Need sizes of all the electrolytic caps of power board 48.L8302.A30
  • diretouch
    • May 2016
    Hi there. This is my first thread. I have one BENQ monitor here. Everything was good when i buyed the display but it is for one good-known client and wanted to renew the electrolytic capacitors put in power board. The board has one more title - cqs ds1107A 1.6mm
    I have replaced all the capacitors(electrolytic) but am unsure if i have made some mistake with sizes and voltages. I made one picture before desoldering them and wrote everything(almost) in one txt file but one i didn`t find the value and voltage - c 813.
    I attach the photo.
    And one more questions - maybe everything is good but i see a big black spot on the other side of the IC701. It includes the space between three things l702,c709 and r702. If i have to of course i will make a photo and upload.I cannot recognize the item title. If i knew it i can check local stores for it.
    Thanks in advance.
    master hoarder
    • May 2008
    • 12175
    Re: Need sizes of all the electrolytic caps of power board 48.L8302.A30
    Hi, can you tell us what is the model number of that BenQ monitor? I have several Dell monitors and one of them may have the same power board inside so I could check.
      Is this the board? BENQ FP71G
      http://www.ebay.com/itm/Power-Board-...p2047675.l2557
      • Noodneek
        Replacing all the caps on the BenQ SW2700pt's power board didn't help...
        by Noodneek
        My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
        I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
        08-30-2024, 12:52 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • black6host
        Replacement caps for Samson Resolv studio monitor 65A Amp board.
        by black6host
        Good day!
        I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
        I'm going to replace the caps and I'll be the first...
        02-06-2024, 08:22 PM
