Viewsonic - VA1912w-3
  • Notherbast
    • Mar 2009
    • 10
    I dont know how i seem to have gotten conned into fixing all these LCD @ the moment but anyway...
    Still waiting for parts on the Benq, but heres another one..
    Viewsonic, nothing but a white screen. had 2 of them, 1 with dud caps, and the other one a white screen. .Swapped the white screen PSU into the other and its all good. So, it looks like the video board is having trouble. All SMD(on the video board), so no bulging or anything. Connectors are good, all clean, no bad joints, reseated cables but no joy.
    Any ideas? been over with the glass looking for dry joints, found a couple and no joy, anyone know test points or anything which may help diagnosis ?
    Oh, its a rebadged chimei a190a2-h01
    Cheers,
    David.
    My sludgebox:
    Intel Xeon E3110
    ASUS P5E
    CoolerMaster CM690
    CoolerMaster Extreme 650 PSU
    4GB Mushkin DDR2-800
    2 x Samsung 750GB HDD
    2 x WD 400GB HDD
    Everything else varies depending on the week
  • mladen82
    • Mar 2009
    • 39
    • Montenegro
    Re: Viewsonic - VA1912w-3
    probably don't have power supply to the lcd panel, you must check +5V to panel electronics (smd fuse)
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Viewsonics usually go due to PSU caps.
      Mann-Made Global Warming.
      - Dr Seuss
      • EGuevarae
        • Nov 2008
        • 1336
        Second that. White screen can be caused by an open fuse on the input of the LCD panel electronics.
        • ASUS ROG Maximus IX Code
        • Intel Core i5-7600K 3.8GHz
        • Windows 10 Pro x64
        • GeForce GT1050
        • Notherbast
          • Mar 2009
          • 10
          PSU is good, as it works perfectly for 3 days now in another monitor... checked all smd fuses, all good...
          Guess a little more time with the meter is called for.
          Cheers.
          My sludgebox:
          Intel Xeon E3110
          ASUS P5E
          CoolerMaster CM690
          2 x WD 400GB HDD
          • EGuevarae
            • Nov 2008
            • 1336
            Cheers.
            Check the fuse on the LCD panel electronics. If open, screen will be white. I've seen it on Hanns-G and Dell units.
            • GeForce GT1050
            • harp
              White screen repairs
              by harp
              To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
              Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
              On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
              05-13-2024, 03:43 AM
            • domu
              Viewsonic VS16217 strange problem - white flickering screen on power up
              by domu
              As per subject, on power up display shows no image, but white
              flickering screen. Strangely, it only happen after power was lost
              when it was on. After power returns - white screen only, but if
              disconnect power for 12-24 hrs, and connect then again monitor
              works normally.
              Any clues how to go about it would be greatly appreciated.
              07-18-2023, 04:57 AM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • EazyBone
              Sharp LC-65Q620U White Screen
              by EazyBone
              Another TV topic!!
              I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
              The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
              Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
              08-21-2024, 12:56 PM
            • hcinne
              Dell G15 ryzen edition black screen 2 amber 1 white
              by hcinne
              I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
              07-23-2024, 07:56 AM
