Westinghouse L2046NV Mosfet 40T03GP Wanted!
  • EGuevarae
    • Nov 2008
    • 1336
    I have two LCDs, one Acer and one westinghouse. They are 19" and 20" respectively, and share the same power supply. I got to keep one if I fix the other one, so I want (need!) to fix them both. One is already working after a recap job, but the other is dead : no backlight.
    I was checking around the board, and came across these two mosfets, one for each transformer. One has continuity over its three pins (both ways) and the other one does not behave in the same way. I was looking for a replacement and I have found none. Any idea?
    Here's the datasheet I found. Please help me to get a 20" LCD (I know I already have one, but you can't beat the price : free! I couldn't help it.. )
    I have some pictures if needed.
    Thanks in advance guys.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • Windows 10 Pro x64
    • GeForce GT1050
  • Toasty
    • Jul 2007
    • 4171
    Re: Westinghouse L2046NV Mosfet 40T03GP Wanted!
    These look to be a fairly close and perhaps better match:
    IPD135N03L G
    http://www.mouser.com/Search/Refine....ord=IPD135N03L
    IPS135N03L G
    http://www.mouser.com/Search/Refine....ord=IPS135N03L
    Datasheet: http://www.infineon.com/cms/en/produ...ml?q=ipd135n03
    Toast
    veritas odium parit
    • EGuevarae
      • Nov 2008
      • 1336
      Do you recommend to change them both or just the shorted one?
      Also, I changed 2 bulged CapXons 25v 220uf only (no more caps, ordered from DigiKey already). Is there any reason for the MOSFET to short? It was the top one (see Pic):
      • GeForce GT1050
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        I would recommend replacing both as they usually work together and changing one without the other may throw something out of balance.
        Mind you that's without tracing the circuit out, just a good practice in general with MOSFETs and other kinds of mirrored or opposing transistors in a circuit.
        Mann-Made Global Warming.
        - Dr Seuss
        • EGuevarae
          • Nov 2008
          • 1336
          So in general it would be a good idea to replace them both, as when a headlight goes out in your car and you change them both also....
          OK, I am there anyway, and at less than a dollar the piece, it would be a preventive action. less than $10 for caps and MOSFETS for a 20" LCD is a reasonable cost
          • GeForce GT1050
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            This doesn't apply to Power MOSFET because the temp coefficient is different.
            There is a condition called Thermal Runaway that can cause problems with matched transistors.
            Thermal Runaway - Temp goes up, junction resistance goes down, current goes up, so temp goes up more, and around back to the beginning, over and over.
            It is a major concern when transistors (most all kinds) are used in matched pairs.
            [Especially in parallel.]
            If you un-match the parts with a replacement minor differences may cause more of the load to be taken by one of the transistors instead of it being shared equally.
            The loaded one will heat more/faster which causes it to take even more of the load then it may 'runaway' and try to take the entire load. If it does it will overheat and burn out.
            When it goes the other gets the entire load dumped on it suddenly and it will usually burn out too.
            - Dr Seuss
            • Toasty
              • Jul 2007
              • 4171
              Originally posted by eguevarae
              ...change them both or just the shorted one?...<snip>...any reason for the MOSFET to short...
              I wouldn't order anything until I had those 2 out of circuit. I kinda a doubt they're bad. Then you can test and be sure that you have a difference between them. Fortunately they're not the ones with the tab soldered down. Which makes me think they are a bit of overkill in this circuit, as they're rated 30W and 28A continuous and not even heatsinked.
              As I said in another of your back light posts, the outputs of these devices are typically across the primaries of the ballast/transformer. You are always going to read shorted until they are clear of the circuit.
              Then again, for 58 cents a piece, who cares!
              Toast
              veritas odium parit
              • Toasty
                • Jul 2007
                • 4171
                I'm confused.
                You suggest that he change both devices, he says he's going to, then you say it doesn't apply here?
                Or, are you disagreeing with his analogy of changing them similar to headlamps? "I'm there already, I might as well", instead of the theoretical reason, "They may be electrically mismatched which can be a problem as such...".
                Temperature coefficient of...?
                While I can agree on matched pairs or sets of devices, especially from years ago in power RF output stages and high end audio equipment, I don't see that much these days. Is this because of better QC and manufacturing practices?
                For one, how will these be a known matched pair? Usually they are (or rather were) sold as such from the manufacturer and typically were 2 in a bag. Or, if an entire run was the same, there was a color dot or two to show that. What's not to say one of these (replacements) is Monday's run and the other is Thursday's?
                Toast
                veritas odium parit
                • Toasty
                  • Jul 2007
                  • 4171
                  Also available from Digi-Key:
                  IPD135N03L: http://search.digikey.com/scripts/Dk...35N03LGINCT-ND
                  IPS135N03L: http://search.digikey.com/scripts/Dk...S135N03LGIN-ND
                  veritas odium parit
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    >> You suggest that he change both devices<<
                    Yes I did.
                    >> then you say it doesn't apply here? <<
                    No I didn't.
                    I said Thermal Runaway doesn't apply to Power MOSFETs.
                    Their temperature coefficient is + vs - as with most other transistor type ICs.
                    On Power MOSFETs when Temp goes up, junction resistance goes up, current goes down.
                    Thermal Runaway is just one example of why keeping matched parts matched is a good idea.
                    It was general discussion and , as I said, not specific to this circuit.
                    - Dr Seuss
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      Toast
                      As far as I remember, I tested both PSUs, and each of the ICs on board, then pulled out the "bad" one and tested it outside. I will retest it just to be sure, but I remember that I saw a diode inside the IC diagram, and the diodes have to be checked either out of circuit or with a pin lifted (so they are basically out of circuit). Again, I'll recheck it (them, as I removed the pair thinking from the very beginning in replacing them both if found and if $$ would allow it).
                      And it is nice that you follow up on people ("As I said in another of your back light posts ...") rather than just throwing an answer/tip (even if it is a correct one, is nice to know that someone follows up).
                      And regarding the analogy of the headlights, I tend to use that kind of things to make things even clearer : I know that some of my questions might be electronics-kinder-grade but I am a computer technician that mainly developed software and never had to mess with electronics, and this sort of analogies help me a lot. Have you seen the movie Philadelphia , where Denzel W. plays an attorney that has a motto like "explain it to me like I was six years old ....". Well, that's my approach here
                      But so far I've repaired many (more than 25 now that I check my notes) LCDs and helped others to do it, so, as it is said, so far, so good.
                      • GeForce GT1050
                      • EGuevarae
                        • Nov 2008
                        • 1336
                        Out of stock until first week of April. Better order them from mouser.
                        • GeForce GT1050
                        • Toasty
                          • Jul 2007
                          • 4171
                          Ahhh! I thought you were replying to the previous post(s). The lack of a - or : at the end of the opening line is what threw me off. So the entire statement was regarding thermal runaway. Gotcha!
                          Toast
                          veritas odium parit
                          • EGuevarae
                            • Nov 2008
                            • 1336
                            Monitor fixed. Replaced both MOSFETS, a SMD fuse beneath the inverter area, and now I am browsing using it on a dual display configuration.
                            • GeForce GT1050
                            • jepongski
                              • Mar 2009
                              • 3
                              hi can you tell me which SMD fuse you;ve replaced coz i got the same power supply. and the same problem.
                              • bullwinkle
                                • May 2009
                                • 107
                                I also have the same problem on my Acer 19" LCD. Got to try soon what I learned here
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  The fuse is F200. As noted it's a SMD fuse. I replaced it with a 4 Amp fuse.
                                  PlainBill
                                  • bullwinkle
                                    • May 2009
                                    • 107
                                    The same procedure and my ACER 19" LCD monitor is now alive and kicking! Many thanks!
                                    • bullwinkle
                                      • May 2009
                                      • 107
                                      PlainBill
                                      Yes I also replace this fuse. My ACER 19" LCD monitor is now alive and kicking. Many thanks.
                                      • bullwinkle
                                        • May 2009
                                        • 107
                                        Oh, forgot to mention i do recap all the big value caps from 220uf up.
                                        • Jane
                                          How do you test MOSFET in laptops ?
                                          by Jane
                                          I tried to use this method:
                                          Testing an N-channel MOSFET:
                                          Step 1: Discharge the Gate (turn off the MOSFET)
                                          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                          Step 2: Charge the Gate (turn on the MOSFET)
                                          Now, place the red probe on the Gate (G) and the black probe on the
                                          09-27-2024, 03:31 AM
                                        • redbaron1007
                                          Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                                          by redbaron1007
                                          I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                                          Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                                          09-09-2025, 11:10 AM
                                        • AppleLover123
                                          Asus X712EA 3 volts after the first mosfet
                                          by AppleLover123
                                          Hey guys,
                                          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                          Now i thought something...
                                          12-15-2024, 07:49 AM
                                        • MicroSMD Lab
                                          ASUS ROG Zephyrus GPU Mosfet repeat failure
                                          by MicroSMD Lab
                                          The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                                          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                                          01-10-2024, 06:36 AM
                                        • Scotchmist
                                          Asus GA502D keeps blowing mosfet
                                          by Scotchmist
                                          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                                          I have removed the mosfet and can run the laptop no problem
                                          The MOSFET is FDPC5018SG
                                          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                                          08-24-2024, 02:23 PM
