BenQ FP737s (Q7T3) issue
  • stevo1210
    • Oct 2006
    • 4156
    My friend has a BenQ FP737s LCD screen and the standby light goes green but nothing comes up on the screen. I think it might be an inverter issue. Anyway, it did this on its own so he's decided to buy a new monitor. I'm going to buy the FP737s off him and try to repair it. Now I've read around here that some components on the inverter die or short or whatever and in the end causes this issue?
    Now since I'm new to the world of electronics and don't understand the jargon in the other posts, can someone put this in laymans terms and tell me what parts are the ones that need to replace. Since I don't have it here, I don't know what's shorted/dead and what's not.... but what are the components that generally die in this LCD to cause the issue? (oh, and I'll need that in laymans terms).
    Thanks.
  • stevo1210
    • Oct 2006
    • 4156
    Re: BenQ FP737s (Q7T3) issue
    .... Anyone?
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Any I've done so far only needed caps.
      I know there are some models with problems with particular transistors but I haven't personally run into that yet.
      Mann-Made Global Warming.
      - Dr Seuss
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        bad solder joints on ccfl transformers,bad 2sc5707's,shorted fu9624's,bad caps.
        open it up and post pics.
        • electroguy75
          • Dec 2008
          • 21
          same here as pcbonez.any i have repaired required replacement of bad caps only.the last one would come on and go black after 15 secs or so.it turned out to b 4 bad caps. transistors were ok.
          • stevo1210
            • Oct 2006
            • 4156
            Originally posted by kc8adu
            shorted fu9624
            Where can I get these from? I've tried quite a few electronics stores here and they didn't have this part, but they have everything else though. The 2SC5707 I could find quite easily at my local electronics store for $3.27 each.
            Since I haven't received the monitor yet, I will have to wait and see what's going on with the internals of the LCD.
            Thanks.
            • ozcar
              • Nov 2008
              That is expensive for the C5707s - I got some from WES in Ashfield for $1.35 each. I don't know if they have the FETs - I did not have to replace them.
              There is another thread here about FP737s were I'm pretty sure there was some talk about where to get the FETs, C5707s and picofuses that also usually blow.
              • Wizard
                • Mar 2008
                • 2296
                3.27 each? That's not bad to do. Don't forget the cost of handling & shipping, and not all live in same country would have to contend with the border fee to pay.
                Cheers, Wizard
                • rounin
                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                  by rounin
                  I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                  🛠 Original Issue
                  The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                  04-19-2025, 01:18 AM
                • ugamazing
                  Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                  by ugamazing
                  I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                  We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                  12-17-2024, 07:05 PM
                • shahnld
                  Lenovo legion 5 pro startup issue
                  by shahnld
                  Good day Experts
                  I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                  A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                  And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                  08-24-2025, 12:31 PM
                • ahmarzo
                  Acer laptop battery draining issue
                  by ahmarzo
                  Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                  Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                  08-02-2025, 06:39 AM
                • elmark
                  HP 15-cw1002ua strange keyboard issue
                  by elmark
                  HP Pavilion 15-CW1002UA
                  S/N 5CD0251CBC
                  P/N 7KE54EA
                  Hello guys!
                  I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                  It powers on OK and has no other issues except the following:
                  • CAPS LOCK does not work at all
                  • Fn button toggles Flight Mode
                  • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                  • (with SHIFT pressed: 't%' and 'y^' respectively)
                  I initially thought it was a keyboard malfunction (internal short, etc.),
                  but when I press and hold...
                  06-27-2025, 01:10 AM
