Benq Q9T3 wont turn on, need help!
+ More Options
Posts
  • Adasm
    • Mar 2009
    • 17
    I inherited a dead Benq Q9T3 monitor from a friend and after reading this forum, there seems to be a light at the end of the tunnel.
    I've included a pic of the power board. This monitor wont turn on whatsoever, no lights, no screen nothing. So, i'm assuming it's a power issue. The components of the board seem to be okay, but that could mean nothing. There seems to be some "burnt" spots on the board which the pic shows, but I dont know where to check from here, hopefully you all can help me in this predicament. I havent checked the fuse yet as i'm hunting for my MM right now. But will update soon on some component checking. Thanks in advance!
  • sofTest
    • Aug 2008
    • 361
    Re: Benq Q9T3 wont turn on, need help!
    Well, from the picture, it looks like 3 or 4 capacitors on the lower right in the picture have bulging tops.
    Be a mensch
    • Bobdee
      • Jun 2008
      • 461
      Dont like the look of that right hand side Inverter Transformer either, looks like it has suffered some over heat damage.
      • Adasm
        • Mar 2009
        • 17
        Awesome, progress. Now, how do you suggest I test these components? I know basic fundamentals of electronics and can test them/replace them. But these components I don't know how to test.
        If the tops of the caps are bulging and not flat, I take it that's a bad sign? A precursor to "leaking"?
        • sofTest
          • Aug 2008
          • 361
          If a capacitor is bulging, it is defective, yes. If you choose to try to repair the board, all bulging capacitors need to be replaced with a good quality replacement.
          Be a mensch
          • Adasm
            • Mar 2009
            • 17
            Good, I can do that. There is a great electronics store nearby I can get caps from. Now, how about this suspect inverter transformer? How do I test that? Also, how do I test the caps with my multimeter to know 100% that they are defective?
            • sofTest
              • Aug 2008
              • 361
              On some multimeters you can measure capacitance and resistance, but that will not tell you 100% that a capacitor is good. The best tester for a capacitor is an ESR-meter. A bulging capacitor is bad, no need for further testing.
              Also, you can't just replace a capacitor with any capacitor with the same markings (voltage and uF). The replacements usually need same or better specification impedance/ESR and ripple than the old ones. This is data you have to look up on the datasheet for a capacitor.
              Be a mensch
              • Adasm
                • Mar 2009
                • 17
                Alrighty. Now how do I discover the ratings of the existing bad caps on the board? I examined and found 5 bulging capacitors:
                1000uF 16V 2pcs
                1000uF 25V 2pcs
                470uF 25V 1pc
                All are electrolytic 105 degreee caps too. Now, do I need more info about them than this? What do you suggest I replace these with? And what about this suspect inverter transformer?
                • Bobdee
                  • Jun 2008
                  • 461
                  Just recap for now and leave inverter, you can look at inverter and compare it, with the other one, to see if the top shows signs of heat damage, as it looks that way from picture, but you can see more clearly than us,it might be okay with luck, just compare them for now.
                  • Adasm
                    • Mar 2009
                    • 17
                    Alrighty. I'm gonna take this board to a friend and have him help me get new caps to solder in. After that i'll try it and update back here. Thank you both for your help, very much appreciated.
                    • Wizard
                      • Mar 2008
                      • 2296
                      Important to have low ESR with high ripple current. If they can't answer your questions at that store, and can read the capacitor markings there, report back with the info before buying these capacitors so we can tell you if it is suitable.
                      Cheers, Wizard
                      • sofTest
                        • Aug 2008
                        • 361
                        If you can give us also the other markings on the capacitors, we can look up the datasheet for them.
                        About the transformer, I'm not quite qualified. You could start with measuring the resistance across the various legs, and compare with the same readings on the other transformer. You can also try searching for transformer in the forum. I've seen measuring transformers have been discussed in other threads.
                        Be a mensch
                        • Bobdee
                          • Jun 2008
                          • 461
                          Have you seen this
                          https://www.badcaps.net/forum/showpo...93&postcount=1
                          • Adasm
                            • Mar 2009
                            • 17
                            k, here's the info:
                            two biggest caps - Elite
                            25v1000uF
                            EL(M)105°C
                            (B)0312
                            two medium caps - Elite
                            16v1000uF
                            EL(M)105°C
                            (B)0418
                            one small cap - Elite
                            25v470uF
                            EB(M)105°C
                            (C)0420
                            That is every little piece of info off of those caps. So, if you could inform me on which caps to purchase, that would be great. Soldering them in is something I can do easily.
                            Also, compared the transformers and they look the same. Doesnt seem to me as heat damage, but rather the amber colored protective coating that seems to be on most of the components. But, I could be wrong.
                            And yes, I did check that topic before, and noticed the badly leaking caps. My transformers look similar to his and he said after replacing the caps all was fine. So, fingers crossed, it's just a cap problem!
                            • sofTest
                              • Aug 2008
                              • 361
                              The Elite EL 25v/1000uF got impedance/ripple 0.021/2360
                              The Elite EL 16v/1000uF got impedance/ripple 0.023/1820
                              The Elite EB 25v/470uF doesn't exist according to the datasheet. Max. voltage should be 16 volt. But for other values, they are a little better rated then EL-series.
                              Anyway, if you can get your hand on Panasonic FMs, they can replace all these capacitors. You can order them from Digikey.com. Also, be sure the check the physical size, especially where components are close.
                              Be a mensch
                              • Adasm
                                • Mar 2009
                                • 17
                                I sized up my caps, but evidently no records match my search criteria.
                                The 25v/1000uf caps are 13.5mmD x 20mmH 5mm LS
                                The 16v/1000uf caps are 10mmD x 20mmH 5mm LS
                                The 25v/470uF caps are 10mmD x 16mmH 5mm LS
                                I dont know if the lifetime @ temp values or the packaging values matter, but I entered all the sizing info and what not and got nothing.
                                Also, for the 470uF cap, what do you suggest I can use in it's place if I can't locate a replacement?
                                • sofTest
                                  • Aug 2008
                                  • 361
                                  The point is that the replacements are not bigger. If the sizes you are listing are the old capacitors, you can replace with:
                                  http://search.digikey.com/scripts/Dk...name=P12379-ND
                                  http://search.digikey.com/scripts/Dk...name=P12366-ND
                                  http://search.digikey.com/scripts/Dk...name=P12388-ND
                                  DigiKey seem to be out of stock of the 16v/1000uF Panasonic FM, so if you don't want to wait, the UCC KZE can be used:
                                  http://search.digikey.com/scripts/Dk...me=565-1664-ND
                                  Be a mensch
                                  • Adasm
                                    • Mar 2009
                                    • 17
                                    ok, im gonna take all this info and see if I can buy these caps and install them tomorrow, will be back for an update tomorrow evening...thanks again for all your help, very appreciated!
                                    • Adasm
                                      • Mar 2009
                                      • 17
                                      Well fellas, my hat is off to ya! I replaced the 5 caps and sure enough, i'm using the monitor as we speak! Awesome, can't thank you guys enough!
                                      • tony_5
                                        • Mar 2009
                                        Please have someone from your service manual for LCD monitor Benq Q9T3. My e-mail: tony5@centrum.sk Thank you very much
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                        • robante15
                                          Acer Aspire 4520 won't turn on after reboot
                                          by robante15
                                          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                          If I remove the...
                                          04-06-2024, 06:50 PM
                                        • masoksian
                                          Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                          by masoksian
                                          I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                          The system does not turn on, there is no post.
                                          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                          The problem continues in the same way.
                                          I tried to turn on the Fn key, nothing came to the screen....
                                          02-15-2025, 12:08 PM
                                        • dqtech
                                          lenovo x240 nm-a091 wont turn on
                                          by dqtech
                                          i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                                          board number VIUX1 NM-A091 REV:1.0...
                                          02-07-2024, 01:57 AM
