Help with dead Commodore 1802
  • R_J
    • Jun 2012
    • 9535
    Re: Help with dead Commodore 1802
    I would replace the caps, They are about the only parts that will deteriorate overtime, This is a crude switching circuit and if it doesn't operate properly it won't work.
    I just repaired a monitor power supply that would turn on and off about 10 times before it would stay on. The power supply startup cap was a 22µf/50v. It's capacity checked 21.5µf. However the scope showed about 3~5v of high frequency ripple on it. replaced it and the power supply was working fine.
    C806: c=223nf = 0.22µf. On the schematic it looks like 2.2µf/160v
    • roadrash
      • Oct 2015
      • 490
      • U.K.
      #142
      I ordered the two caps as suggested and they arrived today. However I was shocked at how much smaller they are than the originals. WIll this be OK or should I find some others a similar or nearer size.
      • R_J
        • Jun 2012
        • 9535
        Hold them up to the monitor so I can see them I'm sure they will be fine, With newer technology they can make them smaller as long as the capacity and voltage is correct they will work.
        Check the new 2.2/160v capacitor [C806] on your meter just to see what it displays.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4949
          • New Zealand
          #144
          Optoisolators can degrade over time too, with the LED inside becoming dimmer like any LED does.
          -David VanHorn
          • R_J
            • Jun 2012
            • 9535
            I was talking about THIS ciruit ONLY it was not a ment to be a general comment, This monitors power supply does'nt us an optoisolator. Since the monitor worked befor it was stored, components like transistors, ic's, resistors, normally won't deterorate, but electrolytic capacitors can dry out.
            The crt will degrade over time also.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4949
              • New Zealand
              #146
              Can you point out the Optoisolator in THIS circuit?
              I'm guessing there isn't one, but that wasn't my point. Just figured I'd add the information as it may help someone in the future.
              -David VanHorn
              • R_J
                • Jun 2012
                • 9535
                I made an edit after you quoted me.
                • roadrash
                  • Oct 2015
                  • 490
                  • U.K.
                  #148
                  Ok here is comparison picture. They are about half the original size.
                  • R_J
                    • Jun 2012
                    • 9535
                    They will be fine
                    • roadrash
                      • Oct 2015
                      • 490
                      • U.K.
                      #150
                      They will be fine
                      Ok soldered in and still the monitor is tickimg and lilght bulb is flashing. So no change
                      • roadrash
                        • Oct 2015
                        • 490
                        • U.K.
                        #151
                        Just a thoght and i think STJ mentioned it before, it couldn't be a transformer could it? Running out of things to test now. We could just replace all caps in psu.
                        • R_J
                          • Jun 2012
                          • 9535
                          What is the voltage across C803, If this voltage is too low the circuit won't start
                          Did you check that C806 did measure different with your meter ?
                          • roadrash
                            • Oct 2015
                            • 490
                            • U.K.
                            #153
                            Its fluctuating between 50 & 69v DC.
                            • R_J
                              • Jun 2012
                              • 9535
                              That is likely too low for the power supply to start.
                              • roadrash
                                • Oct 2015
                                • 490
                                • U.K.
                                #155
                                How does this happen or is it a tranformer fault or maybe a regulator?
                                • R_J
                                  • Jun 2012
                                  • 9535
                                  most of the voltage is being dropped by the lamp as soon as the power supply starts the voltage drops even lower so it will never start. It likely needs around 150vdc to operate.
                                  Since you don't have a variac, try adding a second 60watt bulb in parallel with the 60watt bulb you have in place of the resistor you have now. This will provide more dc voltage and it might start but still provide protection
                                  • roadrash
                                    • Oct 2015
                                    • 490
                                    • U.K.
                                    #157
                                    Ok done that and after about 15 secs the bulbs stopped flashing and just iluminated. Voltage at c803 filter cap is now 83v DC. So I guess thats the psu started and running. What was the point behind this? Whas it to establish the psu will run when fault is found?
                                    • R_J
                                      • Jun 2012
                                      • 9535
                                      Did you have any voltage on either of the secondary capacitors, C812 or C814?
                                      You could try disconnecting L806 and see if you get any voltage on C814. This would lighten the load the power supply has to supply and if it is going to work. Or leave L806 connected, and disconnect L805 and place one of your lamps across C812 and see if it lights.
                                      This power supply needs to generate a square wave to drive the regulator ic 801. If there is not enough voltage on C803, the cpapacitors, C807 and C825 do not charge enough to make the circuit start to switch (like a flip flop circuit)
                                      Q805 and Q806 generate the square wave that is applied to ic801 pin2. Then ic801 pin3 switches on and off at about 20khz and produces the 350 volt peek to peek waveform (number 25). at pin 2 of the transformer.
                                      • roadrash
                                        • Oct 2015
                                        • 490
                                        • U.K.
                                        #159
                                        Something weird has happened, because the 83v DC I was getting at the filter cap has now dropped to just 0.5v DC but the two bulbs connected in parallel to where the resistor was are still lit up. I tried removing the extra bulb we added and the other bulb just stays on and not flashing anymore like it used to and the ticking noise has gone as well. Nothing has changed so I don't understand. Last night I really thought we were getting somewhere.
                                        • R_J
                                          • Jun 2012
                                          • 9535
                                          Check if ic801 is shorted, pins 3 to 4
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
                                          • zunasthegreat
                                            Chieftec GPS-450-AA with dead 20N60C3
                                            by zunasthegreat
                                            Hello everyone hope all doing well!
                                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                            09-01-2024, 07:12 PM
                                          • FiguringITout
                                            MSI Raider GE75 - Not posting, probable dead CPU
                                            by FiguringITout
                                            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                            07-25-2024, 07:27 AM
