for a pimped up gaming computer and and you are afraid all your geek friends will laugh if you don't replace the cap with a something kEwL, by all means do so. However, for a 5 year old monitor that is now worth about $50 on Craigslist - nah!
                PlainBill
                • Toasty
                  • Jul 2007
                  • 4171
                  #28
                  >>However, for a 5 year old monitor that is now worth about $50 on Craigslist - nah!<<
                  With that reasoning, why even crack the case at all....? Why spend $10-$15 on parts and your time??
                  If you're going to fix, then FIX it right and completely.
                  If not, kick it to the curb and buy a new one. Then you have 2-5 years to contemplate recapping it...
                  Toast
                  veritas odium parit
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Toast
                    By that logic, while you're replacing the caps in the power supply, shouldn't you also replace the CCFLs? They fail too. And let's not forget the switches on the control panel. They're only good for 100,000 operations or so.
                    PlainBill
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      PlainBill
                      Damn. I lost the count of the switch ops on my Westinghouse units .....
                      • GeForce GT1050
                      • Toasty
                        • Jul 2007
                        • 4171
                        #31
                        >>Damn. I lost the count of the switch ops on my Westinghouse units ....<<
                        I have an abacus I'm not using...., interested??
                        >>...shouldn't you also replace the CCFLs? <<
                        Absolutely!
                        veritas odium parit
                        • EGuevarae
                          • Nov 2008
                          • 1336
                          As long as it does not have bad caps on it, I am!
                          • GeForce GT1050
                          • bigdoc675
                            • May 2009
                            • 12
                            #33
                            how long does it usually take you guys to get your orders from digikey? they shipped out my caps last monday , and just got todays mail and they still havent arrived, starting to get a bit concerned they got lost in the mail.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              I usually specify first class mail and it takes two to three days. My last order was placed on Wednesday, the 16th and shipped less than half an hour later. I received it late on the 18th.
                              PlainBill
                              • bigdoc675
                                • May 2009
                                • 12
                                #35
                                been 8 days now since it shipped and nothing, really starting to get concerned it got lost in the mail, if it dont come by thursday I am going to have to call and see if they can re-ship it
                                • Toasty
                                  • Jul 2007
                                  • 4171
                                  #36
                                  >>I am going to have to call and see if they can re-ship it<<
                                  Why wait? 1st class anywhere in the contiguous states is 4 days MAX.
                                  At least email them.
                                  veritas odium parit
                                  • bigdoc675
                                    • May 2009
                                    • 12
                                    #37
                                    went ahead and gave them a call, they said it definitely should have been here by now but company policy says they must wait 12 days, so if they do not come by Friday they will reship the order.
                                    • bigdoc675
                                      • May 2009
                                      • 12
                                      #38
                                      finally received my replacement shipment today, threw the caps in and it works perfectly, best picture ive gotten from it in ages too, thanks again to everyone here for their help
                                      • EGuevarae
                                        • Nov 2008
                                        • 1336
                                        Congratulations. Another one saved from the landfill ...
                                        • GeForce GT1050
