dell vostro 3460 m/b DA0V08MB6D REV D
hi i need dell bios vostro 3460
Channel: BIOS Requests ONLY!
by 417731Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
Model: Dell Vostro 3405
Tag:F0B1YF3
CPU:Ryzen 3500U
Thanks in advance-
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by sammus540I have a Vostro 3420 8H8K5R3-8FC8 that freeze at any attempt to enter bios password or the recovery master password received from dell. I do not have a clean BIOS image to flash.
And as luck would have it happened a couple of months ago right outside of the warranty period (Dec 2023) warranty expired in September. Any help or guidance is appreciated.-
- Loading...
