NEC LCD1700v ... feeling clueless
  • retiredcaps
    • Apr 2010
    • 9271
    Re: NEC LCD1700v ... feeling clueless
    Sorry, forgot to mention that the DMM I'm using right now doesn't have a capacitance test function.
    --- begin sig file ---
    --- end sig file ---
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      Two 100uF caps in parallel would make 200uF, just for test.
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        I forgot what thread it was but someone had even switched the top ccfl's with the bottom ones and had some temporary stability in which was a clue into what was going bad.
        • retiredcaps
          • Apr 2010
          • 9271
          Well I got a Benq FP731 today and when I opened up the case, I noticed that the connectors to the CCFLs are the same as the NEC 1700V so I immediately connected the NEC inverter to the Benq screen and Benq screen lit up and stayed lit (showed a bright white screen).
          Obviously, I had no VGA display since the control logic/data cable are all different, but the CCFLs stayed lit.
          So this tells me that something is wrong with the NEC CCFLs. So the next step will be to dismantle that and checked for arcing, burnt solder, etc.
          PS. I still had the way over 470uF caps in there for the test. I fully intend to switch it out for the proper capacitance.
          • x_orange90_x
            Vizio E55-E1 bad backlights or bad inverter?
            by x_orange90_x
            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
            I don't know how exactly to test the inverter itself. Is it...
            01-29-2025, 09:24 PM
          • Gentian
            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
            by Gentian
            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
            03-06-2023, 07:07 AM
          • valvashon
            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
            by valvashon
            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
            01-04-2024, 01:44 PM
          • eccerr0r
            A modified sine wave inverter + a grid tie inverter?
            by eccerr0r
            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
            Next thing is trying to charge the batteries using solar power, but that's another issue ...
            08-31-2023, 09:14 PM
          • mitsu2k
            Power-One solar Inverter driving me NUTS!!!
            by mitsu2k
            Hello folks, this is a last ditch effort. I thought I would seek your expertise before giving up.. I have been working on this thing for over 2 months and have gotten nowhere. Here is the issue:
            Inverter powers on and immediately red GFI light comes on and inverter will not complete the initialization process.
            There is no error code on the screen. I have removed most of the Y capacitors and tested to no avail.
            All relays are good.
            I replaced the current transducer- same problem. Checked most of the transistors and diodes and all appear good. I wish I could get my hands...
            11-13-2023, 07:19 PM
