17" mitsubishi lcd inverter problem???
    power led good, stand by after a few seconds and led turns amber but if i move the mouse it turns to green again which means that the lcd is good and the culprit maybe the inverter ckt or the ccfl.
    can i use ccfl bulb from another monitor of different model to test it is working, how will i know the working V of the bulb.
    here's some pic of the inverter ckt.
    no bulging caps
    another broken 17" lcd
    burn in power supply area, probably the switching transistor and an ic underneath
    can i modify or make a DIY substitute power supply for this one? thanks
    Re: 17" mitsubishi lcd inverter problem???
    model number ?
