Testing a transformer
  • stephkre
    • Jul 2009
    • 26
    I have a mag lt1919wdb and it has the problem with it turning off after about 5 seconds. I have checked the caps they are good I am going to replace them anyways. I have two transformers on the inverter side of the board. This is where I need someones help. By the inverter on the same side as all the caps are on there look to be burnt spots. I need help in testing a transformer to see if it is bad and if it is where a good place to buy one. The transformer has seven leads coming off one side and two leads coming off the other side with the capacitor in between them. If someone could tell me in detail so I can make sure transformer is checked right it would help me.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Testing a transformer
    There are three tests possible.
    The first is quick and easy. With the transformers exposed, turn the monitor on in a darkened room. Look for any signs of arcing on the transformers.
    A more tedious test is to check the resistance between each pin of the transformer according to the following pattern. (This is tedious, but will detect an open winding. It will not detect a shorted turn.) Number the pins from 1-9 in any sequence that makes you happy. Check the resistance from pin 1 to pins 2, 3, 4, 5, 6, 7, 8, 9. Now check the resistance from pins 2 to pins 3, 4, 5, 6, 7, 8, 9. Continue with pin 3 to 4, 5, 6, 7, 8, 9; followed by 4 to 5, 6, 7, 8, 9; and so on. Most of the readings will show an open circuit, a few will appear as a dead short. Compare the readings on one transformer to the reading on the other.
    A ring tester, such as the Anatek Blue Ring Tester is the best way to find a transformer with shorted turns.
    PlainBill
    • EGuevarae
      • Nov 2008
      • 1336
      Why do you think the T's are the problem? Just for the burn spots? Why don't you post a picture of the area so one of our seniors can see and suggest accordingly?
      There are 10 kind of people in this world: those that understand binary, and those who don't.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • 16gb GSKILL TridentZ RGB DDR4-3200
      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
      • Windows 10 Pro x64
      • GeForce GT1050
        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
      • stephkre
        • Jul 2009
        • 26
        Ok. I'm sorry I was going to post pictures but I was not where the monitor was when I posted this. Here is the deal I have a burnt spot as shown in the photos. Also, I forgot to mention it looks as if the screen is not as bright as my other monitor. I am hooking my the broken monitor to my laptop and using them together and I can see that the broken monitor is darker even when it has its brightness all the way up. Therefore my other question is could the tubes be a problem. The hole screen is darker not just in one area.
        • PlainBill
          • Feb 2009
          • 7034
          Take a look at the bottom of the board at that point. Two will get you one that there is a power FET (probably in an 8 pin smd package) on the bottom of the board. It is overheating because the caps for the inverter are bad - notice the bulging tops.
          What is the capacitance, voltage, and brands of the caps on this board?
          PlainBill
          • EGuevarae
            • Nov 2008
            • 1336
            PlainBill
            I agree with PlainBill. The first step is to get good caps in there. That's why pictures are requested. Post the cap's specs and in no time replacements would be suggested.
            • GeForce GT1050
            • stephkre
              • Jul 2009
              • 26
              Ok I know what yall are talking about. The reason I ruled that out is because I took the caps off the board and did the resistance test on them and they climbed to infinite resistance or 0L on my meter. I said I was going to replace them anyways I am just waiting on parts. Ill let yall know in a week. Would that cause a dimmer screen. The caps are xunda 220uF 25V 105degs which you see in the pictures. 4 680uF 25V suscon, 1 more xunda 220uF 25V 105degs, 2 470uF 25V xunda 105degs. and a 10uF 25V 105deg. If yall want to give me anymore info on monitors or boards or testing in general I would love it. I am studing electrical and computer engineering and this is my side hobby I just picked up. Thank Yall.
              • EGuevarae
                • Nov 2008
                • 1336
                That's not a reliable test. Besides, if they are bulging, they are bad, and bad caps can lead to weird things : no power at all, failing inverters, overheating, shorting, etc.
                Your dim screen might be the lamps, might be the caps, the FETs, the transformers, an act of God, bad luck, etc. - you just have to start from the basic (it sounds obvious, but sometimes, we don't do it).
                Bulged caps? change them.
                Then recheck those FETs, looking the datasheet and seeing S-G-D readings. Varying voltage input to FETs from failing PSU (from caps) can behave erratically.
                • GeForce GT1050
                • stephkre
                  • Jul 2009
                  • 26
                  Ok I have a question how much would it affect things if I put a cap with 85deg rating compared to what was in there a 105deg for the time being till my new ones come in. Also how do I test a transistor I have no info on it all it says on the fet is 3055 and 6j is there any documentation you can point me to. Where would be a good and not to expensive place to get parts that has low shipping. thank you
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Quick and simple - don't do it. Most of the caps on this board are low ESR caps. Using standard caps will probably work for the short term, but in a critical application it's a bad idea to take the chance.
                    The 'sticky' threads at the top of the forum have lists of known good and known bad cap manufacturers. Guess which list these caps are on. My recommendation in cases like this is to order replacements for all caps (even those which look perfect). I prefer to use Panasonic FC series from Digi-Key. The caps should coat about $10 (total), Digi-Key has an option of shipping the order by First Class mail which would give delivery in 2-3 days for about $2.00.
                    Even though the second monitor is working well, you might want to order enough caps to repair both monitors.
                    PlainBill
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      PlainBill
                      I agree.
                      Preemptive action.
                      And practice.
                      And savings (more caps, less cost per unit & shipping).
                      And as of teh 85c caps, it is a bad idea. Not taking into account ESR, if you see how much "space" and "air circulation" those caps have, besides being close to FETs and transistors and other sources of heat, it is not a good idea. They will work (maybe, depending on the difference between the original and the replacement caps specs) but will die a quick, hot and painful dead
                      • GeForce GT1050
                      • stephkre
                        • Jul 2009
                        • 26
                        How am I suppose to know the esr on my caps. I dont have a meter and I couldnt really find it on the internet.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          With the exception of the large (100 Β΅f, 450V) cap and possibly one other, all should be low ESR types.
                          Again, refer to the 'stickies' (or post side views of a couple of the caps). They will tell you how to decode the numbers on the caps. Basically, you have to locate the series identifier (usually two or three letters, probably preceding the temperature rating), and check the manufacturer's web site.
                          Note that many of the caps with 'exotic' names (Luxon, Chhsi, CapXon) probably didn't meet specs when the left the factory and they didn't improve by cooking inside a hot monitor for a few years.
                          If you are determined to repair monitors, motherboards, or power supplies professionally, an ESR meter is a must. If you are doing it as a hobby, do what I did at first - replace 'em all. Certain brands I replace even though the ESR meter swears they are good.
                          PlainBill
                          • EGuevarae
                            • Nov 2008
                            • 1336
                            PlainBill
                            See it this way :
                            If bulged -> Change it
                            If known Bad brand/series -> change it (even if it looks and IS OK)
                            The best way would be to get an ESR meter, test them and change the bad ones. But if this is either a hobby, just an attempt to repair your own unit, or you'll be doing it non-professionally, just replace them all. We are not talking of hundreds here (not even dozens in most cases...).
                            If you post the brand, capacitance, voltage rating and if possible series, replacement parts would be suggested.
                            • GeForce GT1050
                            • stephkre
                              • Jul 2009
                              • 26
                              Ok so I got my caps in today and I replaced them all on the board with the same kind but panasonics. However, the problem still persist. Now the monitor seems to stay on for less time. I was wondering how to test those transistors on the other side of the board. Do I have to take it of the board and what do I do. The transistors are sitting right below the burnt marks. I was also wondering if it doesnt cost much I might as well replace them but I dont know what size or anything all it says on the transistor is 550E 6J the board says 200-000-170DTLBMH and PI190DTLBMH. I still would like to test the old ones though.
                              Thank You.
                              • Bobdee
                                • Jun 2008
                                • 461
                                Thank You.
                                cant find a datasheet for those transistors
                                suggest that you set your meter on diode check (2K) and measure between pins, 1+2 1+3 2+3 then reverse probes on both transistors,
                                the readings off the first transistor should be the same as the second transistor or very close,
                                if you find that they are the same, then both transistors are working,
                                if diffrent then the bad one will show a short (probably)
                                the reason being,
                                they are mirrored parts, so one or both must be working for you to have the 2sec image
                                bob
                                can you post pics of both sides of the full board this will help
                                • stephkre
                                  • Jul 2009
                                  • 26
                                  Ill post pics of the transistors tomorrow I am currently not by the monitor right now. I was wondering do I have to take the transistors off the board when I am testing them. Something else I rememober is that the middle leg is not attached to the board.
                                  Thank you for the info. If anyone else can help with identifing the transistors I would be happy.
                                  Thank you.
                                  • EGuevarae
                                    • Nov 2008
                                    • 1336
                                    Middle leg is the same as the back of the transistor. It is connected, only in a different way than the other two.
                                    • GeForce GT1050
                                    • Bobdee
                                      • Jun 2008
                                      • 461
                                      Thank you.
                                      No need to remove transistors from board to test (they may be mosfets but test same way as I described)
                                      The middle leg cut off makes no difference, just use stump (the backplate can be measured as middle leg as they have continuity but best use stump)
                                      The first board number that you gave (200-000-170DTLBMH) is the one to search with, you will find that this PSU/Inverter board is used in several monitors and LCD TVs when you Google (that can be great help sometimes when searching for info)
                                      Havent had any luck yet finding datasheet, will keep looking
                                      Get the pics up of board, both sides of full board and close ups of Inverter transistors so that we can see if any Logos
                                      bob
                                      • stephkre
                                        • Jul 2009
                                        • 26
                                        Here is the pictures of the other side of the board where the transistors are.
                                        • ttmi100x
                                          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                          by ttmi100x
                                          Greetings everyone,
                                          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                          Upon closer inspection...
                                          07-31-2024, 06:36 PM
                                          KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                          by momaka
                                          For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                          http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                          I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful β€œspaghetti cables”.
                                          What mostly drew me into buying it is its 2x PCI-E power connectors...
                                          03-29-2022, 11:34 PM
                                        • triplefour
                                          Emerson LF501EM6F has 21v and 13v but no vled+27v
                                          by triplefour
                                          SO i learned some things about these emerson power supplies from this thread: https://www.badcaps.net/forum/showthread.php?t=65611
                                          where i was able to successfully get the power supply to power up and turn on the backlights, proving that i only had a main board issue. the customer was happy with the result, so he referred me to his neighbor who happens to have a very similar TV but the bigger model.
                                          his issue is different though. when i opened up the set i noticed right away that there was a rather large gecko who had found his way in there and died on the PSU.
                                          looks...
                                          02-18-2023, 03:49 AM
                                        • bauto601
                                          KDM 480W PSU upgrade succes! (opinions?)
                                          by bauto601
                                          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                          A "nice" YoungYear unit? - Badcaps
                                          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                          12-26-2023, 03:05 PM
                                        • dennis_elx33
                                          3PHASE STEP-DOWN Transformer in Check
                                          by dennis_elx33
                                          Hello All,
                                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                          Problem statement: Power tripped Off
                                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                          Action Done:
                                          1) Replaced the faulty parts with good spare.
                                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                          12-02-2024, 06:52 AM
