Inspiron laptop boots to white screen with tested replacement screen assembly
  • axlmastr
    • Aug 2005
    • 158
    I just sold a tested screen assembly from a Dell Inspiron 5150 on ebay. This is the whole assembly not just the panel so all the buyer has to do is bolt it on and connect the LVDS cable, wifi, etc. This thing was in immaculate condition. I packed it very securely as with other screens and panels. I didn't make much on the sale since there were others that were very low priced and I paid shipping too so to compete with other sellers.
    Buyer receives it and "gently installs it" to a Inspiron 1100 (Service Tag# 9CTBT21) and claims to have a solid white display on boot and then a blotchy white screen apparently when it reaches the desktop (pics supplied by buyer through ebay message). Buyer claims that the purchase was made to remedy a cracked screen. They claim this is the second time they have replaced the screen since owning it from new and are just trying to keep it going before buying a new machine. Buyer claims they had an external display connected and working prior to installing my item so not graphics chip.
    I have not seen this issue before but according to searching the net a poorly seated LVDS cable at the motherboard or a damaged socket causing poor seating can cause this. Is there a mismatch between Inspiron 1100 and 5150 that I missed even though they are same series? If an external display works then it is within the screen assembly, as in LVDS cable, inverter, panel etc? Is my panel damaged prior to arrival based on pictures or is it installer error?
    Just wanted a rather solid opinion before I answer to refund or not. I accept no returns on tested items because I can't control the install or the installer as compared to if I did the work on my ESD safe bench and the correct tools.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Inspiron laptop boots to white screen with tested replacement screen assembly
    14" or 15" ? There are two resolutions to the 15".
    You say immaculate condition, did you test it before you sent it ?
    • ozzy214
      • Nov 2013
      • 319
      • usa
      That can happen if the pin wiring is incorrect, wrong resolution etc.
      My gut says screen is not compatible with lappy or in the least the lvds cable is wired wrong.
      How do I know this? I bought a lcd tester standalone. I have seen the same scenario with wrong res and lvds cable. Switch to right lvds or right rez...all fixed.
      You cans earch my name for the reviews on the tester a bit back.
      On a sidenote, I kick myself in the ass. I tossed $400 worth of screens doing same thing. I think my test lappy not comptaible and didnt have tester at the time;
      • axlmastr
        • Aug 2005
        • 158
        @diff - Yes I did test it before ship as with all my items. I did state that in my post both in the title and the message. It's a 15" clearly stated in the listing but after so many people don't read the listings I'm sure the buyer missed it. Unknown what the buyer's size is and with their service tag# I am unable to see the components list to determine if it is a 14". Buyer has a low feedback score and I am always wary of that.
        @ozzy214 - I am sure the buyer didn't read the listing and determine if the screen was compatible with their machine. The LVDS cable makes sense as well as the possible screen size difference per resolution.
        I only sell on ebay to pay for medical insurance and this sale just ate up all potential profit for resale since though I have a "no return policy" the buyer would have some "wiggle room" with ebay to get a refund. Most buyers never read the whole listing especially when they shop on mobile devices. I have two negative feedbacks from two buyers that had a language barrier with me to start and then had no idea what they were buying and how to use it. When I replied to their messages about an issue with the item they never responded and left negative feedback instead. That hurt!
        I will retest this item upon receipt and relist it in hopes that another sale will offset my losses.
        Thanks for the quick responses and insightful messages
        This thread is closed
        • abajor
          A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
          by abajor
          Having this very weird issue.
          The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
          I swapped with a working screen from an A2141 waiting for parts.
          The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
          The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
          04-27-2024, 01:37 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • pabloroggeri
          Dell inspiron 3421 that distortion on the screen
          by pabloroggeri
          Dell inspiron 3421
          Mother DNE40-CR MB.
          Good guys.
          I have this problem with this Dell notebook, it has that distortion on the screen as you can see in the photo. has it ever happened to you?
          I present the tests and measurements that I already did:
          I tried with another screen and it does the same thing, I also put this screen on another one and it looks perfect.
          I checked the LVDS flex that goes to the display and it is perfect
          Through HDMI output the image looks perfect
          All power lines were measured...
          09-29-2023, 06:46 AM
          DELL Inspiron 3250 Inspiron 3000 i5-6400 Specification for Upgrade or Repair
          This specification for the DELL Inspiron 3250 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3250 boardview and Inspiron 3250 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
          09-12-2024, 03:44 PM
          DELL Inspiron 3470 Inspiron 3000 i5-8400 Specification for Upgrade or Repair
          This specification for the DELL Inspiron 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3470 boardview and Inspiron 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
