Dell S2715Ht LED backlight
+ More Options
Posts
  • leggot
    • Oct 2014
    • 50
    I have a dell S2715ht, it has an led strip backlight and has an odd problem, the led strip turns on for about a second before turning off. The monitor power led stays on and shining a flashlight into the screen reveals a good picture.
    I was able to crack the monitor open and test the voltages going to the led strip, the led strip lighted momentary so I only got readings at that one given instant.
    The led/lcd panel is an LG LM270WF7. I would be satisfied using an external power source to power the LED backlight, independent of the monitor; however I haven't been able to find any datasheets for the monitor or the panel. If anyone has experience with the wiring of LED backlights, help would be much appreciated.
    Green (GND?)
    Yellow (~15V)
    Orange (19-20v)
    Red (19-20v)
    Brown (~15v)
    Black (~15v)
    Re: Dell S2715Ht LED backlight
    Can we see the whole pictures that show how all the boards and the LCD PANEL are connected together?
    • leggot
      • Oct 2014
      • 50
        It looks like there are 4 set of LED strings (I see 4 current sensing resistors (LED's Cathode return): 1R00 (R372~375)), that 16-PIN IC next to the LED connector should be the LED driver IC, you can look at the number on top to get the spec sheet of the IC.
        L702 inductor looks to be the LED+ Voltage for the LED common Anode strings, see which pin of the connector has direct connection to L702.
        Also check to see how R372~375 connected to each pin of the connector. I see that one end of R372 go to pin with GREEN wire and another end of the resistor goes to the pin of the IC, so what DCV do you have on that GREEN wire?
        GB98AGN??
        I cannot find the spec sheet for it.
        • leggot
          • Oct 2014
          • 50
          Thanks for the quick reply.
          I noted the following were connected:
          R732 - Green to pin 1
          R733 - Black to pin 9
          R734 - Brown to pin 11
          R735 - Black to pin 12
          L702 - Red and Orange (tied)
          The IC says GB98AGN CF7NIN 1448A2 at I701. I couldn't find an easily accessible datasheet, I emailed a place; we will see if they respond.
          According to this russian forum, the hp elite display e221c has the same chip. This might give us some insight to the led driver of the dell, but again I can't seem to find a service manual.
          When I measured the green wire voltage, (black probe to black wire, red probe to green wire) it was about negative 15 volts. This indicated to me that green would be the reference voltage, thus I measured everything in relativity to green.
            Red and Orange is the supply Voltage to the LED Anode.
            The other four wires are the Cathode return wires for each LED strings (4 strings) and all those 4 wires should show the same reading if there is no problem with the LEDs.
            Please verify the color.
            • leggot
              • Oct 2014
              • 50
              I apologize, here are the corrections
              R733 - Yellow to pin 9
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4333
                • Italy - Milan
                Budm: "It looks like there are 4 set of LED strings"
                I think you mean there are 1 string with 4 series of leds...
                in fact i have count 29 leds from the picture, is not entire, suppose ther are 32 leds, divided by 4 are 8 led/series=20v/8=2,5v per led. Now what you have to do is to grab somewere a small battery 3v an with some probes supply each led, if you find the one faulty you have to: 1. search for a replacemet strip OR 2. search for a compatible led and buy some.. (replacement is not easy)
                • leggot
                  • Oct 2014
                  • 50
                  Actually, there are 60 leds, it is rather difficult to take a picture of the entire panel. In the momentary flash, it appears as if all the leds light up, however it is difficult to verify all 60 leds do flash.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4333
                    • Italy - Milan
                    20v/15led=1,3v per led, seems a bit low, but if you can supply 1,5v by a battery to each led you see if them lights up, if not you can watch which pin of the IC goes to a small cap. and after to GND (screw hole), if you find only 1 of theese, short circ. the cap to gnd and try to power up. You could see all led stay lit apart the broken segment, then you can measure V on each led and then apply that to each led of the broken segment to test.
                    • leggot
                      • Oct 2014
                      • 50
                      From what I can tell, all the LEDs do work, the entire strip flashes momentarily when the unit is first turned on. This leads me to believe this is an issue with the circuitry that controls the power going to the LEDs.
                      I am not opposed to by passing this circuit and simply applying voltage to the LEDs independent of the circuitry; however it would be nice to be able to dim the monitor.
                      I am not sure if this answers your answer, I'm not sure if this proves that all the LED strips are functioning correctly.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4333
                        • Italy - Milan
                        I dont really know about leds but as other semicondutctor components, it can go short at a certain temperature or current, so what seems good to you, it can be not. Apart this leds failure from what i have read many times is the big part of led B.L. problems. You can also test the PS, disconnect green wire by sliding it out (use a sharp tip, needle..) then make a jumper between another return to the place of green, i don't know if it works, never tried, in another way you know that the IC needs to sense a certain voltage range on a resistance, i don't think are those 1ohm resistances, them are probably fuses, them are internal to the ic, we don't have the datasheet so we can't supply that voltage to hijack the ic, but i remember of a Vestel chassis i have studied, i suppose is about from 1 to 3v not more.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4333
                          • Italy - Milan
                          GB98A is made by O2micro: https://cdn.badcaps-static.com/pdfs/...6f8b3d4b96.pdf
                          at page 21 a very ugly schematic, no datasheet..
                            Right now the boost converter is not working,
                            You have 4 set of LED strings, 15 per string, you are only getting 19V.
                            Monitor OFF and disconnect LED connector, black probe on the chassis, red probe on L702 then turn on the monitor to see how high it jumps up to.
                            • leggot
                              • Oct 2014
                              • 50
                              L702 jumps to about 60v and returns back down to 19-20v
                                OK, so the boosted Voltage did startup without the load (LED connector not in place).
                                From post 1:
                                Green (GND?)
                                Yellow (~15V)
                                Orange (19-20v)
                                Red (19-20v)
                                Brown (~15v)
                                Black (~15v)
                                So what is the actual Voltage on that Green wire since now we know that Green wire is not GND but it is one of the 4 LED string.
                                • leggot
                                  • Oct 2014
                                  • 50
                                  Ok, comparing the voltages to the chassis ground:
                                  All the voltages decline after spiking at the voltages listed below.
                                  Green - 12v (this is what the multimeter says, I think it spikes higher, but it is difficult to tell as the multimeter 'thinks' for a second then displays the voltage)
                                  Yellow - 20v
                                  Orange - 60v
                                  Red - 60v
                                  Brown - 20v
                                  Black - 20v
                                  Also, one string of leds stays on for about a second longer than the rest - possibly corresponding to the green wire?
                                    Something wrong in that LED string circuit, it is either the IC or the LED string. One way to find out is to swap the Green wire with other LED wire to see if the problem will follow.
                                    • leggot
                                      • Oct 2014
                                      • 50
                                      First I disconnected the green wire - this led to 3/4 of the led string to function as intended.
                                      Upon swapping the green wire with the black wire, the same 3/4 of the string functioned; however now the string tied to the green wire doesn't turn on when it was reattached. Possibly the green wire string broken when it was attached to the black wire.
                                      Is there a way to test each LED individually? It would be acceptable to swap that one with an LED that is removed from the end of the string - that position would just have a jumper wire on it.
                                        You can test each LED as long as you can get to the solder pads for the LED, and if your meter can provide enough Vf and current to turn on the LED.
                                        • Borse2008
                                          Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                          by Borse2008
                                          Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                          I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                          • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                          • There’s
                                          07-15-2025, 04:55 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • mikey5791
                                          Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
                                          by mikey5791
                                          Got this working ips led monitor by the brand of
                                          Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
                                          Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
                                          09-04-2023, 03:50 AM
