Re: Mag 900P: blown chip and two bad caps...
This post brought to you by the letters W, T, F, and the question mark.
on my xerox monitor is called BDPA1K
whole idiots at all the time are changing IC why?
you have to order AO4606 6 Amps current draw
or AO4620 7 Amp. after replace, you have to wax are of this IC
to better isolation from air, this chip works at 40khz(40,000) Hz/s WOW
must be isolated from air moisture. If you living at Niagara Falls area
do not buy LCD only CRT.
KrisLeave a comment:
I just posted a similar problem, the PS that you have seems to be the same on as in my Xerox XG-91D monitor. The chip is the same one as just above it. The part number on mine is BD5A28 but I can find no reference for this chip. My chip is burnt and part of the silicone is missing. The caps by it are not swollen though. I hope someone can give us a cross reference on that chip.
Lwolffe
I am hoping the people in this forum may be able to help me out.
I have been given a monitor that exhibits the behavior described in this forum, namely it goes black in less than two seconds after being turned on.
It is a Mag 900P, with a Product ID of LT982s, Manufactured December 2004.
The capacitors on the Power Supply board look good in this monitor, instead it is a pair of capacitors just to the left of the power connector, on the Display controller which are swollen.
The catch is this: the Power Supply board I am looking at is not the same as the ones you seem to be describing and which I have seen pictures for in this forum (I have not seen every picture, but I have looked at many), and it looks like someone let the smoke out of one of the chips of the monitor I have.
I am hoping to be able to identify this chip so I can replace it while I am inside the monitor, anyway.
Ultimately I would like to know the recommended replacement caps, and where they can be ordered from, for the Display Controller, and if anybody has a Power Supply board like mine can they tell me what it says on the chip/what chip was/what it was for. Basically it looks like the monitor might work without this chip if I replace the two bad caps, but I am wondering if the chip might be why the caps failed, or the reverse.
The three images (attached) show:
1) The power supply board
2) The location of the bad chip, on the opposite side of the power board.
3) A lousy close up where you can sort of see the smoke trail.
Thanks in advance,
Myself
because the first ic was exploded and I have to replace this monsterLast edited by kris1961; 02-21-2011, 12:17 PM.Leave a comment:
Originally posted by MySelfWebpage for the 4606: http://www.aosmd.com/web/products/pr...tnumber=AO4606
Apparently the recommended replacement is an AO4620.
Sales contact info is also available at the site.
Thanks for this post. I have the exact problem as you do with the MAG 900P, LT982s. Chip 4606 is burnt. I haven't contacted the supplier you mentioned yet for the AO4606. Just wondering, do you have any extra chips laying around? If so, I'll buy a few from you instead if you're interested.Leave a comment:
BD5A28 is a manufacturer number, the part number is the number above this one, to the right of the A in a circle.Leave a comment:
Sales contact info is also available at the site.Leave a comment:
Lwolffe;
Sorry for the delay, I had things to take care of that could not wait.
I have cleaned up the burned chip somewhat and I have discovered that on my board the burned chip and the one next to it are the same. There are two numbers on the Chips: a) 4606, and b) BE4Y1A.
I hope that helps.Leave a comment:
It was definetely hot alright. Those inverters look 15yrs old not 4.
Betch ya that came out of a doctors office near a window and was never turned off at max brightness.
The 5a28 brings up a data sheet from philips, but it's not your chip, sorry.
I always run my hand around a display monitor to take it's temperature in the stores.
Sales dudes think I have a wierd fetish.Leave a comment:
I guess no one can help. Can you tell me the part number of the same chip right next to it. I would like to track down one for my board
WolffeLeave a comment:
To clarify:
The bad chip is on the power board.
The bad caps are on the controller board.
The pictures I included are only of the power board.Leave a comment:
LwolffeLeave a comment:
replace the caps and try it.
those run hot and darken the board.Leave a comment:
Thanks in advance,
MyselfTags: None
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by black6hostGood day!
I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
I'm going to replace the caps and I'll be the first...-
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by SMDFleaCommon SPI bios chip programming Questions and Answers
Bad...-
Channel: BIOS Requests ONLY!
09-02-2021, 04:40 PM -
by odtechGreetings friends.
I was given this nice little laptop and would like to revive it if possible but i'm stuck identifying blown components. I'm very new to the repair game so i'm proceeding very cautiously.
I don't know the history of this laptop and the donator didn't elaborate what happened but it seems some moisture got into the USB C charge port and the result was what looks like some blown caps. The tell is some gunk inside the USB C port and corrosion on the outside as well as what looks like corrosion around the blown components.
Any guidance... - Loading...
