hp f2105 monitor black screen
  • ryn0909
    Professor X
    • 122
    Re: hp f2105 monitor black screen
    110miles so about an hour and half
    ive been working in sausalito for the last 2 months, but we are off work for now.
    • ryn0909
      Professor X
      • 122
      Originally posted by budm
      If you disconnect the cable to the inverter board, will you get your power LED back on?
      nope, still no light
        Well, if you come up this way again I can leave the monitor by the front door for you.
        • ryn0909
          Professor X
          • 122
          i can drive up that way to get it, anytime.day or night. so whens a good time for you? im fixing this monitor for my parents. they arent liking the temporary monitor i gave them (15") lol
            Just PM me and let me know when you want to come over and I will give you my address, I am not home that much so I will leave the monitor for you.
            • ryn0909
              Professor X
              • 122
              ok Thank You i just pm'd you
              • ryn0909
                Professor X
                • 122
                If you wouldnt mind lending some assistance, id still like to try and troubleshoot this one, mainly for the learning experience. im technically inclined, i have a DMM and a basic understanding of electronics/electrical. im in no hurrry to fix this, so it would be at your leisure if not i totally understand no worries
                thank you
                • ryn0909
                  Professor X
                  • 122
                  i decided to do some voltage reading comparison between the good working monitor, that you gave me and the one that i had, that doesnt work. and i have found an issue with mine but im not sure what to make of it. checking the voltage at F851 and F852 the voltage fluctuates between 10v and 14v. the voltage at the same locations (F851 & F852) , on the good monitor, is a steady 18.98v Any ideas as to what i should check next?
                  • ryn0909
                    Professor X
                    • 122
                    So i was able to fix the issue with the power supply board. I decided to replace the remaining 3 CAPS that i hadnt changed at the beginning. see attached pic. Once i changed those caps, the monitor powered on, solid blue light, backlight came on and it was even detected by windows 7, once i attached the video cable to it. But nothing was showing up on the display, not even the OSD Menu.
                    • ryn0909
                      Professor X
                      • 122
                      ********PROBLEM SOLVED********
                      Attached are some pics of the problem component, although im glad to have found it, im not very happy that i have to replace the Main (Logic) Board. But it is what it is..... if i can find one cheap enough, ill buy it and post the results.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4981
                        • New Zealand
                        #31
                        Ouch. One of the voltage regulators has likely shorted, and would explain the blown fuse.
                        The voltage regulator failure could well have been caused by the bad capacitors.
                        -David VanHorn
                        • ryn0909
                          Professor X
                          • 122
                          yea OUCH pretty much sums it up.... i hate when the end result is like this (being a component that i cant replace) im a mechanic by trade and instinctively my thoughts are to fix something, rather than replace. but it is what it is cant win 'em all. hope this tread helps someone in the future
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4981
                            • New Zealand
                            #33
                            Not impossible, you could buy here: https://www.utsource.net/itm/p/4911066.html
                            And soldering QFP is much easier than BGA...
                            The problem is if it needs custom firmware, which is not loaded from an external EEPROM. Then you need the custom programmer for those MSTAR ICs, and of course, the code.
                            -David VanHorn
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4981
                              • New Zealand
                              #34
                              What you could do is look on eBay etc for a universal panel driver board. That would let you use the monitor again. Though I don't know about image quality etc.
                              Might be cheaper than trying to find an exact replacement scalar board.
                              -David VanHorn
                              • ryn0909
                                Professor X
                                • 122
                                yea i found a replacement board amd installed it. but still not showing anything on screen.
                                • ryn0909
                                  Professor X
                                  • 122
                                  ****FIXED****
                                  Finally got it working like a champ. After replacing the Main Board, i went through and RE-checked all my solder connections on the power supply board. and voila!
                                  What i have learned from all this.... When replacing the electrolytic caps, change ALL, even the tiny ones as well. they didnt look bad and i under estimated their potential for failure. Also when ordering new caps, double check their physical measurements as well as their electrical measurements. Caps are so inexpensive, compared to the price of a new monitor or whatever you are attempting to repair, that you might was well replace all of them. Although i did not have one, schematics of the board will save alot of time and headache.
                                  A BIG THANK YOU to all of you who offered your help i greatly appreciate it
                                    Good job!.
                                    So what is the final fix to get it to work when the replacement board in your post #35 still shows nothing on the screen?
                                    The one I gave you is still working?
                                    • ryn0909
                                      Professor X
                                      • 122
                                      Good job!.
                                      Well thats a good question... im wanting to say a bad solder joint on the power supply board. thats because after replacing the logic board, i still had nothing, and so i decided that ill recheck all the solder joints that i had done previously as well as any questionable looking joints. Then i fired it up and VOILA it started working. i now have had it running for 5days straight with no hicups whatsoever
                                      • turmix
                                        AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                        by turmix
                                        Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                        The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                        At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                        During another reassembly, I made a mistake, and...
                                        01-29-2024, 03:48 AM
                                      • HTR-Informatique
                                        Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                        by HTR-Informatique
                                        YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                        I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                        On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                        I also changed the screen because the PC fell and the screen was broken.
                                        I changed the battery with a new and original battery.
                                        I also had corrosion/oxidation on the...
                                        02-09-2025, 06:51 AM
                                      • howardc64
                                        by howardc64
                                        Problem
                                        08-04-2024, 10:36 PM
                                      • DaniK
                                        Acer Aspire E5-574-52RH - black screen
                                        by DaniK
                                        I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                        Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                        Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                        Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                        The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                        Symptoms are:
                                        - random black screen after displaying Acer logo...
                                        02-21-2024, 06:27 AM
                                      • m1ch43lzm
                                        by m1ch43lzm
                                        05-12-2025, 08:37 PM
