HP f1903 problem.
    HP f1903 problem.
    This monitor keeps eating C5907s on one side of the inverter. I've replaced the caps on the inverter and resoldered the plugs. There was a bulged cap on the video board but another tech lost it. I replaced it with 1000uf at 25v but I think its too big. Anyone know what the cap should be on the video board or why else one side of ICs would burn.
    Re: HP f1903 problem.
    The most likely cause would be a short. It could be as elusive as a shorted turn on the transformer, or a shorted (or open) cap or transistor.
    PlainBill
      I dug through it more, it seems like a short. I think it not worth messing with anymore. I think the transformer is shorted on that side.
        Exchange the transformers with each other just to make sure.
        There are 10 kind of people in this world: those that understand binary, and those who don't.
        • ASUS ROG Maximus IX Code
        • Intel Core i5-7600K 3.8GHz
        • 16gb GSKILL TridentZ RGB DDR4-3200
        • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
        • Windows 10 Pro x64
        • GeForce GT1050
          2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
          And if it IS a bad transformer, check to see if someone here has one available.
          PlainBill
            I don't want to lose more C5907s. One of them was arcing. I got this thing on a couple of times and I thought I fixed it. I put it in the case and it stopped turning on. I think when you put the screen in the metal housing it shorts or moves something. Either way I've done WAAAY too much work for $50.
              That changes the approach. Save it for parts, for future use of the lamps, screen or something else.
              • GeForce GT1050
