Vertical Lines Dell U3014
  • am318273
    • Nov 2016
    • 4
    Hey guys,
    Hoping I can get some help with my monitor.
    Had this UltraSharp U3014 since new and all of a sudden it won't display any sign of a working image. Unfortunately it's out of warranty so there's nothing I can do aside from attempt to fix it myself.
    -As soon as I power it up, I get a black screen with a white vertical band in the center that moves horizontally (don't think the "no input detected" dialog is supposed to move)
    -When I try to bring up the menu, the lines just shift to the right side of the screen. I can't see even a tiny bit of the menu.
    -When I plug in a source, I can tell there's movement because the vertical lines take up the entire screen and they change as the screen's content changes (picture 1)
    -When I run the self test (picture 2), I get an entire red, green and blue screen with some faint black vertical lines in the background, almost like screen burn-in. It looks worse in the photo than it is in person. In fact, I don't remember those lines being there before I ran the monitor for several hours, rather there was a faint bar in the right corner instead which is no longer there.
    - The text self test just gives me the same vertical bar as shown earlier.
    - Running the monitor for a long period of time adds a few more lines or artifacts like the faint background burn-in like lines, doesn't seem to be temperature dependent.
    Also, the refresh rate has slowed down to the point it looks like a CSTN screen when switching between test patterns.
    Does this sound like a defective t-con board? Defective main board? Or something more serious?
    Please see the attached photos.
    Any help would be greatly appreciated.
    Thanks!
  • 1supertech
    • Apr 2012
    • 384
    Re: Vertical Lines Dell U3014
    looks like a bad screen
    • boyebaran
      • Sep 2015
      • 249
      • iran
      defective t-con or panel problem
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        It's probably a bad panel, but check the t-con voltages anyways. Sometimes one of the main boosted rails on the t-con can make the display appear messed up. Typically it's caused by shorted ceramic caps. Post some pictures if you want to do a quick check of the voltages on it.
        • Charity
          • Dec 2017
          Originally posted by am318273
          Hey guys,
          Hoping I can get some help with my monitor. Had a UltraSharp U3014 since new and all of a sudden it won't display any sign of a working image...
          Hi, did you ever get it fixed? I seem to have a near identical issue + symptoms with the same monitor.
          Would also love to find out some voltages, etc that should be present, but can't seem to find a service manual anywhere? Anyone that can point me in the right direction? Most appreciated.
          • rddube
            Aspiring Expert
            • Jun 2013
            • 950
            As Momaka suggested to the other user, post some pictures of your boards (nice clear pictures taken in daylight if you can) and then one of the specialists (in my case it was Momaka) can tell you where to take voltage readings and can interpret them.
            • maceoC3po
              • Dec 2018
              Pictures of all boards from Dell U3014T attached.
              • nabla666
                • Dec 2019
                • 8
                • France
                HI, I have a faulty U301.
                I know it is the panel or the T-con board.
                ( I have a second U3014 to check this and the "panel+T-con" is is not working with the good parts and the good panel is working with the parts of the faulty U3014.
                However I did not try to switch the T-con board...
                My photos are not so good but I will post them, maybe you could have an advice on the faulty part, panel or T-con ?
                The faint vertical white lines are what I got when I switch it on.
                The green vertical lines is what I got when plugging an hdmi signal.
                The brown marks is the result of pee of my cat(s)....
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • Firentiosi
                  1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                  by Firentiosi
                  Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                  The issues are as follows: the...
                  11-27-2024, 12:33 AM
                • x_orange90_x
                  TCL 50S535 bad tcon or panel issue?
                  by x_orange90_x
                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                  03-29-2025, 11:02 PM
                • Ancient1
                  Strange LG TV issue : Image vertical lines in black screen
                  by Ancient1
                  Hi
                  Asking for a friend.
                  I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                  but here its the opposite !
                  TV has new T-con = same issue
                  A missing panel voltage would have global effect
                  So , what should one do ? how can I find where the fault is ?
                  Thanks !...
                  02-05-2025, 03:37 PM
                • Kambi13
                  Samsung LE32C530F1W with vertical lines on Screen
                  by Kambi13
                  Hello all, I'm dealing with a Samsung LE32C530F1W that now has vertical lines on the right side. It started with a ghost image on the top of the screen and then I tried the old trick of masking a few contacts in the flat cable that connects the T-Con board to the screen with some tape. It worked for a while and now out of the blue it turned into what you can see in the pic. I was able to get my hands on a known good T-Con board but the problem still persists. Now, what I've noticed is that the cooper colored flat cables that are directly connected to the screen itself are very hot to the touch...
                  09-15-2022, 07:48 AM
