Apple 27" Cinema Display (A1316) has trouble turning backlight on
  • iuliantv
    • Aug 2009
    • 35
    • Romania
    Re: Apple 27" Cinema Display (A1316) has trouble turning backlight on
    in the link above he also says in that post that, to connect only to 2 ends of some 3v resistors, that the third channel is not used, which is a mistake, because the inverter has 3 channels, 3 bars that go up to about 80v when pwm is forced to a maximum of 3 volts, why do I say that? today I struggled again and I managed to turn on the monitor only if I connected the third contact, I think it had a faulty channel or part of the LEDs to say that it was in error, finally I solved the problem without leaving that change, I had imperfect contacts inside the display, at the connectors of the led strips, I had to undo my eyes, working until about 30 minutes ago
    what he was saying
    ,, The led driver is a three channel pwm controller and the board contains all components for three channels and the connector is prepared for three channel but channel three is not used! So don't put 3.3 on R1133! In this case the led driver detects an error and switch off. The led cinema display has only two led stripes! Therefore connect only R1135 and R1132 with 3.3 volts.
    thank you
    https://i.postimg.cc/J7NYnvdY/P-2020...4-v-HDR-On.jpg
    https://i.postimg.cc/bNL60bPQ/P-2020...4-v-HDR-On.jpg
    https://i.postimg.cc/CxQmXgz5/P-2020...5-v-HDR-On.jpg
    https://i.postimg.cc/0yQVVQ5h/P-2020...7-v-HDR-On.jpg
    https://i.postimg.cc/HsTZ7zqY/s-l1600.jpg
    • avneeshshrotria
      • Oct 2019
      • 24
      • India
      Guys I'm still unable to source a picture for the thunderbolt power supply. Would really appreciate if someone could help with images . Thanks
      • Misterkeeks
        • Nov 2013
        • 74
        • America
        See attached.
        • avneeshshrotria
          • Oct 2019
          • 24
          • India
          Hey misterkeeks, amazing picture dude... thanks a lot for it ! Exactly what I needed . Now I need to order all of the resistors and figure out the Oscillator pin caps the two white ones in your picture either-side of resistor 93b. If you have any ideas do let me know. But anyway thanks again for the image
          • howardc64
            • Jun 2017
            • 632
            I've fixed about 5-6 of these (27 iMac, Thunderbolt/Cinema Displays) by just resoldering the LED bar connectors. Old lead free solder joint probably weakened from thermal cycling. Here is the write up. See the last few pages for the actual LED bar connector that need solder touch up.
            https://drive.google.com/file/d/13Gq...ew?usp=sharing
            • slimmy182
              • Apr 2021
              • 117
              • italy
              #26
              Originally posted by Misterkeeks
              Do you still want this info? Let me know and I will look. Send me a PM or I will likely not see your post.
              Can you please help me figure out this cap value? C308
              • roxboy1984
                Apple cinema display A1316 takes forever to turn on!
                by roxboy1984
                Please could someone help or advise. I have an Apple Cinema Display A1316 and it all of a sudden is taking a really long time to come on. I assume it's probably a capacitor related issue on the power board, I'm just wondering if anyone has experienced something similar and if these monitors are easy and or worth trying to get repaired. Thanks in advance for the help.
                12-12-2022, 01:14 PM
              • a_p3rson
                Apple Watch Charging Controller Schematics / Boardview - 820-02601
                by a_p3rson
                Hi there,
                I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                This daughterboard uses an interesting...
                04-21-2025, 11:41 PM
              • mikiotty
                Apple Cinema Display 23" A1082 turning on but no image
                by mikiotty
                Hi everyone!
                A friend of mine gave me an Apple Cinema Display 23" A1082, the aluminum one from late 2005.
                The display turns on, as I can see the backlight increase or decrease following the input from the controls.
                The computer sees the monitor, and supposedly sends signal to it, but all I can see is a black screen.
                Ideas?
                04-16-2020, 04:09 AM
                HP ProDesk 600 G5 + Apple AirPods ProDesk 600 i7-9700 Specification for Upgrade or Repair
                This specification for the HP ProDesk 600 G5 + Apple AirPods can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Apple AirPods boardview and ProDesk 600 G5 + Apple AirPods schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                09-12-2024, 02:30 PM
                HP EliteBook x360 1030 G4 + Apple AirPods Pro Hybrid (2-in-1) Specification for Upgrade or Repair
                This specification for the HP EliteBook x360 1030 G4 + Apple AirPods Pro Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Apple AirPods Pro boardview and 1030 G4 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                09-06-2024, 07:50 PM
