ASUS VK191S - no power
  • ragis
    • Mar 2013
    • 51
    • Bulgaria
    Hello again, folks !
    This time i have a monitor which don't power on or stand by.
    PSU - tip019at-01
    Checked:
    STK0765 - not sure how to test mosfets (put com to source and then charge gate then red probe to drain - gives 1.500 for a sec.) so i'm not sure if it's OK
    SBT150-06 - Readings 135 ohms on the two anodes (i think it's ok)
    LD7575PS - VCC is 11.25V no shorted legs
    Both fuses are OK
    The output is 5.0V
    There is voltage to the main board and to the button board but there is no power on or stand by
    Checked the button board led - OK
    I don't have schematic for the psu...
    Thanks, again for your kind help and support !
    Best regards, ragis
    • 31015
    Re: ASUS VK191S - no power
    nice low-res foto's
    list the pins on the psu and what comes out of them.
    • ragis
      • Mar 2013
      • 51
      • Bulgaria
      Sorry for the photos, here's new ones
      On pin 3,4 - 5.10V
      pin 1,2,5,6,7 - 0V
        • 31015
        there are a lot of cracked solder joints on that - and i'm not refering to the flux covered resoldered pins.
        • ragis
          • Mar 2013
          • 51
          • Bulgaria
          The solder joints are ok, it seems like that from the flux i used around the pins
          But i can resolder them if you think there is a problem, could you be so kind to show me the cracked ones ?
            The power supply is an always on power supply, since you are getting the 5V for the logic board and the 12V for the inverter circuit, the power supply is find but it is not receiving the command signals from the main/logic board to turn on the backlights inverter circuit or the dimming command signal. The problem is not the power supply board.
            • ragis
              • Mar 2013
              • 51
              • Bulgaria
              The client told me that there was a surge shock and the monitor stopped working i can't locate any burned component .. Can be the logic board get demaged.And last thing how can i test the inverter ?
                • 31015
                i still see bad solder joints - NOT THE ONES YOU DID.
                  You can test the power supply/inverter board by itself.
                  I can see three small control line traces, two I can see, the third one I cannot see.
                  I suspect them to be BL-ON, PWM-DIM, ANALOG DIM.
                  You can disconnect the logic board from the power supply board, then solder 1K resistor between # 1 and the 5V pin, then a second 1K resistor between #2 and the 5V pin to see if the backlights will come on the second you plug the monitor into the AC outlet, if not add another resistor between # 3 (which I cannot see due to cruds on the pins) and the 5V.
                  The surge may have come through the Video connections.
                  • ragis
                    • Mar 2013
                    • 51
                    • Bulgaria
                    Ok, so i added 3 1K resistors to the 3 pins and then without logic board i plugged the monitor in AC and the backlight started blinking.I think that means the inverter is OK.But why it can't power on the monitor and even go to stand by mode... What can i do now ? Thanks again for the help to check the inverter
                    • ragis
                      • Mar 2013
                      • 51
                      • Bulgaria
                      Just one simple question:
                      on the logic(main) board there are 2 voltage regulators U1 and U2
                      U1: pin3(input) - 4.74V pin2(output) - 3.28V pin1(adjustment) - 0V
                      U2: pin3(input) - 3.28V pin2(output) - 1.78V pin1(adjustment) - 0V
                      They are both 1117 but i don't know if they are fixed or adjustment the marks are:
                      U1: 17-33
                      U2: 17-18
                      Thanks again
                        U1 is 3.3V fixed
                        U 2 is 1.8V fixed
                        So they are OK.
                        • ragis
                          • Mar 2013
                          • 51
                          • Bulgaria
                          Ok, any other sugestions ?
                          • ragis
                            • Mar 2013
                            • 51
                            • Bulgaria
                            OK, monitor repaired !!!
                            The problem was in the logic board SPI flash IC - SST25VF010A
                            I used a flash bin from VK191D and it worked
                            Thanks again for the replies and help from stj and budm
                            As stj recommended i resoldered the whole PSU.
                            So the solution is to reflash the IC !
                            Thanks again and best regards, ragis !
                            • GLISIT
                              by GLISIT
                              01-16-2025, 02:29 PM
                            • PantherDave
                              by PantherDave
                              Hi all!
                              05-29-2024, 02:01 PM
                            • ShadowAi
                              ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                              by ShadowAi
                              Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                              Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                              After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                              03-15-2024, 10:46 AM
                            • meraklinetx
                              Asus Z97-a power cycle, no boot no cpu voltage
                              by meraklinetx
                              Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                              05-10-2023, 06:08 AM
                            • conghuyms
                              Request for Help – ASUS G531GW Rev 1.6 – No Power On
                              by conghuyms
                              I need your support with an ASUS G531GW Rev 1.6 laptop.
                              When I plug in the charger, the battery charging LED turns on, but the board does not power on when pressing the power button.
                              Here’s what I’ve checked so far:
                              • Motherboard has been removed for inspection.
                              • 3V and 5V always-on rails are present (3V/5V_ALW).
                              • 1.8V and 1.09V at the PCH are present.
                              • I don’t have the boardview/schematic, so troubleshooting is limited.
                              • I tried checking the power button signal from the
                              07-20-2025, 09:14 PM
