Gateway LCD monitor FPD2275W bad capacitor
  • DJCarbine
    • Jun 2009
    • 6
    Sorry for a lack of pictures, but I just got it back together and really don't feel like taking it back apart to snap a few photographs
    The monitor is an LCD FPD2275W made by gateway. The invertor board and main power supply is seperate from the video board. The monitor would turn on, fully functional, and the backlight would fail within a few seconds. This was an office monitor, and I was tasked with purchasing a replacement, which I did. Instead of throwing away the old monitor, I was allowed to keep it.
    Basically there was a bad 1000uF capacitor on the invertor board, and apparently this is a common issue with this monitor. The top of the cap had burst and it was leaking. I am typing this post on the newly repaired monitor.
    Its amazing how such a relatively cheap part can turn a perfectly good monitor into an expensive paperweight.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Gateway LCD monitor FPD2275W bad capacitor
    did you recap it? be sure to replace all caps of bad brands.
    yes, a bad cap will do that to a monitor
    sigpic
    (Insert witty quote here)
    • DJCarbine
      • Jun 2009
      • 6
      I only replaced the single failing capacitor. I have yet to get a stockpile of good capacitors, so for now its just replace whats broken, not replace what will be broken lol
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
        by momaka
        03-15-2023, 10:17 PM
      • tony359
        Bipolar capacitor for vintage Apple CRT monitor
        by tony359
        Good day all,
        I have a question about some old monochrome Apple monitors.
        Inside those monitors there is one bipolar capacitor. From the schematics I have it's part of the horizontal linearity circuit.
        A friend replaced a bipolar 4.7uF 25V capacitor with a Nichicon bipolar 4.7uF 25V. The cap popped after about one hour. The new capacitor was much smaller than the original one but that's not a surprise as the original one was from 1980. (I am not sure whether the original was was actually 4uF and was replaced with a 4.7uF?)
        The new capacitor:...
        08-12-2024, 03:27 AM
      • wattage
        by wattage
        Hello Badcaps Community,
        07-13-2025, 04:41 PM
      • ant3202
        HP 27es - LED monitor - Monitor Flashing On - Off
        by ant3202
        Hi Everyone
        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
        https://www.badcaps.net/forum/troubl...lashing-on-off
        The monitor is HP 27es LED Monitor
        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
        The monitor will randomly blackout and display no signal and will recover again.
        Sometimes need to power and off again to restore the display but...
        03-20-2025, 07:30 PM
