Samsung Syncmaster 225BW
  • GR3Y5H3ART
    • Jan 2011
    • 146
    #301
    Re: Samsung Syncmaster 225BW
    if anyone can help me with possibly having to replace the CCFL Bulbs after replacing all Caps on Two of Three boards:
    https://www.badcaps.net/forum/showthread.php?t=13086
    • typhonus
      • Jan 2011
      #302
      Excuse me if this has been posted before but here is the service manual for the Samsung 225BW monitor
      • Zolton
        • Jan 2009
        #303
        Wow! It's been along time since I replaced my caps! it's good to see so many have found this thread. My 225BW is no longer functioning properly. The buttons quit working and the picture has a pinkish hue, Any suggestions?
        Cheers
        • retiredcaps
          • Apr 2010
          • 9271
          #304
          A pinkish hue suggests your ccfls are dying. As the ccfl age, they draw more power which causes the inverter chip to shut down the backlight.
          --- begin sig file ---
          --- end sig file ---
          • EGuevarae
            • Nov 2008
            • 1336
            Cheers
            Buttons, I dunno.
            Pink hue/flicker = one (or more) of your lamps are dying.
            There are 10 kind of people in this world: those that understand binary, and those who don't.
            • ASUS ROG Maximus IX Code
            • Intel Core i5-7600K 3.8GHz
            • 16gb GSKILL TridentZ RGB DDR4-3200
            • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
            • Windows 10 Pro x64
            • GeForce GT1050
              2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
            • Jonny_B
              • Feb 2011
              #306
              I have the 1, 2, 2 version of the board. Can someone point me to which post contains the best recommendation of part numbers from digi-key or another vendor to purchase replacements? I found a recommendation for the 2, 3 configuration, but since the there are two 10mm dia caps close together on my revision I'm not sure if the 12.5mm dia replacements will fit properly. Thanks.
              Also, may I suggest editing the first post of this rather long thread with a summary of information contained within?
              • retiredcaps
                • Apr 2010
                • 9271
                #307
                It is always best to record the uF, voltage, height and diameter of your own caps on the board. It is not uncommon for manufacturers to make revisions on the board and keep the same model number.
                Forum members like Panasonic FR or FM series caps. If neither of these 2 are available or out of stock, then go with Panasonic FC.
                This forum doesn't allow editing of threads once it is more than 30 minutes old.
                • DarkNite
                  • Sep 2010
                  #308
                  Sure thing! I went with this setup.
                  Rethinking the "Why?" chromosome.
                  • flinxz
                    • Jan 2011
                    #309
                    Hello, I have the 225BW and have the problem many of you did, the screen only comes up for half of a second and goes dark. Leading up to this problem I had a day or two of the screen flickering. I opened up the back and found at least 2 of the caps to be bad (brown popped tops) so I ordered these (from Digi-Key):
                    P10272-ND
                    CAP 330UF 25V Elect FC Radial
                    565-1800-ND
                    CAP 820UF 25v Elect LXY RAD
                    P10277-ND
                    CAP 680UF 25V Elect FC Radial
                    P10321-ND
                    CAP 47UF 50V Elect FC Radial
                    and replaced all 6 of the smaller caps. When I tried the monitor I found that the problem (only coming on for half a second) is still there. I have double checked the polarity and they are all the correct direction.
                    Can anyone give me suggestions as to my possible problem? I am a novice with a solder iron, but my solder job looks pretty good. I used the solder that came with the iron, is it possible that that was not the best to use for this kind of repair?
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      P10272-ND
                      565-1800-ND
                      P10277-ND
                      P10321-ND
                      Not only the popped caps can be bad.Did you replace them all?
                      As for the polarity, you will know when you install one backwards,because of the "pop" you will notice when it EXPLODES.
                      Post more information (what caps were replaced,and with what,and if there are any unreplaced caps).You must rule that out before moving to something else.
                      • GeForce GT1050
                      • flinxz
                        • Jan 2011
                        #311
                        The only one not replaced was the giant one.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #312
                          1) Post clear focused pictures of your boards using manage attachments and please do not post inline.
                          2) If you hookup a working computer displaying your favourite wallpaper, do you see it for 1/2 second before the backlight goes out?
                          3) Do you have a multimeter?
                          • EGuevarae
                            • Nov 2008
                            • 1336
                            • GeForce GT1050
                            • GR3Y5H3ART
                              • Jan 2011
                              • 146
                              #314
                              P10272-ND
                              565-1800-ND
                              P10277-ND
                              P10321-ND
                              i'm having the same problem and looking into it being the CCFL Bulbs
                              the Monitor itself isn't too bad to take apart theres a set on top and bottom coming from the Pink/White, Black,Blue x2 connectors
                              Bulbs are really expensive, $30 for a set of four from:
                              http://www.ccflwarehouse.com/ccfllamps.html
                              they do have a 1 year warranty which is nice
                              the other option i found is from China for $13/shiped being the cheapest but still debating whether i want to go the cheaper route since this is most likely the cause
                              hope this helps:
                              and if you need the inks for anything, PM me and good luck to you
                              • captain150
                                • Feb 2011
                                • 12
                                #315
                                I'm having the same problem (when cold, blinks off after a second. Does it several times, then stays on) with a 216BW Samsung but the board is labelled 223BW.
                                Anyhow there are;
                                3xSamwha XC V8A, 820uF, 25v, 20mm high, 10mm diam, 5mm lead spacing that are bulging.
                                2xSamwha 820uF (same as above) that aren't bulging.
                                1x330uF, 25v, Samwha XC, 14mm high (can be higher), 10mm diam, 5mm lead spacing that isn't bulging.
                                1xSam Young 2.2uF that isn't bulging. I figure I can leave this one alone.
                                I figure I should replace all the Samwha caps. I went to digi-key to look up replacements, but I'm having trouble finding replacements that will fit electrically and physically.
                                If someone could help with finding replacements, I'd really appreciate it. Sorry if this has been answered before.
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Anyhow there are;
                                  For the 5 ea 820uF x 25V, Digikey has P14423-ND EEU-FR1E821 available but only 29 pieces.
                                  For the 330uF, 25V use P12386-ND EEU-FM1E331. Plenty of those on hand.
                                  The Sam Young is a 'replace on sight' for several reasons. The manufacturer is a known 'garbage caps' source, caps that small will fail with no physical sign, and it is a critical component. If that cap dies, your monitor is dead.
                                  Use P10313-ND EEU-FC1H2R2 for those.
                                  PlainBill
                                  • Scenic
                                    o.O
                                    • Sep 2007
                                    • 2642
                                    5x P14423-ND (Panasonic FR 25V 820uF 10x20mm)
                                    1x P12386-ND (Panasonic FM 25V 330uF 10x12.5mm)
                                    that's what i would choose.
                                    maybe even 1000uF instead of 820uF and 470uF instead of 330uF.
                                    edit: damn.. plainbill beat me to it
                                    lol.. also with the same caps
                                    PS: dont forget about the small 50V 47uF startup cap.
                                    digikey: 493-1896-ND
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      And the winner on complteness is Scenic!!!
                                      PlainBill
                                      • EGuevarae
                                        • Nov 2008
                                        • 1336
                                        I've done that when 820 are not at hand. Only 1 or 2,not five.No problems so far.
                                        • GeForce GT1050
                                        • captain150
                                          • Feb 2011
                                          • 12
                                          #320
                                          Wow thanks for the quick replies guys. The 47uF one has some white goop on top so I overlooked it.
                                          So 6 samwha replacements, 2 Samyoung replacements.
                                          This monitor is just out of its 3 year warranty, it'd be nice if Samsung just used decent caps. I'll order the stuff and let you know how it goes.
                                          Thanks again.
                                            09-07-2024, 05:50 AM
                                          • soopacrucial
                                            Samsung Syncmaster 740BF repair
                                            by soopacrucial
                                            Hi folks,
                                            I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
                                            Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
                                            10-29-2024, 02:40 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
