Iiyama ProLite E485S
  • SoilMuncher
    • Feb 2018
    Hi all, I'm having an issue with my ProLite monitor.
    When turned on, the screen cycles through a number of solid screen colours, green, red, pink, etc.
    I know all about the secret menu that can be accessed on these monitors by pressing - and + while turning on the monitor, but this menu disappears as soon as the screen changes colour.
    I have another exact same monitor and this one has the exacts same issue when I switch over both the VGA/DVI and power cables, with the other working while using the cables from this one.
    Any idea?
  • rddube
    Aspiring Expert
    • Jun 2013
    • 908
    Re: Iiyama ProLite E485S
    Not too sure what you mean by this - is one monitor working and the other having the issue? Could you elaborate?
    Posting nice clear pictures of both sides of the power board and the main board will attract more users to come and try and help you, but you need to be clear on which monitor does what.
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • mikey5791
      Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
      by mikey5791
      Got this working ips led monitor by the brand of
      Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
      Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
      09-04-2023, 03:50 AM
      by momaka
      03-15-2023, 10:17 PM
    • ant3202
      HP 27es - LED monitor - Monitor Flashing On - Off
      by ant3202
      Hi Everyone
      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
      https://www.badcaps.net/forum/troubl...lashing-on-off
      The monitor is HP 27es LED Monitor
      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
      The monitor will randomly blackout and display no signal and will recover again.
      Sometimes need to power and off again to restore the display but...
      03-20-2025, 07:30 PM
      Wise Wing F199 19'' LCD monitor - recapped
      by momaka
      Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
      I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
      When I saw the Craigslist post, I wasn't...
      08-24-2020, 10:58 AM
