ViewSonic VG2021m - DAC-12M033 AF
  • pantherts
    • Mar 2009
    • 73
    Hey everyone, so I started repairing this monitor (ViewSonic VG2021m) a while ago and well I'm kicking myself right now because I took off the bad capacitors and didn't write down what they were! I always try to photo the boards extensively or write down the replacement parts for them immediately upon removal of the components. Well, I did some searching and still cannot find the exact capacitors that go on the board. So I'm hoping that someone on here might have this same monitor or a monitor with the same PSU in it and can look at it for me. Here are the details:
    PSU Board: Delta Electronics DAC-12M033 AF Rev. 02A
    Missing Capacitor Locations: C200, CE101, CE102, CE103, CE104, CE108
    I'm hoping that someone can help me to identify these capacitors or at least aid me in figuring out (from an electronic diagnosis standpoint) what they would be. Any takers? Thanks ahead of time everyone!
  • EGuevarae
    • Nov 2008
    • 1336
    Re: ViewSonic VG2021m - DAC-12M033 AF
    Post a picture of the board. Someone might "recognize" it and suggest something.
    There are 10 kind of people in this world: those that understand binary, and those who don't.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • 16gb GSKILL TridentZ RGB DDR4-3200
    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
    • Windows 10 Pro x64
    • GeForce GT1050
      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
    • pantherts
      • Mar 2009
      • 73
      Alright pictures are uploaded. Thanks for reminding me! Warning...these are pretty darn big files. Very high resolution photos.
      VG2021m-1
      VG2021m-2
      VG2021m-3
      VG2021m-4
      • lucky13
        • Aug 2007
        • 412
        OK ,mine is REV. 00A but I think the caps are the same:
        C200 Capxon KF 220uF/25V
        CE101 Capxon KF 220uF/25V
        CE102 Capxon KF 1000uF/25V
        CE103 Capxon KF 1000uF/25V
        CE104 Capxon PW 1000uF/10V (Green body)
        CE108 Capxon KF 220uF/25V
        • Player2
          • Aug 2009
          • 98
          I found a Rev 01A in my box of junk boards. Mine are all the same as what lucky13 listed, with the exception of CE108 which is 330uF @ 25v.
          I hope that helps!
          • lucky13
            • Aug 2007
            • 412
            pantherts,
            If you still have all the original caps in a bag, you can sort them out to see what was on your version for CE108.
            If not, I think 330uF would be better as it has a higher capacitance (assuming the 1st version was under spec for this cap).
            • pantherts
              • Mar 2009
              • 73
              Thank you for the responses! I plan on looking over all of this tonight when I get home. Actually, the cap that is in CE108 I believe I put there so that is not the original cap that came with the board. Sorry for the mess but this was quite a few months ago and I just plain forgot about it. Thanks again. I will let you know how everything works out for it.
              • pantherts
                • Mar 2009
                • 73
                I actually misspoke on this one. In the pic I have a cap in CE104 but I believe I put that there when I was working on this board the first time. I will be removing it and ordering all new caps. I'm hoping that there isn't a huge difference between REV01 and REV02. *Crossing fingers*
                • pantherts
                  • Mar 2009
                  • 73
                  Question for you guys, would it be okay for me to replace the cap at CE104 with a Panaonic FM 1000uf 16V? The original was a Capxon PW 1000uf 10V. Or should I try to match the ripple ratings closer as well as the voltage?
                  • PlainBill
                    • Feb 2009
                    • 7034
                    If it will fit, the Pnasonic FM will work fine.
                    PlainBill
                    • pantherts
                      • Mar 2009
                      • 73
                      Wow!!! That was quick Plain! Thanks for the rapid response time on that one. I have a lot of Panasonic FM's from the last repair job that didn't pan out so I will use those to save me the trouble of ordering more.
                      • lucky13
                        • Aug 2007
                        • 412
                        Get rid of all Crapxon...
                        OK you can leave that 400v one there.
                        • pantherts
                          • Mar 2009
                          • 73
                          Alright I have quite a few caps on the way. Actually have three projects I'm going to be fixing at once here. A PNY 5700 graphics board, a 22inch Chi Mei widescreen monitor and this 21inch ViewSonic monitor. Not a bad deal considering all were free and the total for the parts was $10. Thanks for your assistance on this. If anyone has any questions on this monitor while I have it open for the next week or so please let me know. Thanks everyone!
                          • EGuevarae
                            • Nov 2008
                            • 1336
                            As long as the size is the same (it fits?) and the uf are the same, the V rating (as long as it is bigger) does not affect you. It is the maximum work voltage, not the required one. Just see about the ripple. And about the 220uf/330uf cap,i think it would be safe to use a 330uf.
                            • GeForce GT1050
                            • pantherts
                              • Mar 2009
                              • 73
                              Just wanted to follow up on this posting to close it out. I have successfully completed the entire repair job. All three devices are working beautifully after 20 capacitors in all being replaced on the three items. The ViewSonic monitor's repair went off without a hitch. The Chi Mei 221D repair went perfectly (after getting rid of all those stupid Crapxon caps). By the way, with the 220us/330uf cap question I ended up going with a 330uf. I replaced all caps with new Panasonic FM caps.
                              • mjkirk12
                                • Oct 2009
                                Does anyone have a datasheet or specification for this DAC-12m033AF module from Delta? I am interested in the header pinouts (16 pin header) on this board.
                                My Viewsonic display does not show any obvious capacitor bulging/leaking, but it won't stay powered on for more than 20 seconds. To recover, I have to remove power for a few minutes and then it will repeat this same (stays on for 20 seconds).
                                If I repeatedly power on/off during this 20 second period, sometimes I can make the display stay on for hours. But when it goes into 'sleep' mode it will eventually power off after several hours and won't come back on.
                                • Dorsal1
                                  Just because you can't see obvious bulging of capacitors, does not guarantee that they are all OK. Sounds to me like your monitor is showing the classic signs of capacitors on their way out, I've seen this behavior personally many times.
                                  While we're at it, can someone identify the value of CE107, the small electrolytic cap near the lower middle of the power supply board (Delta DAC-12M033AF) - mine is covered with glue/paint and scraping it off removes the lettering as well. I think that it might be 22uf 50V @105*C, but would like some confirmation if possible. I might as well replace all of the Capxon capacitors while I have the thing apart!
                                  • Dorsal1
                                    Pinout for DAC-12M033 AF
                                    Also, the pinout for the header is printed right on the board!
                                    • Horseman
                                      Originally posted by Dorsal1
                                      ...can someone identify the value of CE107, the small electrolytic cap near the lower middle of the power supply board (Delta DAC-12M033AF) - mine is covered with glue/paint and scraping it off removes the lettering as well. I think that it might be 22uf 50V @105*C, ...
                                      To confirm:
                                      ...On DAC-12M033AF Rev:02A
                                      CE107 = 22uF 50V @ 105C
                                      I know how to read them...I need to know how to order and replace them.
                                      I have the Viewsonic VG2021m that has a "very" dim image. If this was a laptop, I would replace the inverter. Since the inverter seems to be combined with the AC on this monitor, I looked for a replacement board...no luck.
                                      So, I find this thread dealing with repairing the board
                                      Yes, I have a few caps that looks swollen to me...
                                      What is the basic process?
                                      I expect that I'll need a small/precision soldering iron & a good work light. What Solder should I use? Recommendations?
                                      Where can I locate these replacement caps? (RadioShack?)
                                      I'm assuming that Ill need to remove solder from the bottom of the PCB to remove the caps...any helpful tips?
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Originally posted by Horseman
                                        To confirm:
                                        willawake covers most of the issues in the Recapping Faq.
                                        Don't buy caps from Radio Shack. This is not to say they are garbage, it's just that they do not have the performance required for this very tough application. I prefer Digikey, mainly because of their quality parts, low cost and quick shipping. Tip: Specify First Class Mail shipping for quick delivery at low cost.
                                        I STRONGLY recommend replacing ALL electrolytic caps (except the big one). This will typically cost less than $10 for parts and shipping, and you won't have to worry about opening it up again to replace one you've skipped.
                                        As far as which caps to buy, first you must identify the value, voltage, and dimensions of the caps you are going to replace. You can either post the list in this thread and someone will identify proper replacements, of you can do it yourself. A brief procedure is in this thread.
                                        PlainBill
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • keepread
                                          Dell monitor PSU vs Dell laptop PSU
                                          by keepread
                                          Hi there!
                                          Someone gave me their old monitor, it's Dell S2715ht.
                                          The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                          Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                          10-30-2025, 04:45 PM
                                        • wattage
                                          by wattage
                                          Hello Badcaps Community,
                                          07-13-2025, 04:41 PM
                                        • ant3202
                                          HP 27es - LED monitor - Monitor Flashing On - Off
                                          by ant3202
                                          Hi Everyone
                                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                          https://www.badcaps.net/forum/troubl...lashing-on-off
                                          The monitor is HP 27es LED Monitor
                                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                          The monitor will randomly blackout and display no signal and will recover again.
                                          Sometimes need to power and off again to restore the display but...
                                          03-20-2025, 07:30 PM
                                        • Rick_1234
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          Things I tried
                                          06-22-2024, 04:44 PM
