BenQ FP557 issue
  • stephen.p
    • Jan 2009
    BenQ FP557 issue
    I know I shouldn't be posting too many new threads on an emergency account, but this was what I was trying to post on my Stevo1210 account when it crapped out.
    My friend has a 15" FP557 BenQ LCD which he wants me to fix. It still works and all assuming you can get it to turn on.
    The problem is that when you want to turn it on you have to wait 10-15 minutes before you get an image on the screen. Within the 10-15 minutes, the power light flashes green to amber continuously. After about 10-15 mintues it finally stabilises itself and decides to go to green and then turn on like any other monitor. But funny thing is that if you turn it off and turn it back on again, it comes on straight away. If the LCD is turned off for say 30 minutes, the problem comes back. My friend also noted that it comes on really quick on hot days, but on colder days it does the amber-green light thing continually until it wants to turn on and it can be a real pain sometimes.
    I suspect it might be bad caps because he did state that it comes on quicker on hot days or straight after being turned off and then on again.
    The backlight and everything else is fine. The picture quality is perfect, it's just this silly issue of the starting up that really bothers him and needs to be fixed.
    Thanks.
    This is "stevo1210" reporting in with this "new" emergency account as my other account doesn't work properly.
  • stevo1210
    • Oct 2006
    • 4156
    Re: BenQ FP557 issue
    Stevo1210 is now officially online again. I was talking to my friend today and he said this issue only came to life a few months ago, so I suspect it has to be bad caps. I think that if say a transistor or something was faulty we would have noticed from the beginning and it would be dead as well and wouldn't turn on at all I suppose.
    Thanks.
    • stevo1210
      • Oct 2006
      • 4156
      ... anyone?
      • Bobdee
        • Jun 2008
        • 461
        I a hobbyist but if it was mine, I would be in it looking to see if there is visible problem, and inspect all solder joint carefuly with magnifying glass and resolder any suspect solder or joints, it sounds like poss problem, if it is not then you can post back on what you do find in there that looks like a problem
        bob
        • stevo1210
          • Oct 2006
          • 4156
          I managed to go over to my friends house yesterday to inspect this LCD monitor. Since it has been really cold recently, he has tried to turn his LCD on in freezing temperatures with no success and that power LED keeps flashing and with every flash if you listen carefully through the LCD's air vents, you can hear very faint clicks with every flash of that power light.... and I mean very faint because only the best of ears could hear it. When a bit warmer of course, the LCD will boot and stay on (not every time it's warm though.... hit and miss really).
          Anyway I did a visual inspection of the caps and this is what I found.
          2x 220uf 25V (8x10mm)
          1x 1000V 35V (12.5x25mm- approx height)
          2x 1000uf 16v (10x15mm - approx height)
          3x 470uf 25V (10x10mm- approx height)
          All of them are either Elite or Lelon brand. The Elite brand 1000uf 16V cap is very slightly bulged so I know that one is bad.... the others don't look bulged or popped but seeing as they are either Lelon or Elite brand I'm not taking my chances.
          Other than that the others are very small caps like 100-220uf of low voltages which I don't think are affected at all.
          So would you guys think it is wise to replace all the "larger" caps? I don't want to waste my friends money or ruin my image with electronics so yeah.
          Thanks.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            do the larger ones. just to be safe.
            sigpic
            (Insert witty quote here)
            • MrVik
              • Apr 2009
              • 18
              I have a dumpster Hann 19" that had similar symptoms. There were no caps with visible damage, so I replaced all those in the power supply circuit. Now, it works like new. This was before I got my ESR meter. I later checked those caps and only one had bad ESR, so it only takes one bad to shut the whole thing down. Good luck.
              Why throw it away? I might need it in the next 40 years. Duh!
              • stevo1210
                • Oct 2006
                • 4156
                I'm doing this fix up job tomorrow.... I have bought new caps, or rather my friend has for the quick fix solution.
                We bought a bunch of Suntan branded caps because they were the only ones that were available locally. So after about 15 caps and a bill of $14 something, we have a whole bunch of low ESR caps (Only big caps, not small ones under 330uf).
                I hope this works....
                Thanks.
                • stevo1210
                  • Oct 2006
                  • 4156
                  I have some good news and some bad news. The good news is that after replacing the caps on the power circuit, the monitor is now able to turn on and work again. But the bad news is that the lcd only displays white now... no colour, image or anything, just white... I looked at my soldering and it appears I haven't done any thing wrong in that sector... but why does it only show white now? what would be the cause of this?
                  thanks.
                  • Bobdee
                    • Jun 2008
                    • 461
                    thanks.
                    You havent by any chance left the lead to the panel and mainboard disconected either end
                    If you havent check the tiny fuse on the panel itself under plate up top of screen
                    • stevo1210
                      • Oct 2006
                      • 4156
                      I've checked it and I can confirm that all appropriate cables are plugged in. I'm going to look for this fuse thing under the screen's top plate.
                      • rounin
                        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                        by rounin
                        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                        🛠 Original Issue
                        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                        04-19-2025, 01:18 AM
                      • ugamazing
                        Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                        by ugamazing
                        I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                        We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                        12-17-2024, 07:05 PM
                      • shahnld
                        Lenovo legion 5 pro startup issue
                        by shahnld
                        Good day Experts
                        I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                        A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                        And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                        08-24-2025, 12:31 PM
                      • ahmarzo
                        Acer laptop battery draining issue
                        by ahmarzo
                        Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                        Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                        08-02-2025, 06:39 AM
                      • elmark
                        HP 15-cw1002ua strange keyboard issue
                        by elmark
                        HP Pavilion 15-CW1002UA
                        S/N 5CD0251CBC
                        P/N 7KE54EA
                        Hello guys!
                        I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                        It powers on OK and has no other issues except the following:
                        • CAPS LOCK does not work at all
                        • Fn button toggles Flight Mode
                        • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                        • (with SHIFT pressed: 't%' and 'y^' respectively)
                        I initially thought it was a keyboard malfunction (internal short, etc.),
                        but when I press and hold...
                        06-27-2025, 01:10 AM
