Chimei DAC-19M009 Power Supply problems
  • RethoricalCheese
    • Mar 2013
    • 1517
    • Estonia
    #101
    Re: Chimei DAC-19M009 Power Supply problems
    Just saying that removing these IC-s is fairly simple so I had no problem. Only needed to desolder and lift only one side anyway.
    Looking forward for my ebay package now :P Might take around 2 weeks.
    • Amraks
      • Nov 2011
      • 725
      Originally posted by jh20
      edit 2: amraks, if you still want the p605 datasheet, here's it is:
      I was checking if the_boss had it. cause it come up in the searches I done.
      • RethoricalCheese
        • Mar 2013
        • 1517
        • Estonia
        #103
        Anyway, I got mine fixed. Mainboard arrived today and replacing it got the monitor working.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          #104
          Well done Boss -thanks for letting us know - dont suppose you did any
          comparison tests to see if you could spot what was dud on the old board.
          So many fail and we never seem to bottom it
          • RethoricalCheese
            • Mar 2013
            • 1517
            • Estonia
            #105
            Yes, I did not bother testing it. If I have time I could try to test some.
            • Avocado
              • May 2013
              • Spain
              #106
              Hi, first post here.
              Fascinating reading this thread so far that it has prompted me to ask a question:
              I have the same board that has been discussed on here - image attached, but it's one borrowed from another post because I don't have a camera to hand.
              My monitor has no power at all. Replaced the biggest capacitor because it had clearly burst but still no power.
              I then checked the fuse F101 for continuity and got nothing, so clearly blown. However, I then noticed that the little green capacitor next to it (circled in red) has a big black hole in it and requires replacing.
              My question is, what do I replace the green capacitor with? There are no markings on it at all, although it's possible that the blown hole has obscured any previous markings. So at this point I have no idea what size capacitor to buy.
              Cheers,
              Avocado.
              • Rtech
                • Jul 2010
                • 1095
                #107
                Its not a cap But a Power Thermistor,SCK037 is a common one used in Monitors as below :-
                • lexwalker
                  • Feb 2011
                  • 307
                  • Malaysia
                  #108
                  If the main capacitor spoiled then there could be other components there that have failed. Check the MOSFET first especially. Also noticed a number of bulged capacitors there..
                  That's a thermistor, not a capacitor. You can find this very commonly used in SMPS power supplies.
                  • Avocado
                    • May 2013
                    • Spain
                    #109
                    Hi, Thanks Rtech and lexwalker.
                    So this thermistor is a SCK-037.
                    I don't know anything about thermistors. Do I have to get an exact part match or is there a generic thermistor that will suffice?
                    Been looking on eBay for thermistors but nothing comes up with that search string so I'll contact some of the sellers for a bit of advice.
                    lexwalker, the bulging capacitors in the photo are not actually from my board - I borrowed the photo from an earlier posting on this thread because my board is the same type, and well it just seemed easier. I've checked my other capacitors and none are bulged or look anything other than perfect (apart from the main one which I've already replaced).
                    What is a MOSFET and how do I check one?
                    • lexwalker
                      • Feb 2011
                      • 307
                      • Malaysia
                      #110
                      Why not try online electronic stores. Here's an example from RS Components: Passive Components > Variable Resistors > Thermistors >Type S237 NTC thermistor,ICL,1R 170degC. Lots of other examples there also (including other places like Farnell, Digikey, Mouser, etc), just pick the one closest to the original part's specifications.
                      The 3-legged transistor that's on the heatsink near the big main filter/smoothing capacitor. If this part becomes faulty, then it will usually become shorted thus causing the fuse to blow (again).
                      • lewmur
                        • Oct 2013
                        Originally posted by The_Boss
                        Okay, I did some magic which made me realize that mainboard is faulty.
                        I connected a computer PSU and buttonboard with the mainboard. It still had the flickering lights. This shows that LCD PSU had nothing to do with the clicking sound and flickering LED-s.
                        Now the question is - Is the PSU faulty too or just the mainboard?
                        http://www.ebay.com/itm/Main-Board-A...item3cc4b1c6c2 I was planning to buy this if it turns out to be faulty.
                        Now I will trouble Amraks a little so he could test something for me
                        My monitor turns on and shows the "No signal" box as long as the monitor isn't connected. But when I connect by either VGA or DVI cable, the monitor shuts down. Would this indicate that the mainboard is bad and not the PSU?
                        • aresano
                          • Sep 2017
                          • spain
                          #112
                          Sorry if some line is poorly worded since I use a google translator.
                          I am repairing a power board DAC-19M009 Rev02A and wanted to request from the group if
                          I could provide the schematic-diagram of components since a couple of them
                          burst and I can not read the values. If they had the diagram or a link-link where
                          I could download it. Thanks for the help.
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                            03-31-2024, 02:12 PM
                            07-01-2024, 06:34 AM
                          • Francesc V.
                            Problems with a LINEAR power supply
                            by Francesc V.
                            Hi:
                            I bought an ebay kit to assemble a linear power supply. The following one that is explained in this page:
                            https://www.qsl.net/z33t/dc_0-30v_0-3A_eng.html
                            The power supply seems to work, but I have the following problems I would like someone to help me.
                            1. The input must be about 24-26V AC. My idea was to reuse a 30VAC 160VA toroidal transformer. But with this input the output doesn't go from 0-30V......it remains with some mV. And I guess will stress/burn some components. Do you see any possible modification to...
                            09-06-2023, 12:21 AM
                          • CMCM
                            Russound CA4 Power Supply Repair
                            by CMCM
                            Hello Everybody,
                            Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                            Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                            The outputs marked 12v and 20v are all measuring only 1v.
                            The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                            The capacitors physically look clean (no bludgesor leaks) and...
                            07-03-2025, 01:12 PM
