Help required with DEll 2209WA monitor
  • jinu_j
    • Feb 2016
    • 90
    • India
    Hi Folks
    Facing a weird problem with my monitor. I have attached two images. When i switch on the monitor i see image 1 as shown in image 1
    Now if i leave the monitor on for about 15 minutes it becomes proper as shown in image 2 as shown .
    Is this a repairable issue or is the panel dying. I opened up the monitor thinking there were some bad caps causing this issue, but could not find any damaged/leaking caps. The monitor is about 8 years old. Any ideas ?
  • jinu_j
    • Feb 2016
    • 90
    • India
    Re: Help required with DEll 2209WA monitor
    Posting some more pictures of the main boards
    Main Board
    Side board
    I cant see anything burnt or damaged. So what is possibly causing this behaviour.
    • jinu_j
      • Feb 2016
      • 90
      • India
      Adding the image of the TCON Board. Again no damage visible.
      • R_J
        • 9583
        Try reseating the plug connections on the t-con board and see if that helps. You cam also use a heat source like a hair dryer and heat sections of the tcon or main board to see if you can speed up the return to normal picture. The power supply section and the inverter board are not likely the cause of the problem. but the fault could be on the lcd panel board itself (CN2 cable connects to panel board)
        • jinu_j
          • Feb 2016
          • 90
          • India
          Thanks for the response. I tried reseating the plug connection on the TCON board. Also heated the the TCON board using a heat gun, but made no difference. So guess the panel board is failing and that cannot be changed or modified.
            • 31163
            your probem may be caps on the main board - i had a tv do similar shit because of caps around the main chip
            • jinu_j
              • Feb 2016
              • 90
              • India
              Wierd behaviour I put everything back together and now the i have a new set of problems. Now when i on the Monitor, no issues at all just some faint horizontal line, but image is clear and usable. But after about 1 hours of continuous usage the monitor goes back to the old problem and becomes unusable. I switch off the monitor for about 10 minutes and the monitor clears up again.
              Another new problem is a crackling/hissing sound coming from the monitor right hand side. This hissing sound comes only if there is an image on the screen. if the screen is blank then no sound.
              Another problem i have observed is the time taken for the power light to go off once i off the main power switch at the electrical outlet connecting the monitor. It takes alteast 10-15 secs for the power light to go off.
              • jinu_j
                • Feb 2016
                • 90
                • India
                Ok figured out the problem with the hissing/crackling sound. one of the connectors to the backlight is burnt to crisp. so much so that the rubber padding that was holding it is completely burnt. Not sure why this happened.
                See image
                Question i have is can i directly solder the backlight tube terminal to the backlight connector on the PCB ?
                  by momaka
                  03-15-2023, 10:17 PM
                • wattage
                  AOC AG493UCX 49-inch monitor - Firmware request
                  by wattage
                  Hello Badcaps Community,
                  The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                  07-13-2025, 04:41 PM
                • ant3202
                  HP 27es - LED monitor - Monitor Flashing On - Off
                  by ant3202
                  Hi Everyone
                  Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                  https://www.badcaps.net/forum/troubl...lashing-on-off
                  The monitor is HP 27es LED Monitor
                  https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                  The monitor will randomly blackout and display no signal and will recover again.
                  Sometimes need to power and off again to restore the display but...
                  03-20-2025, 07:30 PM
                • Rick_1234
                  LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                  by Rick_1234
                  Good evening, gentlemen.
                  I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                  To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                  https://drive.google.com/file/d/1L6S...ew?usp=sharing
                  Things I tried
                  - Bought a new AC adapter thinking that was the problem but the problem...
                  06-22-2024, 04:44 PM
                  Wise Wing F199 19'' LCD monitor - recapped
                  by momaka
                  Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                  I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                  When I saw the Craigslist post, I wasn't...
                  08-24-2020, 10:58 AM
