Benq Q7T4 FP71G
  • FreeGeekVan
    • Oct 2008
    • 8
    Benq Q7T4 FP71G
    Working on a Benq FP71G model Q7T4. So far have found blown fuse, bad solder job on cap at C826, 2 blown transistors (those infamous C5707). Also included in attached photos is the MOSFET part number I think user "pecolt" was looking for in the Q7T3 thread.
  • nakourou
    • Oct 2008
    Re: Benq Q7T4 FP71G
    interesting so far i had the same bad soldure at the same part and the 2 blown transitor. C826 broke but no broken fuse, still looking to find what else may have broken ive tested the 4 transformators :t804 to t801 and they are all fine. got any leads to what it could be?
    • FIXITNOW
      • Jun 2008
      • 128
      Re: Benq Q7T4 FP71G
      "Replace Q808,Q809 --> type 2sc5707
      C826 0.22uF 160v
      C712 1000uF 10v
      PF801 3A wicked Fuse"
      • Krankshaft
        • Jan 2007
        • 2328
        Re: Benq Q7T4 FP71G
        Also check the FU MOSFETs one of them usually likes to open.
        If one is open both of the monitor blacklights won't turn off when you hit the power button.
        Oh yes and were not talking a standard 3 amp glass fuse it's a pico fuse it's a through hole component.
        It is black and almost the same size as an IN400X diode but it will say Buss (a fuse company) in green with the voltage and amperage on it.
        • Pentode
          • Feb 2008
          Re: Benq Q7T4 FP71G
          Wow! Just fixed a friend's benQ, and the culprit was also a bad solder joint on C826. Those transistors must pump out a lot of heat, and melt the solder next to them.
          Thanks to all.
          • zerophotos
            • Mar 2009
            Re: Benq Q7T4 FP71G
            i am having the same problem with mine, if anyone is still willing to help, solder on C826 looks fine and broken on mine, will re solder that, also, there is solder missing on one little spoke on the big yellow thing, will re solder them both tomorrow will start with C826, and leave other off and than try it, dosent appear to have had solder there b4 hand
            screen turns on for 1 sec, and flash's off
            • NxB
              • Feb 2009
              • 1595
              Re: Benq Q7T4 FP71G
              Probably C5707 ics. I had 2 of those last week, both the AC and DC versions. You're going to have to buy the parts. Just fixing solder joints isn't going to do it.
              • zerophotos
                • Mar 2009
                Re: Benq Q7T4 FP71G
                how much do you think it would cost to fix all up, not really worth throwing screen away i couldent find C5707 some solder is broken on mine but dose not look to bad, ill just solder it all up, and see how it goes, if it dosent work, will have to take it to the next step and get some parts for it. and see how it goes, how much would it cost for all most common parts which go???
                • PlainBill
                  • Feb 2009
                  • 7034
                  Re: Benq Q7T4 FP71G
                  FIXITNOW gave a list of parts above. Google lists a number of sources for the 2sc5707, several have it for under $2.00 each with no minimum order. The two caps should cost under $1.00 each. The picofuse might be the expensive part - you'll probably have to buy a 5-pack for $5.00. Add in shipping and it should still cost less than $20, delivered for everything on his list. Of course, this is for the USA.
                  PlainBill
                  • canadan
                    • Mar 2009
                    • 5
                    Re: Benq Q7T4 FP71G
                    I have the same Problem as FreeGeekVan. So far I replaced the (obviously blown) c712 as well as the c707, c708 and c709 (just in case). I furthermore put in an new Q805 (shortcircuited with IRFU 9024N and replaced al sc5707 with sc5707. I tested the fuse PF 801 and a current can run through. The symptom of a white screen with running backlight has not changed. Does anybody have an idea how to fix my Q7T4? I can not test capacitators so I do not know which other ons to replace. Furthermore my standart electronics dealer (in Germany) does not have any replacement for the c826 which was also one of the most common flaws. I will see if I can get that one elsewhere...
                    Cheers,
                    Canadan
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Re: Benq Q7T4 FP71G
                      Cheers,
                      Canadan
                      I've seen several references indicating a white screen is often caused by a blown smd fuse on the LCD panel itself.
                      PlainBill
                      • EGuevarae
                        • Nov 2008
                        • 1336
                        Re: Benq Q7T4 FP71G
                        PlainBill
                        Yep, I second that. The 5v rail is not reaching the panel logic board. Look for a fuse near the input connector and see if it is blown.
                        • ASUS ROG Maximus IX Code
                        • Intel Core i5-7600K 3.8GHz
                        • Windows 10 Pro x64
                        • GeForce GT1050
                        • canadan
                          • Mar 2009
                          • 5
                          Re: Benq Q7T4 FP71G
                          I read that reference, to. But I thought that the respective fuse is pf 801 which I have tested and found to be OK. There is however a glass fuse near the power input. I'll check that one.
                          • Bobdee
                            • Jun 2008
                            • 461
                            Re: Benq Q7T4 FP71G
                            the fuse you are looking for is not on the 2 boards that are pictured earlier in thread, they are on the screen panel,usualy under a metal cover that usualy has 3 tiny screws to remove to get at it, its very small not much bigger than pinhead,
                            • canadan
                              • Mar 2009
                              • 5
                              Re: Benq Q7T4 FP71G
                              Ok, I found the culprit and the fuse you mentioned seems to be blown. I am now thinking of hotrwiring it due to the fact that I don#t have the tools to put in a new fuse that small.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Re: Benq Q7T4 FP71G
                                You don't have a soldering iron?
                                PlainBill
                                • EGuevarae
                                  • Nov 2008
                                  • 1336
                                  Re: Benq Q7T4 FP71G
                                  PlainBill
                                  And Toasty criticized my 99c soldering iron.. at least I had one
                                  • GeForce GT1050
                                  • canadan
                                    • Mar 2009
                                    • 5
                                    Re: Benq Q7T4 FP71G
                                    I do have a soldering Iron, but it is let's say quite one the brink of destruction... It was a fairly cheap one and I can't get replacement tips. To replace the transistors I had to use up quite an exxesive amount of sandpaper on it. But I will probably try to replace the fuse anyway.
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Re: Benq Q7T4 FP71G
                                      First of all, get a decent soldering iron. You don't need a $200 (US, about $75 Canadian ) soldering station with digital temperature control, but you deserve one where you can at least replace the tips.
                                      If there is sufficient clearance you don't even have to remove the old fuse, just solder the new on on top of it.
                                      PlainBill
                                      • EGuevarae
                                        • Nov 2008
                                        • 1336
                                        Re: Benq Q7T4 FP71G
                                        PlainBill
                                        I started like him, but as things started to roll well, Toasty suggested something that's obvious but I needed that someone (him, in this case) told it to me to do it : get a decent Soldering Iron. As this was/is my main activity, I started with a cheap one because I didn't want to invest in something that maybe would not be uses so much. But now I changed the equipment because it is used and I will probably upgrade again soon. I understand his situation, and advice that he does the same as I : upgrade.
                                        • GeForce GT1050
                                        • cmlewis89
                                          LG 47LB5DF blown power supply board
                                          by cmlewis89
                                          Hi folks,
                                          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                          09-03-2024, 07:50 PM
                                        • Caspar
                                          BENQ GW2780-T power board blown
                                          by Caspar
                                          Hi all, I am looking for some help in ID'ing some parts in an attempt to fix a power supply from a GW2780-T monitor. The power supply PN is 715G7300-P02-006-0V3R. I have been looking around for the PN and it appear the board was used by other OEMs as well (ASUS, Viewsonic). If anyone has a schematic, it would be helpful.
                                          Quick look on the underside of the board, I can see:
                                          -D905 is blown - ? value
                                          -R920 is open - 1Ω ?W
                                          -R927 is open - 20Ω ?W
                                          On top side, I see:
                                          -R931 open - 0.68Ω ?W
                                          Metered short:
                                          -P9NK65ZFP...
                                          06-01-2022, 05:16 PM
                                        • drscoot
                                          HP X360 convertible battery blown fuse error, not charging
                                          by drscoot
                                          HP Modelnumber: 14-dh0061nb​
                                          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                          All these 3 batteries are charging...
                                          12-15-2023, 05:54 AM
                                        • swerg
                                          Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                                          by swerg
                                          Hey everyone,
                                          I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                                          I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                                          I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                                          06-06-2024, 03:39 PM
                                        • MrzPdlch
                                          Blown fuses on Gigabyte GTX 980TI 6GB
                                          by MrzPdlch
                                          Hey everyone,
                                          I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                                          Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                                          Find some pictures of the actual GPU together with a picture of how it should look like.
                                          I also wonder whther it might be a problem that there...
                                          03-10-2024, 04:14 PM
