Dell 2408WFPb display inoperative
+ More Options
Posts
  • magorkonig
    • Nov 2016
    • 18
    Greetings all,
    The problem: blackout happened at the house and now monitor when plugged in will give a green power button for a second and then go to yellow. Power button does not function and there is no display using any input source. Using the great information I have found on this forum I have obtained the following test results:
    Power board A
    118.9VAC both sides of F601
    118.7VAC into CN603
    Power board B
    23.4VDC both sides of F701
    159.6Volts across large cap C605
    Vcc pin on IC601 is 14.8VDC
    D602 reads OL and 0.47 (ok)
    Voltage across C716 is 18.3VDC stable
    10 pin connector CN701: 0/0/0/23.4/23.4/0/23.4/2.80/empty/0 (all VDC)
    Logic board
    0VDC on either side of F1 (surface mounted but fuse is not open)
    Since I have 23.4VDC on a number of pins to the logic board from CN701 I'm not sure if what I have is a power supply problem or something further downstream on the logic board. I have several donor boards from another monitor that I might be able to match and swap components but at this point I feel kind of blind.
    I have many years of experience in automotive DC circuits and while I remember most of my schooling on component operation and testing I haven't had a lot of practice at the board level. I have a PDI 890 automotive meter who's only limitation is capacitor testing.
    Thank you to all the contributors to this forum and any guidance you could offer.
  • boyebaran
    • Sep 2015
    • 247
    • iran
    Re: Dell 2408WFPb display inoperative
    hi
    please check F1 line (befor and after f1-which part connect to this fuse.).may you take a clear photo of around F1?
    measure ohm F1 to ground .
    always in switching power supply if you have problem so you dont have any dc output voltage.i think it is logic board problem.
    • magorkonig
      • Nov 2016
      • 18
      I have included the requested photo. I don't see anything mounted on the board on the left side of the fuse and the other side according to the etching looks like it's connected to a couple of caps (the large one above it and the tiny one beside it). The readings to ground are left side= 1.3kohms and right side= 4.8kohms. Maybe there is no voltage to that fuse because it isn't used??
      • boyebaran
        • Sep 2015
        • 247
        • iran
        "The readings to ground are left side= 1.3kohms and right side= 4.8kohms:"
        it is fuse and both side must be same ohm.
        "is no voltage to that fuse because it isn't used??"
        No.it have voltage.but seems that it is for external adapter.
        please first read to topic below:
        https://www.badcaps.net/forum/showthread.php?t=46546
        https://www.badcaps.net/forum/showthread.php?t=29271
        • magorkonig
          • Nov 2016
          • 18
          So the whole family has been sick so it's been a while since I have worked on the monitor. I read through both posts you listed and interestingly enough when I plugged it in to do more testing following those posts it powered on. I though maybe all the disconnecting and reconnecting things may have resolved it. I put it back together and went to install it in the house and it was back to the failed state again. So it's back apart on my bench and all the previous readings I listed are the same.
          • jetadm123
            • 2169
            Interesting that you're getting 23V output at CN701 and only 160VDC across C605. When the the power supply is fully operational, the PFC circuit (IC651) should boost the voltage close to 400VDC across C605.
            • magorkonig
              • Nov 2016
              • 18
              So from I have read the standby voltage across C605 should be ~1.4 x input (120VAC) which is what it is. But as you state above, when operational it should be 400VDC. Given that not all the wires in connector CN701 have 24 volts could it be because C605 is not getting the stepped up voltage? And since the beginning as soon as you plug the monitor in the front power light is a solid amber color and doesn't change. Maybe something is preventing the power supply from coming out of standby mode. I'm just throwing out ideas. Please forgive my lack of knowledge on system operation.
              • jetadm123
                • 2169
                I think the schematic below is for your power supply. It was drawn up by some other member a while back. I suggest you check the Vcc voltage of IC651 (L6561D) to see if it meets the minimum startup voltage. Also, since you say the monitor did work a bit after you hooked it up, then there could possibly be a bad solder joint?
                • magorkonig
                  • Nov 2016
                  • 18
                  Thanks for the schematic jetadm123. I checked the Vcc voltage per the diagram and when I measured pin 8 (Vcc) with the black probe on ground for the board I got -77.18VDC. When I checked the voltage using the IC ground pin (#6) it came up as 0.517VDC. I guess I need to know which is the correct way to read the voltage on Vcc line and depending on the answer I can assess my results. I will get out my magnifier and check all the solder joints again.
                  • jetadm123
                    • 2169
                    You are measuring the L6561 Vcc on the "hot" side of the power supply. Therefore, your ground reference should be the negative lead of the main cap, C605. Pin 6 of the L6561 chip is also connected to the neg lead of C605. Be careful on the "hot" side as you are dealing with line voltage. Since you are reading .5 VDC for Vcc, something is clearly preventing the L6561 from starting. Suggest you check Q654 for shorts.
                    • magorkonig
                      • Nov 2016
                      • 18
                      Checked Q654 for shorts to ground on the base, emitter and collector. None were found. Continuity to surrounding components per the schematic were also ok. I will check the solder joints tonight and see if I can come up with something. By the diagram it looks like IC652 controls Q654 so I'll be sure to check the joints on that one.
                        Connector CN701 pin that is connected to the resistor R677 (1K), that pin is the PS-ON pin to turn on the PFC circuit, so it should have >2.5VDC from the main board to turn on Q656, which then turns on OPTO IC652, Q654 which supplies the VCC to VCC pin 8 of L6561 PFC IC.
                        Please note that I do not know how accurate the SCH is.
                          • 31144
                          have the startup cap(s) been changed yet?
                          btw, from the foto i would re-solder the mains inlet connector.
                          • jetadm123
                            • 2169
                            budm made a good point- the schematic I provided is not factory supplied and it's accuracy cannot be guaranteed. You should verify that the points you are testing actually match those on the schematic. You might want to verify that the 2.8V you read on CN701 is feeding R677. If yes, then check everything budm mentioned in his post.
                            As for the startup cap (c620?) stj mentioned, it should be connected to pin 8 of the L6561. It's value is generally something under 47uf. Try replacing it. If you don't have the correct value, then try heating up the cap with a hair dryer to see if affects the monitor startup.
                              Power board B
                              I do not suspect the startup caps (C606 (47/50V), C611 (47/50V) otherwise you will not have the 23.4V output, the PFC Voltage booster is not working right now.
                              Check Q504 Emitter DCV, it should have around 15V (about the same Voltage at VCC pin 6 of the IC 200A6).
                              Check the Q505 E-B DCV to make sure that transistor is ON to provide the VCC for the PFC IC.
                              Check the resistance between VCC and GND of PFC IC.
                              All of the above are based on the SCH we have.
                              • magorkonig
                                • Nov 2016
                                • 18
                                So the 2.8V i am reading in CN701 pin 3 (by the diagram) is not feeding R677. Pin 9 is the one feeding R677 and it is 0V.
                                stj: I have not replaced any parts yet.
                                budm: Resistance between Vcc and Gnd on the PFC IC is OL. I think we are on to something with the lack of voltage to pin 9 on CN701 to feed Q656 and so on. I have looked all over the power and logic boards to find Q504 and Q505 and have been unable to find them.
                                  Run the board by itself and you can force on that Q656 with 3V battery to turn on that Transistor to see if the PFC will come alive.
                                  BTW, the drawing shows the connector as 10 Pin but the drawing has only 9 pins, I guess pin 2 is blank so it is not drawn in..
                                  • magorkonig
                                    • Nov 2016
                                    • 18
                                    Sure enough, with a 3V batt on pins 1 and 9 of CN701 with it disconnected from the logic board got the PFC to come alive. I had 401VDC across large cap C605. Pulling logic board now to check under magnifier. Will update with any findings.
                                    • creating
                                      • Dec 2016
                                      • United Kingdom
                                      Good luck! Please do report back - watching this with interest as I'm suffering a very similar fault. My 2408b fails to start up usually showing just a momentary flash of the green power LED when connected to mains. However, unplugging/replugging 20-30 times it sometimes goes into state you describe with green going to the stuck amber state. However if I keep retrying then the monitor will usually start (though this is getting worse, used to take only 1 or 2 attempts). Once it starts, the monitor works fine in normal mode, standby, sleep until mains power is removed.
                                      I also had the monitor apart and tested the 240V mains board (UK) and the secondary power board - all seemed ok and I was getting a solid 23.8V on the output side 100% of the time (although obviously under load). I couldn't see anything obvious on the logic board so gave up, put it back together and it fired up after a few attempts and I haven't switched it off since
                                      • creating
                                        • Dec 2016
                                        • United Kingdom
                                        ^^ er, typo I can't edit... ** 23.8V 100% of the time (although obviously NOT under load).
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • master3112
                                          by master3112
                                          07-29-2025, 01:55 PM
                                        • Garret Matt.
                                          DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
                                          by Garret Matt.
                                          I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
                                          Thank you in advance for any assistance you can render.
                                          Inductor In question. Buzzes like...
                                          06-20-2025, 01:21 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
