Aoc Lm727
+ More Options
Posts
  • anno
    • Sep 2007
    • 140
    • netherlands
    Aoc Lm727
    I have a AOC 17 inch lcd monitor, model LM727 with a backlight problem.
    the ccfl lamps goes off after an hour. The Green light stays on and if i look on the screen there is still an image visible , but the lights are off.
    I checked all caps with ESR meter, and they were all good. And i resoldered some things in inverter area. But still the same problem
    What can be the problem? Is it overheating? How to find the problem?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Aoc Lm727
    If the monitor is several years old, I would hazard a guess that one or more of the CCFLs are dying. It could also be overheating. If the timing is consistent, try changing the temperature in the room and see if it has an effect. (Or cover the back to trap the heat CAUTIOUSLY.)
    If you had a schematic of the inverter and an oscilloscope, it would be possible to determine WHY the inverter was shutting down. This would go a long way towards fixing the problem.
    PlainBill
    • EGuevarae
      • Nov 2008
      • 1336
      Re: Aoc Lm727
      PlainBill
      I had one of those and one of the lamps were dead. It failed when hot, so PlainBill's suggestion has sense to me.
      There are 10 kind of people in this world: those that understand binary, and those who don't.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • 16gb GSKILL TridentZ RGB DDR4-3200
      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
      • Windows 10 Pro x64
      • GeForce GT1050
        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
      • anno
        • Sep 2007
        • 140
        • netherlands
        Re: Aoc Lm727
        okay. I checked the voltage on the IC in the inverter and when the lamps go off, there is still voltage on vcc pin of IC. i think it is indeed the ccfl lamps too. I try with other ccfl lamps . thanks
        • valvashon
          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
          by valvashon
          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
          01-04-2024, 01:44 PM
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
        • stomanata
          Problem with power inverter emc18aecn1 of washing machine AEG L6FBA674
          by stomanata
          on my previous post with help from this forum i found short circuit GIF5CH60TS-X
          I replace it but again give me error for current over 16A.
          I measure again and found short circuit between #15 and #16 (Cin and GND).
          On PCB i remove R121 to check in which direction is short circuit. But this pin goed
          to big copper piece on back side.
          So i try to measure over every resistor and capacitor
          But i can`t find any short circuit,
          On example circuit of GIF5CH60TS-X is labaled that Cin can goes to GND in some cases:
          1. Through CSF (i don`t know...
          09-15-2024, 02:06 AM
        • Gibon378
          Problem with stopping audio and video for no reason
          by Gibon378
          PC Specs:
          • CPU: Ryzen 5 1600
          • GPU: GTX 1080 Palit JetStream
          • MOBO: ASRock ab350 PRO4
          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
          • PSU: XFX 650W (don't remember what model)
          • OS SSD: ADATA SP920
          • OS: Windows 10 21H2
          Problem description:
          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
          11-19-2022, 09:41 AM
