Benq Q7T4 (FP71G)
  • EGuevarae
    • Nov 2008
    • 1336
    Re: Benq Q7T4 (FP71G)
    Originally posted by Notherbast
    okay.. Partial success.. the backlights now turn on (got the 2sc's today) and then the monitor just kind of "pixelates" and fades off..
    Am recapping the rest of the board now, but anyone got any ideas on what else could cause it ?
    I just had that problem (pixelation) on a 940T. The case is as follows:
    I bought two units and after recaping I found out that the 2nd one had the right part of the screen pixelated. I pressed the ribbon cable that connects the LCD panel circuit board to the TFT glass/panel/whatever-the-name-is, and ended up with a corrected image but three/four vertical lines across the screen. They didn't go away. You can see the two screens working, and the lines on the one I mention. The portion of the screen at the right of the lines was pixelated BEFORE I PRESSED the ribbon. You can try this to see if that is your case. Crazy Idea, but it is my only pixelation case so far, and I just wanted to suggest it.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • Windows 10 Pro x64
    • GeForce GT1050
    • Notherbast
      • Mar 2009
      • 10
      Hmmm, will try, thanks.
      My sludgebox:
      Intel Xeon E3110
      ASUS P5E
      CoolerMaster CM690
      CoolerMaster Extreme 650 PSU
      4GB Mushkin DDR2-800
      2 x Samsung 750GB HDD
      2 x WD 400GB HDD
      Everything else varies depending on the week
      • EGuevarae
        • Nov 2008
        • 1336
        Any update on this unit? Now I actually have one of them in my workbench. I recapped, and the Backlight turns on, but after 3~4 mins., it turns off. Then after that, just on-off if I power cycle the unit. I haven't checked the 5707s, but I guess I'll start looking for them ...
        • GeForce GT1050
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4316
          • Italy - Milan
          I'd like to know by those of you that seem to have to do with many monitors to repair and you often tell that you recapped without success in repair, but why don't get an esr meter instead of recapping blindly? I'm also an owner of a broken FP71G+, it has an open pico fuse on the exit 14v line , do you think is enough to replace it only? Caps and other things seems ok visually, also 2 tr. in the path to the output are good, there
          seem no other things apart .litics caps.. (not bulged) thanks..
          • EGuevarae
            • Nov 2008
            • 1336
            I don't know others, but I do not "blindly recap". You recap when known bad brands under known conditions tend to go bad, and as a starting point you recap to eliminate that variable from the whole equation, especially when visual indication exists. I don't need an ESR meter to replace a Su'scon, a Lelon or another "good" brand on sight. Also, I have repaired monitors without replacing a single cap, so this is not about replacing blindly any cap on the board. On the other hand, caps and other components (like bridge rectifiers, FETs and Transformers) can go bad (open, short, high ESR, lower capacitance,etc.) without visual indication, so "seeing" all components OK just because they are not bulged (in the case of caps) is like "blindly diagnosing".
            • GeForce GT1050
            • Bobdee
              • Jun 2008
              • 461
              #26
              That open fuse usually indicates a faulty transistor on Inverter (C5707) there are four of them to check, Also resolder the four Inverter transformers as they are possibly the cause of failure
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4316
                • Italy - Milan
                #27
                Thanks Bobdee, in fact some minutes after writing i saw other threads and even if i don't suspected it i found 2 c5707 in short , the solderings are correct. Bye.
                (PS: do you remember wich part is compatible with the 2 tr.? If not i'll start searching here, i had read it one time)
                • Bobdee
                  • Jun 2008
                  • 461
                  #28
                  I have repaired many Benq boards with failed C5707s and never found one that did not have bad solder joints on one or more Inverter Transformers, this is what you are likely to find (not easy to see with naked the eye)
                  https://www.badcaps.net/forum/attach...chmentid=11030
                  Best resolder them
                  The transistors are readily available on Ebay, just search for 2SC5707s, they are considered the most suitable for the requirements
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4316
                    • Italy - Milan
                    #29
                    Hi, i know this problem, i have watched very well the solderings, that in the picture is
                    easy to see also by naked eye, i've done a cold soldering by moving the grey .22 cap
                    near c5707, i can see it quite well, my view is good, there's no cold sold. in mine, i will not touch them cause i can only worse them, i have read a repair guide on net about this monitor, he say that blown tr. are cause by cold sold. on transf. or bad .22 160v grey cap, near the 2 tr. One question, i'm not expert in elect. , i cannot found same part for C5707, i can use another tr. with Vce max 80v (like c5707) but Ic=10A (instead of 8A) even if package is bigger (To220) but seem the pin step near the same, or i have to follow other specs.. (dissipation, mhz)
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4316
                      • Italy - Milan
                      #30
                      Sorry, "is near the same"... and "dissipation"=heat sinking...
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4316
                        • Italy - Milan
                        #31
                        i've asked about substitute components for c5707 'cause i also need others components for other things and my benq also has a blown FQU1106 tran.
                        • mecklan
                          • Oct 2008
                          • 5
                          #32
                          The MOSFETs have I changed the fuse and also the transistors and .22 caps. The other capacitors I have left alone, since I have no direct way to test it. The converter I have soldered, brazed solder removed and resoldered. With the above measures, I have just assembled the TFT again, and lo and behold, it touches on something. Unfortunately, the joy was short-while. The monitor has displayed a picture of exactly 2 seconds and then switched back to orange light. This can be repeated as often as desired. Switched on and off again, then another 2 seconds and picture because that's all well again. What can still be broken?
                          • seppde
                            Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                            by seppde
                            I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                            ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                            The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                            In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                            02-09-2024, 05:19 AM
                          • AJ847.63e
                            BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                            by AJ847.63e
                            Hi All.
                            Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                            The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                            09-18-2023, 06:42 PM
                          • ChatBTC
                            Benq EX3501R
                            by ChatBTC
                            Hi!
                            I am new to this site, and found it via LLM ChatGPT.
                            I got a BenQ Ex3501R monitor which i have had for a while now, it works pretty good until recently, it struggles to turn on, i can see the purple welcome screen is shown for a brief time before it vanish again, usually it stays on for a couple of seconds before the main computer screen is shown, but image is still kept black, before i just had to turn it off and on a few times and that would leave it on, but now it takes ever longer to stabilize the image on the screen, ocasionally i can see the computer desktop...
                            01-24-2025, 08:49 PM
                            BenQ JoyBook S52 S53 Laptop Schematic
                            Quanta ED3...
                            11-01-2024, 02:03 PM
                            BenQ S72 Laptop Schematic
                            Inventec Grasshopper Rev 3.0...
                            11-01-2024, 07:23 AM
