Samsung 225BW & 226BW CCFL Bulbs?
  • GR3Y5H3ART
    • Jan 2011
    • 146
    so i have fixed one 225BW by using the Screen from a 226BW i bought
    i ordered the 6 Main caps that have been known problems and have gone through both 225BW & 226BW posts many times to see if it might be something else
    the only thing i haven't done is check the fuse (green) but leaning towards it being the CCFL bulbs
    my question is there anything i can do before ordering them because they are pretty expensive at $29.99 with 1 year warranty or the cheapest i've found is from China at $13.00/shipped but not sure if i should go for the cheaper version
    also, are there any precautions to look out for when installing them, removing cover, etc.
    here's a few pics and thanks again for all the help:
    1st Left is Samsung 225BW with the 226BW screen & an Acer (never had problems with) *knocks on wood*
    2nd is different deaktop altogether with ol school Dell Monitors hopefully will be replaced with the two 22" Samsung Monitors soon
  • Toasty
    • Jul 2007
    • 4171
    Re: Samsung 225BW & 226BW CCFL Bulbs?
    Actually need the Panel Model number (i.e. LTN... LTM...) and/or the tube diameter & length (in mm's). Single tube or dual tube setup?
    These are sold as individual tubes, wired tubes (specify plug), or complete assemblies.
    - Assemblies are pre-wired, shrink wrapped, end caps installed, and wired to the plug. You just unplug and remove the old one and replace and plug in the new.
    - Pre-wired tubes and you specify what plug you want.
    - Individual tubes require de-soldering, removal, replacement and re-soldering.
    What is the problem with the unit(s).
    What does "6 Main caps that have been known problems" caps mean?
    Have you considered that all the caps need replacement except, perhaps, the mains cap?
    Toast
    veritas odium parit
    • GR3Y5H3ART
      • Jan 2011
      • 146
      I spoke with Lydia @ CCFL Warehouse recommended by members:
      http://www.ccflwarehouse.com/
      Pretty sure it was the top set of numbers?
      1st monitor
      2nd monitor
      Without wires since she said if there not brown, the ones on the Monitor can be used comes out to $29.99 for one
      Also, asked about usage and she said that 15,000 hours on is not a lot for a monitor
      The big three, and the other 3 within this thread:
      https://www.badcaps.net/forum/showth...t=6930&page=15
      Current problem is both Monitors will turn on and turn off but the Blue light doesn’t blink, it will stay on
      • GR3Y5H3ART
        • Jan 2011
        • 146
        k so decided to take one apart since gotta learn and always thought they were literally behind the monitor...one set of two is top and another on bottom...not sure if theres a way to tell but heres the pics
        • EGuevarae
          • Nov 2008
          • 1336
          Toast
          1.- I agree. Explain exactly what have you done to the units, and in one thread, not spanning over three of them.
          2.- Why don't you make a working set from the 2 units you have if possible?
          • ASUS ROG Maximus IX Code
          • Intel Core i5-7600K 3.8GHz
          • Windows 10 Pro x64
          • GeForce GT1050
          • Toasty
            • Jul 2007
            • 4171
            Here's the Chi Mei panel datasheet for the M220Z1-L01.
            You can buy the tubes as 4 individual pieces, and do it yourself, for the same money as one assembly.
            Originally posted by EGuevarae
            <snip>Explain exactly what have you done to the units, and in one thread, not spanning over three of them<snip>
            Yo Patch!!
            Exactly why I hate "me too" threads. It is MUCH easier to work on 1 person's problems than to get tossed into the middle of a 16 page, 301 post epic tale. Keeping straight who's problem you're fixing is a bitch.
            IMO - You have 1 or more failing tubes. It seems the inverter controller chip is doing one of 2 things. It sees an over-current -or- an excessive strike-time (too long to fire) and shuts down. If you have a working unit of the same size, you could swap them to that. Or one of the cheap-o PC case lights, that should at least give you a clue as to the weak tube(s).
            I would start swapping tube assemblies to the unit that's still together and see if it will run. No need to disassemble, just plug them in one at a time to each output.
            Toast
            veritas odium parit
            • GR3Y5H3ART
              • Jan 2011
              • 146
              thanks...datasheet and advise...will report back with results
              • Scenic
                o.O
                • Sep 2007
                • 2642
                Ha!
                I've got a cracked Chi Mei M220Z1-L01 22" LCD Panel here (out of an Acer X223W).
                CCFLs are fine. If you want them, let me know
                They're already out of the panel.
                please note that replacing them on that specific panel is anything but easy. you have to remove the metal back plate and disassemble the panel to get to them.
                no easy slide-out on the side as i've seen on other panels, like LG/Philips
                • GR3Y5H3ART
                  • Jan 2011
                  • 146
                  omg...i've already disassembled it
                  please tell me it wouldn't be shipping from Germany
                  the cheapest i've found is from China @ 13 bucks but still debating because Stateside seller has it for $30/shipped w/1year warranty and warranty is nice but price is double
                  anywho, please get back to me at your convenience...i will check PMs here or eMail me directly @: yongrayk@alumni.usc.edu
                  sent you PM as well Scenic
                  • GR3Y5H3ART
                    • Jan 2011
                    • 146
                    Mod can you please remove my eMail addy for spam purposes...thanks
                    • GR3Y5H3ART
                      • Jan 2011
                      • 146
                      thanks so much to Scenic, packaged finally arrived, installed today, and works GREAT!
                      so my problem was the CCFL and all the soldering and replaced Caps are working great
                      seeing the Twin Samsung 225BW is freaking awesome
                      Scenic, you da man!
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        Good job, but please put your location in your profile so that we can help you better in the future.
                        A working TV? How boring!
                          09-07-2024, 05:50 AM
                          09-06-2024, 11:40 PM
                          09-06-2024, 08:40 PM
                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 06:20 PM
